odd problem when driving-electrical shutdown
Discussion in '2nd Gen. Tacomas (2005-2015)' started by beanzfrd, Dec 25, 2011.
  1. Dec 25, 2011 at 5:02 PM
    beanzfrd
    beanzfrd [OP] New Member
    nashville
    05 tacoma sr5 trd
    this has happened a couple of times,wonder if someone has had the same problem,driving on the highway approx.70 to75,really doesn`t matter what speed,but all of a sudden all electrial power to gauges and motor shut down for approx. 1 second or so and then start up again,this may happen several times and then all is well,2005, v6,6 speed with around 98000 miles.maybe a relay going bad? would welcome the input.
  2. Dec 25, 2011 at 5:04 PM
    Panther
    Panther Well-Known Member
    Kaiden
    BH, ME & BOS, MA
    2021 TRD Sport DCLB
    OEM lift. Ditch lights
    I'd get your alternator checked.
  3. Dec 25, 2011 at 5:04 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Is the battery original? Those things last about 5 years.
  4. Dec 25, 2011 at 5:05 PM
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    Sounds like a loose main ground. Check your battery terminals and grounding points.
  5. Dec 25, 2011 at 5:06 PM
    Hughesc99
    Hughesc99 Well-Known Member
    Derby, KS
    Possibly a ground or alternator. I had an alternator go bad on me and it did something similar. If your battery dies then thats probably it.
  6. Dec 25, 2011 at 5:40 PM
    beanzfrd
    nashville
    05 tacoma sr5 trd
    thanks everyone,but no weak or dead battery,gound is tight,i thought maybe there is an ignition relay going bad,gound for battery to body is tight
  7. Dec 25, 2011 at 5:44 PM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    This ^ or you have a short somewhere.
  8. Dec 25, 2011 at 7:32 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Can you induce the problem by jiggling the ignition key? Sounds like bad ignition switch or something pretty early in the electrical line from the battery. I would start the truck up and start wiggling wiring harnesses and fuses in the fuse blockl
  9. Dec 25, 2011 at 7:40 PM
    beanzfrd
    nashville
    05 tacoma sr5 trd
    thanks joe,i`ll give a shot
  10. Dec 25, 2011 at 8:10 PM
    T-Rex266
    T-Rex266 Moderator Moderator
    Elon
    Agree on the loose ground. Keep us updated
  11. Dec 25, 2011 at 8:24 PM
    ziggynagy
    ziggynagy All Glory To The Hypnotoad
    Stoughton, MA
    '11 Sport AC 4x4 V6 Auto Tow
    Westin step bars, led dome & map lights, tailgate hoseclamp, BluLogic, MetalMiller emblem, 35 tinted front windows, extra OEM d-rings, WeatherTech front/rear
    Had the exact same thing happen in my old 2000 kia... All electrical wires would blink and gauges would drop to zero then pop back up after a second or two. After checking the battery, terminal connections, etc i ended up replacing the alternator to fix.
  12. Dec 25, 2011 at 8:36 PM
    Bloodhound
    Bloodhound Banned from the Pics Thread
    Greg
    East Moline, IL
    '10 TRD O/R DBL-CAB
    Floor-mats, Running Boards, Shorty Antenna, AFE Pro Dry Air Filter, AVS In-Channel VentVisors, Beer cans in the bed
    Same here, actually on a Mazda 6 (2003) and the voltage regulator was causing the gauges to die and come back on with all kinds of fault codes. Not sure, but I thing most voltage regulators are piggybacked onto the alternator nowadays. I'd have that checked out at Pep Boys, Auto Zone, O'reilly or whatever you have close by.
  13. Dec 25, 2011 at 8:45 PM
    moto932
    moto932 What's the matter, Colonel Sandurz? CHICKEN?
    Eric
    Dayton, Ohio
    04 TRD Off Road
    Basically stock. OME 882s, HD Dakars and nitrochrgers, TG front bumper, custom rear bumper, 4Xinnovations sliders, RAT skids, Softopper, 255/85/16 ST MAXX's on 16" steelies, 1" B.O.R.A. wheel spacers Scangaugae II, deck plate mod, grey wire mod,ECGS bushing, diff breather relocation, alarm mod, defrost w/o compressor mod, de-badged, sockmonkey beside decals.
    ^^^this. just had this problem on a cavalier. an attachment point for a ground wire coming the the engine block to the battery tray had rusted off. find out were all the grounds go and make sure the are getting a good connection. good luck
