OBDII port scanner
Discussion in '2nd Gen. Tacomas (2005-2015)' started by aaronb43, Aug 13, 2007.
  1. Aug 13, 2007 at 9:56 PM
    aaronb43
    aaronb43 [OP] Well-Known Member
    Edmonton AB Canada
    07 SR5
  2. Aug 13, 2007 at 10:05 PM
    LRH
    LRH Well-Known Member
    GA USA
    '07 2.7L PreRunner
    I think it is worth the money, about 70% as a tool, and 30% as a neat toy.
  3. Aug 13, 2007 at 11:39 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    Great little gadget!
  4. Aug 14, 2007 at 4:37 AM
    ZonKs
    ZonKs Can speak french in Russian.
    Ted
    Glendale, CA
    2018 Sport DCSB 4x4
    =p
    I love mine. Get it, its worth it.
    Ted
  5. Aug 14, 2007 at 2:11 PM
    stratton
    stratton Well-Known Member
    isnt that part of the group buy that we might do on here. i am hoping that it goes through. i want one too.
  6. Aug 14, 2007 at 5:20 PM
    LRH
    GA USA
    '07 2.7L PreRunner
    What is the current group buy price? I ordered mine from Amazon since I was getting some books. I ordered on a Tuesday night 06-19 about 10:00 pm or so and had it Thursday by noon,~ 38 hours later. never got anything that fast, and I am still waiting on the last 1 of the 6 books I ordered. Price was 159.95 total OTD which I believe was $5.00 higher than the group buy, which was over at that time.
  7. Aug 14, 2007 at 10:43 PM
    aaronb43
    Edmonton AB Canada
    07 SR5
    So, where did you (or where do you plan to) mount your scanners? The manufacturer suggests that, with the Tacoma, a great place to put it is on top of the steering column. Your thoughts?
  8. Aug 14, 2007 at 11:42 PM
    LRH
    GA USA
    '07 2.7L PreRunner
    Mine is on top of the column, w/velcro. Had to tilt/telescope column to allow viewing cluster. Looks a little out of place with the sharp 90º corners, wished it was rounded off a bit. Did remove it once to run and then clear code on wifes Trailblazer a couple weeks ago for a bad coil pack, now wish I had purchased extra cable, although it was pretty easy to remove cable. I ran cable from diagnostic port for about 8", then coiled up all but approx 2-2.5'. Removed flip open mini storage pocket and placed coiled up cable behind storage pocket door and ran remainder up and out of slot at top of column. and pluged it in. It does help to force a slight bend (mild kink) in cable to take the preload off the cable that wants to force the ScanGauge to tilt forward. Works great.............
  9. Aug 15, 2007 at 4:38 AM
    nd
    nd Radical Town. It's a hell of a place!
    Nate
    Greenville, SC
    07 TRD Off-Road 4x4 debadged
    De badged, 5100's, Black Toyota Baja wheels
    What exactlyl does this little gadget do that makes it so fun?
  10. Aug 15, 2007 at 4:41 AM
    ZonKs
    Ted
    Glendale, CA
    2018 Sport DCSB 4x4
    =p
    I velcroed mine inside that little tray below and to the right of the steering column. I like the factory look, so this works well. You can see the display through the bottom right cut out in the steering wheel. Out of plain sight and functional.
    Ted
  11. Dec 21, 2007 at 12:01 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
  12. Dec 21, 2007 at 12:47 PM
    piercedtiger
    piercedtiger Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
    OBDII code reader AND:
    -MPG
    -MPH (with correction for tire size)
    -RPM
    -Water temp
    -intake temp
    -throttle position
    -open/closed loop
    -engine load
    -daily trip
    -current trip (engine on to engine off)
    -"trips" include max rpm, max speed, avrg speed, avrg mpg, distance, gallons used
    -tank mpg, gallons used, gallons to empty, miles to empty
    As well as some custom "x-gauges" you can program in later for tranny temp, horsepower, etc.
    There's more, but you get the idea.
  13. Dec 21, 2007 at 1:52 PM
    maverick491
    maverick491 Towing Guru
    South Jersey
    07 4x4 Access Cab, TRD off road, 6 cyl, 6 spd
    Activator III brake controller, Extang Fulltilt toneau, Factory bed mat, Extra D-rings in the bed, 2ndary air filter removed, Garmin Ique GPS, Eco-2, AFE Pro Dry-s filter, USASPEC PA12-toy, Pioneer 3-way speakers, SG II on Blendmount, Gulf States Alarm added.
    I love mine. I have mounted mine above the rear-view mirror on something called a blendmount.
    I am 3/4th of the way through writing and formatting the DIY write-up with photos and instructions for it. It should be up and posted before Christmas.
    Phantom, are you sure it is slated to do 0-60 and 1/4 mile times? I've not heard of them writing the code for that. Perhaps you are confusing it with the dashhawk?
    We are supposed to be doing a group buy in the spring, though I don't know that the group buy will be a significant savings over the normal $159 including shipping price.
  14. Dec 21, 2007 at 3:47 PM
    piercedtiger
    Jon
    Southern Tier, NY
    3in1 posts on TN (he sells them). Horsepower is available now as well as some others. Tranny temp is too, or will be soon. I don't remember. He'll post them up on TN as soon as it's available. I have the old SG 1 so the X-Gauge codes are useless for me.
  15. Dec 23, 2007 at 10:54 AM
    piercedtiger
    Jon
    Southern Tier, NY
  16. Dec 26, 2007 at 6:26 PM
    vabchxrunner
    vabchxrunner Well-Known Member
    15 4Runner SR5 4X4
    Here is mine mounted, nice tool to have.
  17. Dec 27, 2007 at 8:34 AM
    jinxed
    jinxed New Member
    Phoenix, AZ
    06 Tacoma Prerunner SR5
    Scan Gauge.
    Looks good. I'm undecided as to where I should mount my Scan Gauge, but this looks nice. What did you use to mount it?
  18. Dec 27, 2007 at 10:09 AM
    vabchxrunner
    15 4Runner SR5 4X4
    i just used the velcro and attached it to the headliner. doesn't move at all and will not fall off. it will be fine as long as you don't take it off like 100 times.
  19. Dec 27, 2007 at 11:04 AM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    I have a DashHawk and I love it. It does everything the Scangauge does but then also offers 0-60 and 1/4 mile times. It is $300 new though. I picked up mine on ebay for about $180.
  20. Dec 27, 2007 at 11:51 AM
    piercedtiger
    Jon
    Southern Tier, NY
    That dashhawk, it's an OBDII reader as well? And can clear codes? I might have to keep an eye on eBay for one for the truck. (SG lives in the car now since it keeps throwing CEL's)
