October 2015 Citrus/Croom Camp & Ride Weekend...
Discussion in 'Florida' started by Taco No Baka, Aug 13, 2015.
  1. Nov 8, 2015 at 2:37 PM
    #1061
    Taco No Baka
    Taco No Baka [OP] Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
    I should have had you do it last time. Just didn't think about it. ;)
  2. Nov 8, 2015 at 2:44 PM
    #1062
    Rattletrap66
    Rattletrap66 (ノಠ益ಠ)ノ彡┻━┻
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    2014 TRD Off Road DCSB
    ╭∩╮(ಠ۝ಠ)╭∩╮
    funny you say that about getting winched out, guy in the jeep that tried it back in July tried winching himself out but didn't have any luck. Was digging himself more into the top vertical part and needed more of a lift to get up and over it
  3. Nov 8, 2015 at 2:51 PM
    #1063
    Taco No Baka
    Lee
    Tampa, FL
    I know a trick or two that would probably deal with it if someone has a snatch block. Just have to put a tree saver as high as you can get it on a decent-sized tree (usually by standing on someone's truck) and with the snatch block connected to the tree saver, it should give a high enough angle to pull over the top. The other trick is, just don't spin the wheels. Stick it in neutral and let the winch do the work. Not sure if all that would be enough, but I think as close as I was, I would have come out.
    Timbo's Customs likes this.
  4. Nov 8, 2015 at 3:54 PM
    #1064
    Timbo's Customs
    Timbo's Customs Well-Known Member
    Timothy
    Lakeland FL
    2019 f250 6”lift 37s deleted 1997 T4r, tons and 4ds
    1997 t4r has super duty axles, 5.13s locked front and rear. 3 link front with 14" kings. Rear 63s.
    I don't have a snatch block yet. I do have a tree saver
  5. Nov 8, 2015 at 8:18 PM
    #1065
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
  6. Nov 8, 2015 at 9:44 PM
    #1066
    mosquitoTaco
    mosquitoTaco Has an attractive member
    Anthony
    SouthTennessee
    14' DCSB offroadsport-sold =2005 T4R V8
    Bilstien 5100@ 0, OME 885(+10 mm drivers side spacer for taco lean, 5mm passenger), b110 rears w/ allpro standard leaf pack, wheelers ubolt flip, superbump bump stops, extended brake lines steal braided(front and rear), Dick Cepek extreme country 305/65/17 tires on FN six shooters=17x8, street tires are 285/75/16 duratrac w/FN countersteer type X= 16x8, a healthy cab mount chop, SPC LR UCA's, TC cam tab gussets, Wet okole seat covers, husky x-act fit floor liners, SOS aluminum front skid, SOS mid skid, SOS sliders (bolt on), ECGS bushing for needle bearing, uniden PRO520XL cb. BAMF tailgate antenna mount, 4' firestick, A.R.E. Z series camper top, Factory roof rack, Pioneer avh-5800x head unit. Front and rear anytime cameras, Rear diff. Breather relocate. 42" highlift. Tow straps/All-PRO snatch strap, tow hitch w/D-ring, traction pads, Tacoma bed mat, Rago Fab ditch light brackets with jap special light pods
    That video angle probably gives you the best idea how steep that is. Good job
  7. Nov 9, 2015 at 4:50 AM
    #1067
    Taco No Baka
    Lee
    Tampa, FL
    Somebody probably had a snatch block out there. :thumbsup:
  8. Nov 9, 2015 at 6:18 AM
    #1068
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    thanks!
  9. Nov 9, 2015 at 1:41 PM
    #1069
    allenfab
    allenfab I hate everything
    Todd
    Lakeland, FL
    08 5-lug on one tons
    I did :thumbsup:
  10. Nov 9, 2015 at 1:47 PM
    #1070
    Taco No Baka
    Lee
    Tampa, FL
    I thought maybe you did. I seem to recall you getting a big bag-o-winch accessories. :D
  11. Nov 9, 2015 at 3:09 PM
    #1071
    Taco No Baka
    Lee
    Tampa, FL
  12. Nov 9, 2015 at 3:19 PM
    #1072
    allenfab
    Todd
    Lakeland, FL
    TAZ2014Taco likes this.
  13. Nov 9, 2015 at 3:25 PM
    #1073
    Taco No Baka
    Lee
    Tampa, FL
    I'm pretty sure you could get it however you want it. Says it comes in standard or custom lengths and you can specify your desired castor and pinion angles. I doubt they'd have a problem leaving the brackets off. Less work for them and they might even give you a break price-wise, though it probably wouldn't be much. Especially since they probably want it's weight in gold for the axle to begin with, haha.
  14. Nov 9, 2015 at 4:16 PM
    #1074
    allenfab
    Todd
    Lakeland, FL
    Oh they do, I've priced them before for my old tundra. But in reality, after you buy an old axle and build it up with all the good stuff (like in my case), the price difference really isn't too bad. And knowing you're getting a brand new, not bent axle built with modern day equipment and technology is a big pro with buying brand new.
  15. Nov 9, 2015 at 4:45 PM
    #1075
    Taco No Baka
    Lee
    Tampa, FL
    Just out of curiosity, how much do they get for them? I'm guessing the axle would probably be worth more than my truck by probably half again. :eek:
  16. Nov 9, 2015 at 4:54 PM
    #1076
    allenfab
    Todd
    Lakeland, FL
    I don't recall, it was 8 years ago when I priced one. And I think I priced a 60 and not a 44..... Hell I don't remember haha
  17. Dec 16, 2015 at 7:39 PM
    #1077
    mosquitoTaco
    Anthony
    SouthTennessee
  18. Dec 16, 2015 at 7:48 PM
    #1078
    michaelrussell
    michaelrussell Well-Known Member
    Michael
    belleview,FL
    09 prerunner sr5 2.7 / 5 speed
    lots of stuff done more to do
  19. Dec 16, 2015 at 9:00 PM
    #1079
    mosquitoTaco
    Anthony
    SouthTennessee
