OEM 2014 Tacoma Navigation Radio
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by FLTrucks, Oct 14, 2013.
  1. Feb 23, 2014 at 4:10 PM
    #341
    RonCarver
    RonCarver New Member
    Ron
    Pocono Mts. Penn.
    2014 Tacoma Sport
    Tow package
    I just joined TacomaWorld today and have the same problem I have seen so many others talking about. My new Tacoma (off the lot a week ago) came with an Entune Audio plus and I didn't know it did not have nav and Apps until I got it home and started setting things up. I went back to the dealer and told them I was disappointed and asked them to upgrade me so I would have the Navigation also. They told me there was no upgrade because they must be installed at the factory.
    I can see in the posts that this is not true. Does anyone know how I can acquire an Entone Premium audio system that I can install myself?
    You got a really good deal on your system and I'm glad it is working fine.
    Thank you....RonCarver
  2. Feb 24, 2014 at 1:34 PM
    #342
    mbray
    mbray Well-Known Member
    Regina, Canada
    '14 4x4 TRD Sport
    JBL Entune Conversion, BHLM, Heated & Auto-dimming mirrors
    As far as I no... There is little or no difference.
    But....
    Your speakers will always sound a lot better than the stock system if it's powered properly. I've amped my stock unit (2013) and factory speakers
    It sounds a lot cleaner and I'm definitely happy with just the 4ch amp
  3. Feb 25, 2014 at 11:38 AM
    #343
    tail07
    tail07 Member
    Todd
    IL
    14 Tacoma Sport 4X4
    OEM Nav Head unit
    I just installed the navigation unit and it works flawlessly! Thank you!
  4. Feb 27, 2014 at 2:31 PM
    #344
    fbconvert
    fbconvert Well-Known Member
    Brian
    Seacoast, NH
    2005 Tacoma Double Cab TRD Sport
    Just got my nav unit in a the mail. Everything was plug and play into the 2013 (after I fixed the wiring). I was a little bummed that it didn't come with an SD card. I looked it up and that sucker is not cheap.
  5. Feb 27, 2014 at 3:33 PM
    #345
    Xtremewelder
    Xtremewelder Well-Known Member
    Marc
    Newport, Oreogn
    2014 DC trd sport
    Gentex mirror,ARE cap, LED lights
    Mine was in the unit installed already, I think its included.
  6. Feb 27, 2014 at 3:36 PM
    #346
    fbconvert
    Brian
    Seacoast, NH
    I had another member tell me that... I sent FLTruks a PM, I am hoping its just a mistake. Everything was package real nice but it was odd, the SD card cover on the radio was removed and just loose in the box.
  7. Feb 27, 2014 at 6:24 PM
    #347
    Xtremewelder
    Marc
    Newport, Oreogn
    2014 DC trd sport
    I would say a mistake, he's really good but super busy. Takes a while to get back to you.
  8. Feb 28, 2014 at 10:18 AM
    #348
    fbconvert
    Brian
    Seacoast, NH
    I would check your plug to your clock/hazard light assembly under the radio. If its disconnected, connect it. If the light still doesn't turn on check out this .pdf (ignore the last two pages, just follow the instruction to read and clears the error code. My guess is you are getting error code 45 which is a malfunction in the passenger airbag indicator light.
    Edit: Sorry I read your post too fast I understood it as your airbag warning light was on in your dash... Not sure if what I said above will help you. The only think I can thing that would keep it on is maybe some tool or your old stereo is on your seat and the system is sensing that as a person being there. I'm not sure on the weight limit but I bet it's pretty sensitive.
  9. Feb 28, 2014 at 10:31 AM
    #349
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    If it's the actually light that lights up the word "airbag" that's normal...
    If it says "ON" then the system might be thinking something is on your passenger seat
  10. Feb 28, 2014 at 10:55 AM
    #350
    mbray
    Regina, Canada
    '14 4x4 TRD Sport
    This is correct. "AIRBAG" is always lit, regardless of occupancy.
  11. Feb 28, 2014 at 1:06 PM
    #351
    warriors_03
    warriors_03 Active Member
    Mark
    San Marcos
    2012 Tacoma DCLB Sport 4x4
    The airbag light in the gauge cluster shouldn't be lit all the time. Only the actual "Airbag" word under the radio.
  12. Feb 28, 2014 at 1:09 PM
    #352
    Jerez
    Rod
    Ontario Ranch
    Estock
    awesome glad you got it figured out :thumbsup:
    Yea he's talking about the pass airbag
  13. Mar 1, 2014 at 4:52 AM
    #353
    Fourspeedsteve
    Fourspeedsteve Active Member
    Indiana
    SR AC 2.7L 4x4 Gearbanger
    I got mine from FLTrucks on 2/27, and have the same issue. Installed in my '14 with base radio and everything worked perfect, except the NAV since I didn't get an SD card. The cover was open for the memory card when I unpacked the unit from the box, with no card installed. Checked inside the box for it loose and no luck. PM'd FL and awaiting response. Otherwise very happy and shipped quickly after payment!
  14. Mar 1, 2014 at 5:50 AM
    #354
    JustinL
    JustinL Well-Known Member
    Justin
    Berlin, CT
    2009 TRD OffRoad DCSB Pyrite Mica
    2012 Conversion
    Wonder if anyone that has the map SD card can simply copy it and zip the files online
  15. Mar 1, 2014 at 6:59 AM
    #355
    fbconvert
    Brian
    Seacoast, NH
    FLrucks responded to me yesterday. I just confirmed my address with him again. I hope to get my card soon. I too am very happy with everything. I think this is an outstanding deal even if I need to wait a few more days for the SD card. If my aftermarket adapter will make this work with a 2005 Jbl system I'm going to order another one for my truck.
  16. Mar 1, 2014 at 2:24 PM
    #356
    Trubes99
    Trubes99 New Member
    Endicott, NY
    13 Tacoma TRD Sport
  17. Mar 2, 2014 at 9:00 AM
    #357
    tedstrat
    tedstrat Member
    Ted
    Long Island NY
    Coming soon
    FLTrucks....please add me to the list. Just ordered 14 off road - nav not part of that package apparently. Would like to purchase. Thx
  18. Mar 2, 2014 at 10:01 AM
    #358
    fbconvert
    Brian
    Seacoast, NH
    If you installed this nav unit in your 2013 and want to add the Vice switch, I took some pictures (here) of how I got it to work. I think just buying the controls is still probably the best option for most though.
  19. Mar 2, 2014 at 10:40 AM
    #359
    Fourspeedsteve
    Indiana
    I heard back from FLTrucks yesterday as well, and should be getting a card too. Should be all good when it arrives!
  20. Mar 2, 2014 at 12:54 PM
    #360
    steveo27
    steveo27 Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    Where are you guys getting the VINs to run the Etunes apps?
