OBD Fusion tips and tricks
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Totall4285, Jan 28, 2019.
  1. May 4, 2021 at 11:56 AM
    #301
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    After putting it into the dropbox folder (correctly mapped of course), did you go through the import process in OBD Fusion? It's not intuitive :)
  2. May 4, 2021 at 11:59 AM
    #302
    RushT
    North Texas
    Lt. Dangle[QUOTED] likes this.
  3. May 4, 2021 at 12:07 PM
    #303
    BortisYeltzen
    BortisYeltzen Well-Known Member
    Barrett
    Salt Lake City, UT
    2017 MGM TRD Off-road DCLB
    OTT Tuned, Bilstein TRD Pro lift, ECGS bushing, Heated Clazzio's, RCI SKID TRILOGY, BAMF sliders, ARE V-Series shell, RokBlokz flaps, more to come
  4. May 4, 2021 at 1:03 PM
    #304
    reymataco
    reymataco Well-Known Member
    Denver, CO
    2020 DCLB Off Road Premium in Slowsand
    I can't find Transmission Actual Gear any longer, and it didn't read any value when I had it hooked up. I don't see Gear or Transmission anything when I search PIDs. What is the correct PID to get the gear my truck is currently in? Do I need to buy the extras pack specific to my vehicle?
  5. May 4, 2021 at 1:09 PM
    #305
    dunlap837
    dunlap837 Well-Known Member
    2018QSDCLBSR5
    Enhanced Skinny Pedal
    status of the shift status
    RushT and reymataco[QUOTED] like this.
  6. May 4, 2021 at 3:33 PM
    #306
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
  7. May 4, 2021 at 3:34 PM
    #307
    Lt. Dangle
    Ohio
    I haven't done anything yet. Still researching stuff.
  8. May 5, 2021 at 7:29 AM
    #308
    Lt. Dangle
    Ohio
    How do you move a title left or right when merging displays? Mine only go up and down?
    I can make it go right by adding spaces before the title, but is there a better way?
  9. May 5, 2021 at 9:03 AM
    #309
    RushT
    North Texas
    Good question. My testing shows what you found. But.... if you put a decimal in front of your leading letter in the title, you can then add a bunch of leading spaces. Then you can go back and edit out the decimal.
    That will force the title to the right. It’s a bit of a kludge.
  10. May 5, 2021 at 12:11 PM
    #310
    Lt. Dangle
    Ohio
    After playing with it a bit, outside of layering and fading a gauge outside of the wanted text, I can't think of another way to move the text. Someone has a better way, I'm all ears. Using two PIDS to move text to the left or right, seems wasteful.
  11. May 5, 2021 at 4:08 PM
    #311
    reymataco
    Denver, CO
    This is not an SAE PID either. None exist with the word "shift" in it. Do I need to buy Toyota extras pack for $9.99 to get AT current Gear? That seems bonkers to me. Transmission Actual Gear Status is what I am using and it just reads 0 all the time.
  12. May 5, 2021 at 4:09 PM
    #312
    SubaruTheTacoma
    SubaruTheTacoma SubaruTheTacoma
    Rhys
    USA
    2017 STI Off Road
    HELLA Horns BP-51 ARB Summit SCS Ray 10 And many many others
    I got the Toyota pack and it works
    Lt. Dangle likes this.
  13. May 5, 2021 at 4:10 PM
    #313
    SubaruTheTacoma
    Rhys
    USA
    2017 STI Off Road
    is it normal for OBD Fusion to lag a lot or are my settings wrong. I am using the MX+ I was using Carista and that lagged like crazy so I thought it was that but then coughed up the 120 for the mx+ from obdfusion thinking it would fix it .... but it did not.
    any advice?
  14. May 5, 2021 at 4:37 PM
    #314
    reymataco
    Denver, CO
    I just bought the 2020 Toyota Extras pack, it has Shift Sensor Status. Will try that out, thanks!
    EDIT: Correct PID (from Toyota 2020 extras pack) is "Shift Status" FWIW. Pretty much exactly what @dunlap837 said :rofl:
  15. May 9, 2021 at 12:49 PM
    #315
    Patton250
    Patton250 Bible and Gun Clinger
    Brett
    Tampa Florida
    2021 Tacoma SR5
    I just purchased OBD fusion app and Carista. How are you getting the gear gauge? I can’t find it anywhere on the app. I feel like an idiot because that’s pretty much the biggest reason I got this.
  16. May 9, 2021 at 1:01 PM
    #316
    Lt. Dangle
    Ohio
    Status of the shift status under transmission I believe.
    Patton250[QUOTED] likes this.
  17. May 9, 2021 at 1:05 PM
    #317
    Lt. Dangle
    Ohio
    How much lag we talkin? I have Carista and have like a second delay. How much info are you trying to monitor? I have very few PIDs at the moment, like 10 or so.
  18. May 9, 2021 at 1:12 PM
    #318
    Patton250
    Brett
    Tampa Florida
    2021 Tacoma SR5
    Thank you but I can’t find it. I know you click on menu and then add display followed by what type of gauge you want then what color you want it when it comes to PID and I don’t know what to do from there because I can’t find it under PID. I bought the $9.99 Toyota expansion pack because others in this very thread said to get that. At this point in time I feel like an idiot.
  19. May 9, 2021 at 1:17 PM
    #319
    Lt. Dangle
    Ohio
    Don't feel bad, it takes some usage to figure it out.
    Open app
    go to dashboard
    click add display
    select whatever
    click on toyota, lexus, scion
    tap transmission
    scroll way down to "stautus of the shift stautus / 1,2,3,4,5,6,7, or 8th"
    click done
    should be there. I may be an idiot too, so...good luck lol.
    Topanga Taco likes this.
  20. May 9, 2021 at 1:20 PM
    #320
    Patton250
    Brett
    Tampa Florida
    2021 Tacoma SR5
    that’s where everything goes wrong. After your option of select whatever the next page I get is this picture below. I when I click on PID a massive list of options comes up. Transmission is not one of them nor shift status.
