Odor from 07 A/C
Discussion in 'Technical Chat' started by kngharley, Mar 16, 2007.
  1. Mar 16, 2007 at 5:17 AM
    kngharley
    kngharley [OP] Well-Known Member
    Corona, Ca
    I have an 07 double cab TRD Sport. I bought it with 18 miles on it. Ever since the day I got it, it has had a very sour smell coming from the A/C. If you turn the air flow to outside air (not A/C) there is no smell. I now have 5,000 miles on it. I have taken it to the dealer on two seperate occasions and they are telling me that they can't "replicate" the issue. Then when I leave the dealer it happens again. Does anyone have the same issue?
  2. Mar 16, 2007 at 5:38 AM
    LovinMyTaco07
    LovinMyTaco07 Well-Known Member
    I haven't experienced that. I would come to the dealer with the A/C running, leave it running and get the mechanic and watch him smell and if can't smell anything then I'll find an employ without a stuffed up nose, until I get to the manager if needed...
  3. Mar 27, 2007 at 7:44 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    I had the same thing on my 2006. It was October when I bought mine and it was months before I tried the A/C. For some reason I didn't get the odor from the defroster; only from the vents with the A/C on.
    The first time I used the A/C in the Spring it choked me. I thought it was another vehicle but I didn't recognize the smell. (not brakes, oil, antifreeze, etc.) Still can't tell you what the source was but it eventually went away. I'd drive with the windows open and the A/C on just to blow out the system, and these days I don't have the problem.
    Good news: You're not the only one and it does eventually go away.
    Bad news: The cause is still a mystery.
  4. Mar 27, 2007 at 2:44 PM
    kngharley
    Corona, Ca
    I bought mine in October of 2006 as well. I live in Southern California and you have the A/C on almost every day. I still have the odor after trying to "air it out". I went as far as to remove the cabin filter, spray fabreeze into the filter and the ducts. It is almost like a vinegar smell only not as strong kinda like silicone. Any other suggestions to rid the problem would greatly be appreciated. Craig
  5. Mar 28, 2007 at 6:53 AM
    mjp2
    NJ
    Hrmm...I actually picked mine up in October 2005. Weird that Toyota would have the same issue on 2 random trucks a year apart. The smell you describe sounds like the same symptom.
    AFAIK, the air comes in through the cowl at the base of the windshield. Have you run your truck through a drive-through car wash yet? Now that I think of it it's possible that the smell went away after going through one of those automated car washes and flushing out the cowl.
    Of course, if that was the source it doesn't make sense that the smell doesn't appear without the A/C on. I'm grasping at straws here.
    Good luck finding a solution, and if/when you do, please post it. That'll be some good information.
  6. Oct 14, 2008 at 1:38 PM
    sockmonkey
    sockmonkey Well-Known Member
    Greg
    Benbrook, SW Fort Worth
    2007 White Dbl Cab Pre-Runner
    Volant Ram Air intake,URD MAF calibrator, Mr Marv 10" sub box, Alpine HU, Alpine Amp, fog light mod, scan gauge II, RAAMmat front and rear doors, Wet Okole seat covers, blacked out dash. blacked out front bumper. American Racing Mojave Teflons wrapped with 265/70/16 Pathfinder AT. NST Lite Pulleys
    pulling out an old thread, here
    i am getting a strange smell from my 07 vents as well.
    it started out as a canned peaches smell...as i was told by my kids.
    not too unpleasant.
    then it started to turn to a musty smell.
    it does not matter whether A/C is on or venting from inside or outside.
    it is almost as though some water had pooled up somewhere.
    definitely coming from vents.
    and only when fan is turned on (does not smell funny when air coming through vents without fan on).
    FWIW: truck is kept garaged
  7. Oct 14, 2008 at 1:41 PM
    mjp2
    NJ
    "Musty" is an excellent description. Possibly related, I had to recharge my A/C system recently. Possibly a slow leak in the system that gets into the ductwork?
  8. Oct 14, 2008 at 2:09 PM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    There is a product called Frigi-fresh from BG products that you spray into the ac air intake while the ac is on. It works very well. Also, try turning off your ac about a minute before you get home so the cool air is blown out of the system. The cool air creates moisture in the system which in turn causes mildew and odor. This seems to work on all of my cars. Just a thought.
  9. Oct 14, 2008 at 2:16 PM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    +1. This is exactly what happens.
  10. Oct 14, 2008 at 3:16 PM
    sockmonkey
    Greg
    will try
    makes sence :cool:
  11. Mar 10, 2009 at 6:20 PM
    genxer36
    genxer36 Lord of Tomfoolery
    Sean
    Bethlehem,GA
    Tow package, XM Satellite radio, K & N Air filter, & Channel Vent Visors
    I know this is an old post. But just for anyone searching for an answer, going forward.
    I had the same problem with the musty smell. I had the dealer do an A/C cleaning. Paid about $35. They inject a cleaner into the A/C system. The musty smell is from mold & bacteria. I had it done in 06 for my 05. And I haven't had a problem since.
  12. Dec 25, 2012 at 5:50 PM
    dadeo131
    dadeo131 New Member
    Debi
    Washington
    2011 Tacoma Tracy cab
    My 2011 Tacoma has a foul sour can't describe smell coming out of defroster! Usually after it has not been driven for a while when the fan gets turned on! You can kinda smell it when it's not running! Any one clues to what this is! I noticed first in the summer now in the cool wet winter! Only 19500 miles and its bugging me!
  13. Dec 25, 2012 at 5:56 PM
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    I haven't had this problem,but my wife did in her old Camry. She would leave everything on when turning key off. I told her its good practice to shut things down before. I always turn ac off and then turn fan off before turning key off. Like I said , I haven't experienced this yet in 39k miles.
  14. Dec 26, 2012 at 2:53 PM
    dadeo131
    dadeo131 New Member
    Debi
    Washington
    Thanks kolunatic, I usually always shut everything off as well. but will make sure. Seems like if I drive regularly its fine, its only after sitting a while like when I go on vacation a while!
    Thanks!
  15. Dec 26, 2012 at 3:05 PM
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    Use of ozium inside with air on recirculate,idle for.awhile. see what that does. Also check cabin filter if ya have one.
  16. Dec 26, 2012 at 5:41 PM
    Failure2Comply
    Failure2Comply Old HVACR Tech
    Virginia, USA
    05 Access Off Road TRD/SR5
    This is known as "Dirty Sock Syndrome" usually caused by mold and bacteria growing on the evaporator coil and duct lining. As mentioned above his dealer "fogged" the duct system with an antimicrobial agent to kill the source. Home units with easier access can be chemically cleaned fairly easily and there are companies that specialize in duct fogging.
    http://www.achrnews.com/articles/a-new-solution-found-for-dirty-sock-syndrome
    http://www.foxservice.com/austin/kn...nditioning & Heating &_filterField=Categories
    http://www.rsandrews.com/blog/do-you-have-dirty-sock-syndrome/
  17. Dec 27, 2012 at 1:08 PM
    dadeo131
    dadeo131 New Member
    Debi
    Washington
    I popped the hood and did find leaves in the cowl and removed them and cleaned the area. today there was no smell, so may it draws in the smell from the outside vents?? Hoping this is the cure!
  18. Dec 27, 2012 at 1:20 PM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    Bingo!
    I used a product similar to that in prior cars. It cleans the evaporator coil and drain tube and gets rid of the 'funk' smell and will last for a long while.
