OBA -> On Board Air Mega Thread & BS
Discussion in 'Technical Chat' started by Gunshot-6A, Oct 20, 2013.
  1. May 9, 2019 at 2:49 PM
    #1861
    YamaDirtrider
    YamaDirtrider Custom bumpers @FORT-ifyRigs
    Josh
    Elizabeth CO
    06 DCLB sport postrunner
    What hasn't been modified?
    If you want to a different switch, all you need is the power wires and the purple wire.
    Wile I did not extend my harness, I did gut all the unnecarry wires and did a custom ch4x4 switch
    RUSSELLTACO[QUOTED] likes this.
  2. May 9, 2019 at 2:56 PM
    #1862
    RUSSELLTACO
    RUSSELLTACO Well-Known Member
    Blacksburg Va
    silver shitbox
    bolt ons and autozone decals
    i have a spot that the arb switch would fit in i did some browsing in here and im seeing that the part of the harness to the switches is optional
    Gunshot-6A[OP] likes this.
  3. May 9, 2019 at 3:03 PM
    #1863
    Gunshot-6A
    Gunshot-6A [OP] Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    most of it is optional. To make your own, you just need a run that goes from battery to relay to compressor, with a small cutout for the pressure sensor. Then a small wire run that goes from power to switch to the relay to turn on/off.
  4. May 9, 2019 at 3:13 PM
    #1864
    YamaDirtrider
    Josh
    Elizabeth CO
    The twin has its own internal relay and pressure switch.
    All he needs is to apply +12v to the purple wire to activate the compressor. Once it gets to 150 it’ll shut off.
  5. May 9, 2019 at 3:17 PM
    #1865
    RUSSELLTACO
    Blacksburg Va
    silver shitbox
    thank you
    Im assuming you went to tech? I start there next semester to finish my Mechanical Engineering degree.
  6. May 9, 2019 at 3:58 PM
    #1866
    Gunshot-6A
    Conner
    Everett, WA
    Indeed I did! 'Congrats, and I'm sure you'll do well.
  7. May 9, 2019 at 7:52 PM
    #1867
    Ritchie
    Ritchie Well-Known Member
    San Diego (North County)
    RC Step side Pre-runner
    2.7 w/auto, 4WU 3 link, F & R Diamonds, ARB's F/R w/ Yukon 5.29's, Inchworm 4.7 Lefty, Deavers, ARB OBA, Schrockworks up front.
    The ARB pressure switches shut off at 100 psi. This eliminates any chance of blowing the seals in the lockers.
    The twins do operate at 100% duty cycle which is cool for air tool operation.
  8. May 9, 2019 at 8:03 PM
    #1868
    Ritchie
    I would refrain from extending the harness at all. The twins pull 56 amps IIRC. Extending the harness will increase resistance and could possibly melt wires and start an electrical fire.
  9. May 9, 2019 at 8:13 PM
    #1869
    YamaDirtrider
    Josh
    Elizabeth CO
    135-150 is the twins cutoff
    Ritchie[QUOTED] likes this.
  10. May 9, 2019 at 8:24 PM
    #1870
    Ritchie
    Hmm, not mine, and I’ve had two of them. Do you have ARB lockers?
    I have front and rear ARB lockers and anymore than 100 psi, which is where my compressor shuts off, you’ll blow the seals within the locker.
    One can modify the compressor if not utilizing ARB lockers though. Out of the box, 100psi shut off is the norm.
    Verified by Matt @ ARBUSA.com.
  11. May 9, 2019 at 8:33 PM
    #1871
    YamaDirtrider
    Josh
    Elizabeth CO
    I don’t have air lockers and when I add a locker I’m going electric rear lsd front
    It’s norm is higher. Mine straight out of the box was going past a 125 safty valve.
    When I hook up to air up tires it’s in the 139-149 range.
    Very last page: https://www.4wd.com/sku/ARB 4x4 Accessories/standard/CKMTA12.pdf
  12. May 9, 2019 at 8:40 PM
    #1872
    Ritchie
    Hmm,
    My manual does not reference the pressures you provide. My compressor pressure was verified with a crystal pressure gauge as I didn’t want to blow seals in my lockers. My compressor is actually at 99.1 psi at shutoff. Volume instead of pressure to air up my tires and operate my air tools. Add to that, the seals in my lockers have never blown.
  13. May 9, 2019 at 8:40 PM
    #1873
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    ARB docs say otherwise..?
    I'm inclined to listen to technical docs not sales people.
    https://www.arb.com.au/assets/air-lockers/3-06.pdf
  14. May 9, 2019 at 8:42 PM
    #1874
    Sandman614
    Tim
    '06 SR5 Off Road
    Another data point
    Ritchie likes this.
  15. May 9, 2019 at 8:49 PM
    #1875
    Ritchie
    Sandman,
    My question is, how new is new?
    My lockers and system is 3 years old. I like new tech and all and if there are new upgraded seals available to obtain higher pressures to operate other items, I’m all for it.
    Seems nobody wants to answer this.
  16. May 9, 2019 at 8:58 PM
    #1876
    Sandman614
    Tim
    '06 SR5 Off Road
    Yes I have arb lockers front and rear, I do not have arb compressors. This is my email from Chase at east coast, I'd consider them professionals and technically inclined enough to provide correct answers. I've also had my lockers for 3 years. If I can dig up my installation manuals I'll check their wording too.
  17. May 9, 2019 at 9:00 PM
    #1877
    YamaDirtrider
    Josh
    Elizabeth CO
    My compressor is at least 1-2years old.
    No I do not have air lockers. Ya missed my edit ^ when I regear and add a locker in the rear it’s going to be electric. Seen the stories of arb’s leaking.
  18. May 9, 2019 at 9:05 PM
    #1878
    Sandman614
    Tim
    '06 SR5 Off Road
    The arb doc I linked is also dated 2016
    Run your system like you want, it's your system. Just don't need to scare other people when the documentation clearly reads what psi it (should) operate at. *should because apparently yours doesn't.
  19. May 9, 2019 at 9:29 PM
    #1879
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I could be wrong about this but I think here are actually two pressure regulators in a system that runs an ARB locker. The twin comp has an internal regulator and is the one that cuts off at 135/150 psi. But as you've been pointing out, that is too high for the locker seals.
    On my setup there is a 2nd, external regulator along with a small air tank that is for the front locker. IIRC, it shuts off at 90 psi. Here is a pic of the small tank. The pressure regulator solenoid is a small black cube (not pictured) that is mounted on the output side of the air tank, between the tank and the air line to the locker.
  20. May 10, 2019 at 8:34 PM
    #1880
    Nate87
    Nate87 Well-Known Member
    Nate
    CONUS
    2013 AC TRD OR
    I run a twin compressor with ARB front and rear. Pressure cutout is 150 and cuts in around 125-135. Been running that setup for about 5 years. No blown seals or issues with anything. Just throwing that out there for those scared shits going to blow up.
