October 2015 Citrus/Croom Camp & Ride Weekend...
Discussion in 'Florida' started by Taco No Baka, Aug 13, 2015.
  1. Oct 22, 2015 at 11:38 AM
    #1021
    Taco No Baka
    Taco No Baka [OP] Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
    Well, I did a brief inspection of the OGT's front end today. My inner tie rods (both sides) are definitely toast. My steering rack bushings and LCA bushings might be toast, or on their way out as well. Not really sure about the LCAs. I don't know how much movement is normal for them. Plus, I need to drop the skid to see the rear ones better.
    Also, I haven't identified the source of the clanking I was hearing going over bumps, but I have some suspicions relating to the skid plate. Kinda hope that's what it is because it will be a cheap fix.
    Rattletrap66 likes this.
  2. Oct 22, 2015 at 11:39 AM
    #1022
    mosquitoTaco
    mosquitoTaco Has an attractive member
    Anthony
    SouthTennessee
    14' DCSB offroadsport-sold =2005 T4R V8
    Bilstien 5100@ 0, OME 885(+10 mm drivers side spacer for taco lean, 5mm passenger), b110 rears w/ allpro standard leaf pack, wheelers ubolt flip, superbump bump stops, extended brake lines steal braided(front and rear), Dick Cepek extreme country 305/65/17 tires on FN six shooters=17x8, street tires are 285/75/16 duratrac w/FN countersteer type X= 16x8, a healthy cab mount chop, SPC LR UCA's, TC cam tab gussets, Wet okole seat covers, husky x-act fit floor liners, SOS aluminum front skid, SOS mid skid, SOS sliders (bolt on), ECGS bushing for needle bearing, uniden PRO520XL cb. BAMF tailgate antenna mount, 4' firestick, A.R.E. Z series camper top, Factory roof rack, Pioneer avh-5800x head unit. Front and rear anytime cameras, Rear diff. Breather relocate. 42" highlift. Tow straps/All-PRO snatch strap, tow hitch w/D-ring, traction pads, Tacoma bed mat, Rago Fab ditch light brackets with jap special light pods
    This is exciting
  3. Oct 22, 2015 at 11:40 AM
    #1023
    mosquitoTaco
    Anthony
    SouthTennessee
    This is no bueno. I hope you get it figured out
  4. Oct 22, 2015 at 11:41 AM
    #1024
    Rattletrap66
    Rattletrap66 (ノಠ益ಠ)ノ彡┻━┻
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    2014 TRD Off Road DCSB
    ╭∩╮(ಠ۝ಠ)╭∩╮
    Dang man well at least you can identify most of it, my skid was doing the same thing. Missing a bolt and all good
  5. Oct 22, 2015 at 11:48 AM
    #1025
    Tisa4runner14
    Tisa4runner14 Well-Known Member
    Tisa
    Spring Hill
    2014 4Runner 2x4
    For real. Trav and I both the whole time in the truck lol
    TAZ2014Taco likes this.
  6. Oct 22, 2015 at 11:50 AM
    #1026
    TAZ2014Taco
    TAZ2014Taco Well-Known Member
    Florida
    2019 Tacoma 3.5 SR5
    Haven't had Facebook in a couple years lol TW interests me, no petty drama and bs (well some) just trucks and all that
    mosquitoTaco likes this.
  7. Oct 22, 2015 at 11:54 AM
    #1027
    Taco No Baka
    Lee
    Tampa, FL
    Good for you. :thumbsup:
    Yeah, I may end up rebushing my whole front end. It'll be a lot of work, but at least the individual parts aren't terribly expensive, though they will add up. $20 per side for LCA bushings, $31 per side for tie rod ends, and I suspect steering rack bushings will be similar pricewise. May see about getting poly bushings for it since they are under a pretty big load with those Swampers and the Lincoln locked front diff. The biggest single expense is going to be the alignment afterwards.
    As far as the skid, I think I may have popped the welds on that mickey mouse factory cross-member that the front mounts to. That's what I'm hoping anyway.
  8. Oct 22, 2015 at 12:00 PM
    #1028
    TAZ2014Taco
    Florida
    2019 Tacoma 3.5 SR5
    Very nice!
    mosquitoTaco[QUOTED] likes this.
  9. Oct 22, 2015 at 1:59 PM
    #1029
    nammer
    nammer Well-Known Member
    Nam
    Bradenton, Florida
    Wishing I had a Taco
    lol, there are times, then like we get like 80 members watching, then it gets all :locked:
    TAZ2014Taco[QUOTED] likes this.
  10. Oct 22, 2015 at 2:00 PM
    #1030
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
  11. Oct 22, 2015 at 3:34 PM
    #1031
    6Speed_Reid
    6Speed_Reid Active Member
    Reid
    Webster, Florida
    2009 DCSB 6 Speed 4wd TRD Off Road
    6" Rough Country,Total Chaos UCAs,Donahoe Racing Coilovers,285/75/16 Toyo Open Country MTs,TRD short throw shifter,Pioneer Double-DIN,LED Concepts halos,BHLM,6000k HIDs, Spyder LED Tail lights.
    Lee, I have video of this but it's not the best quality because it was saved from Snapchat. I'll try to upload it.
  12. Oct 22, 2015 at 3:55 PM
    #1032
    6Speed_Reid
    Reid
    Webster, Florida
  13. Oct 22, 2015 at 4:04 PM
    #1033
    allenfab
    allenfab I hate everything
    Todd
    Lakeland, FL
    08 5-lug on one tons
    I put poly bushings on my tundra and they are worth every penny. It cured for the most part the issue I was having with it tracking to the right and it most definitely tightened up the steering.
  14. Oct 22, 2015 at 6:27 PM
    #1034
    Taco No Baka
    Lee
    Tampa, FL
    Thanks, Reid! :thumbsup:
    Cool. Sounds like that's the way I need to go then. :cool:
    6Speed_Reid[QUOTED] likes this.
  15. Oct 22, 2015 at 6:33 PM
    #1035
    6Speed_Reid
    Reid
    Webster, Florida
  16. Oct 25, 2015 at 6:26 PM
    #1036
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    @Taco No Baka , working on the footage now. Give me until Wednesday night o_O
    Taco No Baka[OP] likes this.
  17. Oct 25, 2015 at 8:08 PM
    #1037
    Timbo's Customs
    Timbo's Customs Well-Known Member
    Timothy
    Lakeland FL
    2019 f250 6”lift 37s deleted 1997 T4r, tons and 4ds
    1997 t4r has super duty axles, 5.13s locked front and rear. 3 link front with 14" kings. Rear 63s.
    Saw this on Facebook and thought about the ogt
  18. Oct 25, 2015 at 8:09 PM
    #1038
    Timbo's Customs
    Timothy
    Lakeland FL
    He will never be as cool as the ogt
  19. Oct 26, 2015 at 5:11 PM
    #1039
    Taco No Baka
    Lee
    Tampa, FL
    Haha, promises, promises. :rofl:
    :humble::wink: :cool:
    :cheers:
  20. Oct 28, 2015 at 5:10 PM
    #1040
    Taco No Baka
    Lee
    Tampa, FL
    :playball:
    :tumbleweed:
    :turtleride:
    :boink:
    :wave:
    Rattletrap66[QUOTED] likes this.
