OBDII location on an 08
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SILVER08, Dec 27, 2007.
  1. Dec 27, 2007 at 4:06 PM
    SILVER08
    SILVER08 [OP] Member
    08 TRD 4door
    I've tried the search function and checked the user manual and came up empty. So can someone please tell me where the OBDII is located. The reason is, i just purchased a ScangaugeII and need to know where the plug in is. Thank you.
  2. Dec 27, 2007 at 4:10 PM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    I'd search under your dash, by your left knee.
  3. Dec 27, 2007 at 10:26 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Yup! Or just behind (underneath) that little opening compartment. The OBD port will be covered with a black plastic cover - you'll have to take the cover off.
  4. Dec 28, 2007 at 3:21 PM
    SILVER08
    08 TRD 4door
    Found it, Thanks again guys.:D
  5. Nov 17, 2013 at 1:16 PM
    fortapache
    fortapache fortapache
    Bayfield, CO
    06 Tacoma 4x4
    It is under the dash, driver's side, left leg side, forward of and attached to the fuse box group on the steering column side, pointed down, black plastic rectangle cover over a trapezoidal shaped plug with two rows of connectors, almost directly above the parking brake pedal.
    This is on a 2006 Tacoma.
