Odd tsb question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Frostbyte, Apr 4, 2011.
  1. Apr 4, 2011 at 7:13 AM
    Frostbyte
    Frostbyte [OP] Well-Known Member
    Northern Utah
    03 Black SR5 4x4 TRD Off Road
    RIP - 07 Radiant Red SR5 4x4 TRD Sport Fabtech 6" lift, 33x12.50.18 Toyo M/T on All black XD Hoss wheels
    Hey all, i bought my truck used, with a spacer leveling kit already on it, which im gonna remove and put billys on. I want to also get the rear tsb done as well, but im not sure if it has already been done, so how do i tell if it has been done or not?
    -Erik
  2. Apr 4, 2011 at 7:43 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    You can't get the TSB done if you are outside of the 3 year, 36k miles warranty.
    Just buy an add-a-leaf for $75.
  3. Apr 4, 2011 at 11:30 AM
    Frostbyte
    Northern Utah
    interesting, i thought that they had just opened it to all years it pertained to...
  4. Apr 4, 2011 at 11:34 AM
    Frostbyte
    Northern Utah
    i know a lot of people who have done the tsb, also get another leaf to add to the tsb, so would i need to add a leaf, and then another leaf to make up for not being able to get the tsb leaf? does that make sense... or am i putting too much thought behind this?
  5. Apr 4, 2011 at 11:42 AM
    KPT
    09 Prerunner
    The folks who add a leaf to the TSB are using the 1.5" Toytec AAL for TSB.
    If you want roughly the same amount of lift as them, you could get a 2" or 2.5" AAL instead.
  6. Apr 4, 2011 at 11:44 AM
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    Is that the only reason for AAL's? or don't they also do it to add load carrying?
  7. Apr 4, 2011 at 12:19 PM
    KPT
    09 Prerunner
    Not technically, because the specified payload capacity of the truck also depends on how much load the shocks were designed to dampen, how much the composite bed is meant to hold, and how much additional weight the tires are rated for, etc.
    That being said, if you stiffen up the rear with an AAL, it will take more weight to bottom the truck out than before.
  8. Apr 4, 2011 at 3:28 PM
    buddywh1
    Philly PA
    07 DC SR5 4x4
    I understand that of course, but I also think it's pretty well known the weakest link in the Tacoma are the leaf packs. So much so that beefing them improves the trucks ability to carry loads at rated capacity, without sagging and bottoming.
  9. Apr 4, 2011 at 7:16 PM
    KPT
    09 Prerunner
    Correct the stock leaf pack is quite weak. I just didn't want to suggest that after you get the TSB, that putting an add-a-leaf in will increase the payload capacity above the advertised weight.
