ODO reading...
Discussion in 'Wheels & Tires' started by bt08231, Nov 22, 2011.
  1. Nov 22, 2011 at 5:16 PM
    bt08231
    bt08231 [OP] Well-Known Member
    Baltimore, MD
    09 Magnetic Grey SR5
    Stock
    swapping up from 245/75 to 265/75, does this effect the odometer reading? Am i travelling farther than it says? or is that increase in size negligable.....advice? Thanks
  2. Nov 22, 2011 at 6:30 PM
    wolftree
    wolftree Well-Known Member
    Rick
    Ohio
    2011 Tacoma 4x4 Regular cab automatic trans,
    Rear Leaf TSB, Bilstein 5100s, extra leaf added
    You will have a difference in odometer readings yes. I went with 265X70-16 for that reason. They are almost identical in height with the 245s. Use the "Tire Size Calculator" at the bottom of this page/screen to compare. The calculator gives percentages in difference and height.
  3. Nov 23, 2011 at 11:00 AM
    bt08231
    Baltimore, MD
    Stock
    thanks for the reply, i tried that calculator, i am still unclear as to what percentage i need to add to the total amount of miles driven before i divide by gallons used to check gas milage.....make sence???
  4. Nov 23, 2011 at 12:12 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Stock odometer/speedometer reads too fast/ more miles per gallon than real.
    My stock size was 265/70-16 and the speedometer said 70 when I was going 67. I got 16.5 mpg around town.
    My new size is 1" taller: 265/75-16 and my speedometer is now right on 70 at 70. I now get 15.5 mpg around town! But, that is real...
