OBA -> On Board Air Mega Thread & BS
Discussion in 'Technical Chat' started by Gunshot-6A, Oct 20, 2013.
  1. Dec 7, 2018 at 11:31 PM
    #1721
    Red18Taco707
    Red18Taco707 Well-Known Member
    Richi
    Nor Cal
    Red 18 TRD POOR
    :notsure: I did. Also thinking about adding the remote hoses at the front and rear.
    moser633[QUOTED] likes this.
  2. Dec 7, 2018 at 11:33 PM
    #1722
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    My heavier wires pass through the grommets under the seats. In under the driver's seat to the relay and out to the compressor under the passenger seat. Ground wire runs along the passenger frame rail up into the engine bay across and around to the battery. Since I brought air into the cab I installed the pressure switch and relay there under the console along with a 6-way mini fuse box that I'm converting to 2x3-way so I can have both always hot and ignition hot fuses there. One nice thing about the 5-manny is that there's a perfect spot below the cup holders and after sanding the clips it pops out as easily as the dash fuse cover cubby.
  3. Dec 8, 2018 at 1:39 PM
    #1723
    moser633
    moser633 2016 TRD OR AC
    2016 magnetic grey Tacoma TRD Offroad
    Aux Reverse Lights, tailgate inserts , TRD PRo Grill, Truxedo lo pro gt tonnaeu cover, Cali Raised led Apex stealth light bar Cali raised led Ditch Lights ARB on Board air Method NV Bronze 16 in with 265 75 16 Cooper STT Pro
    installed me arb single just need to order my switch to fit in my dash but runs and fills up my tires in about 2 minutes.
  4. Dec 24, 2018 at 8:20 AM
    #1724
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Still in the works but I went with a simple OBA this time. Have one QD at the front bumper and one QD at the rear bumper. 6g power wire that will be turned on by manually flipping the breaker under the hood. No tank this time.
    TacoNorth76 and buyobuyo like this.
  5. Dec 31, 2018 at 8:30 AM
    #1725
    SGTCap
    SGTCap Well-Known Member
    Cap
    Summerville, SC
    4x4 6-spd,
    37s, 4x4 6-spd, OME 886s, Allpro Expos, SOS sliders and front/rear bumpers,Rack,Skids, 4.56s, Lockers,Recon Winch, TJM RTT, Lots of tools, boxes and gear. Shaggy mutt behind the seat
    I like this
  6. Dec 31, 2018 at 8:54 AM
    #1726
    07taco
    07taco Well-Known Member
    san antonio
    2017 taco trd dclb
    Easy install and wiring. Air tank next.
  7. Jan 14, 2019 at 2:30 AM
    #1727
    weldertaco
    weldertaco Mr.13%bodyfat
    texas
    TrailRunner
    4wd to 2wd conversion
    Just installed all this over the weekend. Only problem is the 5 pin switches. Can anyone draw me a wire diagram or break it down like a 5 yr old as to where I messed up if I PM you a diagram of what I did? I got all the switches to work but they don’t light up when switched on.
    Wiring is my kryptonite and I’m trying to get better at it but it can feel overwhelming
  8. Jan 14, 2019 at 7:32 AM
    #1728
    anthony250f
    Anthony
    San Diego, CA
  9. Jan 16, 2019 at 6:18 AM
    #1729
    golfindia
    golfindia Well-Known Member
    Yes.
    pickup truck
    I have a 2.5g Viair tank that came with one of these "compression fittings" in it:
    https://www.viaircorp.com/fittings/compressionfittings
    What documentation I have found says it's for 1/2"od-3/8"id hose. Ok, what kind of hose? Nylon? DOT? Rubber? Braided? All the above? Just trying to avoid trial and erroring this.....
  10. Jan 16, 2019 at 7:02 AM
    #1730
    YamaDirtrider
    YamaDirtrider Custom bumpers @FORT-ifyRigs
    Josh
    Elizabeth CO
    06 DCLB sport postrunner
    What hasn't been modified?
    Compression fittings usually use the air hose rated by dot. It’s the same line that semi’s use.
  11. Jan 16, 2019 at 9:21 AM
    #1731
    bagleboy
    Scott
    Norcal, Santa Rosa
    I switched out some of the ptc fittings for 1/4" compression(still same plastic air lines) and used brass insert nipples inside the tube ends. Assembly seems to go a bit easier with a little silicon lube on the air line and nylon compression sleeve.
  12. Jan 16, 2019 at 10:35 AM
    #1732
    golfindia
    Yes.
    pickup truck
    Thanks. I presume that the 1/2 and 1/4 DOT tube will handle 200psi?
  13. Jan 16, 2019 at 11:46 AM
    #1733
    YamaDirtrider
    Josh
    Elizabeth CO
    Should. Semi’s run 120-140 psi.
    I thought the lines had the rating on them. Either 200 or 300psi
  14. Jan 16, 2019 at 4:34 PM
    #1734
    golfindia
    Yes.
    pickup truck
    Yeah, I can't tell. Some say "435 psi" some say nothing. some reviews look like people used the tubing for ice machines, so WTF indeed. Some 1/2" tubes are listed as 1/2 od, some are listed as 3/8 od. So screw it, not wasting $40 to find out. I took off the weird compression thing and put a 1/4npt in there. I can figure that out.
  15. Jan 28, 2019 at 6:21 PM
    #1735
    apocataco2015
    apocataco2015 Well-Known Member
    Clayton
    Salado, TX
    2017 Tacoma TRD OR 4x4
    Fox/OME/Icon lift. TRD Beadlocks. Toyo MT’s. Pelfreybilt, RCI, Mobtown armor.
    Greeting all. I’ve got the single ARB installed but the wiring of the switch has got me stumped. I haven’t read every post in every thread related to OBA but hopefully someone can help. Ive got a Rago switch and so far no luck. I’ve tried every combination of wires I can think of to get it to turn in but obviously I’m doing something wrong. I checked the fuse and it looks good. I’ve checked the terminals and the harness connections. I’m not using ignition wire on the switch because I don’t care if it lights up. I’m also not using the secondary harness that comes with the compressor because I’m not running it to lockers. I’m just using the compressor to air up my tires and my kids soccer balls. Any idea what I’m doing wrong here?
  16. Jan 28, 2019 at 6:44 PM
    #1736
    YamaDirtrider
    Josh
    Elizabeth CO
    On the compressor side looks like your only gonna use the red.
    Green and yellow go to the connectors which plug into the locker solonoids.
    On the switch side, I think it’s red and green. Red can connect to red and green wound be power in (12v source) the other red and black can go to the dimmer circuit. Or just to switched power. It’s the light for the switch
  17. Jan 28, 2019 at 6:53 PM
    #1737
    apocataco2015
    Clayton
    Salado, TX
    Thank you for the help. Sorry but I’m not clear on the switch side. Red goes to red, and the green goes to what? What do you mean green wound be power?
  18. Jan 28, 2019 at 7:00 PM
    #1738
    YamaDirtrider
    Josh
    Elizabeth CO
    So red 1 Shound go the the red on the compressor
    apocataco2015[QUOTED] likes this.
  19. Jan 28, 2019 at 7:03 PM
    #1739
    apocataco2015
    Clayton
    Salado, TX
    Thank you for your help. I’ll give this another shot tomorrow and report back.
    YamaDirtrider[QUOTED] likes this.
  20. Jan 28, 2019 at 7:05 PM
    #1740
    YamaDirtrider
    Josh
    Elizabeth CO
    Did arb give you the wiring diagram in the packet? It Shound have what wire is the activation. It Shound be the red since the others go to the connectors, but doesn’t hurt to double check
