OEM 17” 4Runner wheels on my 2013?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bigezee, Feb 5, 2024.
  1. Feb 7, 2024 at 5:57 AM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Go to RockAuto and get the Denso ones from there. Or search Amazon for the Denso part number I posted above, but you may get counterfeits. I wouldn't buy parts from Amazon or eBay unless the seller is a Toyota dealership.
    Bigezee[OP] likes this.
  2. Feb 7, 2024 at 1:12 PM
    Bigezee
    Bigezee [OP] Well-Known Member
    2013 Toyota Tacoma V6
    Got the wheels! Perfect condition. 300 bucks. Gonna order those sensors like you said.
  3. Feb 7, 2024 at 8:19 PM
    Vance4
    Vance4 Member
    You will add 1" ride height which means less tire clearance. I have the same on my 2013. They had 265/70 on them when I got them. They rubbed. I ended up changing to a set of 245/75 that I had laying around. Now they are perfect. Good luck.
  4. Feb 8, 2024 at 5:53 AM
    Bigezee
    going to get quotes today for tires. Don't want rubbing so thanks for that info. Don't plan on lifting this and just want the stock look.
  5. Feb 8, 2024 at 6:10 AM
    Agoldxj
    Agoldxj Well-Known Member
    James
    Central Pa
    2009 SWB AC
    Don’t forget new lug nuts, they are different than the steel wheel lugs.
    Bigezee[QUOTED][OP] likes this.
  6. Feb 8, 2024 at 6:28 AM
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    Stock tire size on a Tacoma with 17" rims is 265/65R17 (TRD Sport). The 265/70R17 size is only slightly larger, only adds 1/2" and shouldn't rub, but the 4Runner rims may have a different offset than the TRD Sport rims. Personally, I'd go with 265/65R17.
  7. Feb 8, 2024 at 8:36 AM
    Bigezee
    Yes i will have to get new lugnuts and new tpms sensors. The current sensors in these steel wheels are shot and needed replaced anyways.
