Odd noise from a 2007 Tacoma?
Discussion in 'Technical Chat' started by foofighter, Dec 18, 2007.
  1. Dec 18, 2007 at 1:37 PM
    foofighter
    foofighter [OP] New Member
    Hello,
    I have a 2007 Tacoma with an automatic transmission (double cab, long bed). Since new, it has made a growling sound from the drive train when driving at low RPM. It seems to do it worse when the car is cold. I thought maybe it was something that might go away as parts wore in, but 3,000 miles later it's still doing it. Has anyone had the same experience, or know what this might be? I'm just wondering if it's something that they all do? I haven't asked the dealer's opinion on it yet.
    Thanks!
  2. Dec 18, 2007 at 1:45 PM
    dirthawker1313
    dirthawker1313 Well-Known Member
    i would take it to the dealer and have them check it out. its free so it cant hurt IMHO
  3. Dec 18, 2007 at 5:24 PM
    concrete jedi
    concrete jedi Well-Known Member
    Rochester N.Y
    06 Tacoma 4 door indigo blue
    Broken and scratched tailgate, cracked rear tail light lens, coffee stain in driver seat.
    Dirthawker1313 is right, this sounds like a dealer issue, but to confirm that you are correct is to drive a new one somewhere else. :evil:
  4. Dec 18, 2007 at 5:28 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Is it a 'growl' or more like a 'whine'?
    So - you know it's engine related (rpm related)?
    Mine used to whine a bit but has quieted down since I did the first oil change using synthetic oil. Every once in a while I hear it...but not often.
  5. Dec 18, 2007 at 5:35 PM
    TheMaster
    TheMaster Born to Ride
    Chicky Baby
    NY
    2007 DC TRD Sport
    Bug shield, window visors, skid plate, rust proofing, tonneau cover, paint & upholstery protection, side step bars, navigation system.
    Yeah, its best you create a service history on this issue just in case it comes to haunt you later. Later meaning, when your warranty expires.
  6. Dec 18, 2007 at 11:56 PM
    foofighter
    Yeah, it's a growl. It happens when the engine is at low RPM and the car is moving. I'm going to have it looked at, I was just wondering if it was something that others had experienced. Thanks for the input.
  7. Dec 19, 2007 at 6:07 AM
    argm31i
    argm31i Well-Known Member
    I'd definitely take it to the dealer to create a paper trail for this one at least. At least that way, even if they don't have a fix, you'll know when it started (as will they) and they can maybe fit you under the warranty even if the noise doesn't cause catastrophic failure until after the warranty is out.
