OBD Fusion Enhanced Diagnostics and A/T Temp
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Markc1024, Feb 25, 2017.
  1. Sep 3, 2020 at 4:05 PM
    #41
    mattleg
    mattleg Well-Known Member
    Kansas
    2020 OR DCSB AT 4WD
    MT's don't have temp sensors.
  2. Sep 3, 2020 at 4:42 PM
    #42
    b3itz
    b3itz Camp Life
    Northern KY
    2016 MT OR DCSB
    Tuned, geared, armored, BP51s...
    Roger that. Any reason or way to add one? Seems odd unless the mt maybe isn't vulnerable to heat as badly as the at
  3. Sep 3, 2020 at 4:56 PM
    #43
    mattleg
    Kansas
    2020 OR DCSB AT 4WD
    MT's don't generally need auxiliary cooling, far less heat is generated so passive cooling is enough without the need for temp monitors. Industrial applications, semi-trucks for example, more commonly have temperature and auxiliary cooling on an MT and even differentials.
    AT's generate more heat due to the torque converter. Modern AT's in particular are sensitive to fluid properties. Auxiliary cooling and temperature monitoring is almost always needed.
  4. Feb 19, 2021 at 2:27 AM
    #44
    a522467
    a522467 Life’s short. Live now.
    Ohio
    Two 2015 White TRD Pros
    ARE topper, custom vinyl accents, weather-tech liners, spring upgrade, bed step, seat covers
    I know this is an old thread, but...
    Are these two transmission temp data points available with the basic $10 OBD Fusion app, or will I need to spend more $ to upgrade to find these?
  5. Feb 19, 2021 at 4:13 AM
    #45
    glk21c
    glk21c Well-Known Member
    MD
    2007 Silver Tacoma TRD Sport 4x4
    for my 2007, yes they were.
    a522467 likes this.
