OEM ball joints
Discussion in '1st Gen. Tacomas (1995-2004)' started by Timmythetacoma, Jul 29, 2020.
  1. Jul 31, 2020 at 9:29 AM
    eon_blue
    Azusa, CA
    The recall only applied to a few 1st gens of the 2001+ years, it was a relatively small bad batch that triggered the recall. I have a 2004 and my truck was not part of it, most people weren't. I wouldn't be too upset about it
  2. Jul 31, 2020 at 8:11 PM
    JJ04TACO
    JJ04TACO Well-Known Member
    Jim
    Dallas
    04 White DC/TRD
    Fox 2.5 RR front, 2.0 RR rear from AccuTune Offroad, OME Dakar Leafs, Camburg Uniball UCA's, CBI Offroad Bolt on Sliders w/kickout, Scangauge II Uniden Bearcat 880 w/ 3' Firestick on CBI antenna mount B&M Trans Cooler
    https://www.toyotaofdallas.com/parts/shop.htm?path=/v-2004-toyota-tacoma--base--3-4l-v6-gas/front-suspension--front-suspension
    It's true about pricing. Toyota Dallas are $101 and $126 for the L and R LBJ's.
    But if you have local free pick up then you still save the shipping...
  3. Aug 30, 2020 at 8:24 PM
    Brahms
    Brahms Well-Known Member
    Houston, TX
    2004 Tacoma DCSB 4x4 SR5 V6 TRD
    Does the set 04005-03235 also include the castle nut and cotter pin?
  4. Aug 30, 2020 at 9:41 PM
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    It does, yes.
    Jeff
    Brahms likes this.
  5. Aug 30, 2020 at 10:07 PM
    Brahms
    Houston, TX
    Thank you, that was a helpful tip that saved me $40
  6. Oct 30, 2020 at 8:30 AM
    BubbaTaco324
    BubbaTaco324 Active Member
    97 Tacoma 4x4 3.4L
    I'm
    I'm curious why 95-00 and 01-04 have different LBJ part numbers and the kit 04005-03235 was made for 01-04 but you say it'll work for 95-04. Shouldn't this info exclude 95-00 from this LBJ assembly?
  7. Oct 30, 2020 at 8:32 AM
    Jeff Lange
    Calgary, Canada
    Toyota updated the ball joints in 2001 and changed the design slightly. The new design can be used on older trucks as well, but the older style of ball joints are still available as well.
    Jeff
  8. Oct 30, 2020 at 9:09 AM
    eon_blue
    Azusa, CA
    01-04 uses the dust boot around the ball joint and the '95-00 does not, that's one difference. However it has it's own part number. As far as I know the actual ball joint itself works across all years.
  9. Oct 30, 2020 at 9:14 AM
    Xbeaus
    Xbeaus Well-Known Member
    Beau
    Black hills South dakota
    98 Tacoma 3.4 5 speed SR5 limited TRD 4x4
    Toytec coilovers. Height adjustable Bilstein's. 265/75/16 MT. TRD wheels. Rebuilt r150f. Marlin clutch kit. All kinds of new parts...
    My local dealer acts like they dont' have time for peasants that own a first gen. My price was about $250 each. Got them from camelback where they actually help the guy who likes his old Toyota. lol It does help to shop around for parts. They say to support your local businesses but when they gouge you because they are greedy they can go F themselves. lol There is my ball joint rant for today and you got a pretty good deal on those for sure.
    Black97v6MT likes this.
  10. Nov 5, 2020 at 1:54 PM
    BubbaTaco324
    97 Tacoma 4x4 3.4L
    I ordered this LBJ kit 04005-03235 and I've run into a snag. The driver side fits fine but the passenger side LBJ has a smaller hole for the tie rod; 20mm driver side, 17mm passenger side.
    I would say this kit is not right for older Tacomas or I received the wrong passenger LBJ somehow.
  11. Nov 5, 2020 at 2:03 PM
    eon_blue
    Azusa, CA
    I'm fairly certain the 3rd gen 4runners have an almost identical LBJ to us but the tie rod is slightly different, I wonder if they sent you a 4runner one by mistake
  12. Nov 5, 2020 at 4:54 PM
    Jeff Lange
    Calgary, Canada
    04005-03235 is a kit that comes with ball joints for both sides of a single vehicle.
    I can think of zero Toyotas that use a 17mm tie rod on one side and a 20mm tie rod on the other side. It's obvious the kit you received had the wrong ball joint in it, lol.
    Jeff
  13. Jul 2, 2024 at 11:47 AM
    CenCalWheeler
    CenCalWheeler Well-Known Member
    2003 Toyota Tacoma TRD
    None yet
    I don’t mean to resurrect an old thread, but I’ve recently acquired a 2003 TRD Off-Road. It had its ball joints replaced during the recall in 2006. Considering the truck has been driven over 100,000 miles since then—albeit mostly on streets—I’m contemplating whether I should replace them again as a safety measure.
  14. Jul 2, 2024 at 12:37 PM
    ciaman96
    ciaman96 Well-Known Member
    Tucson
    2001 Reg Cab Tacoma 4x4
    OME Lift, E-locker, interior swap
    They’re probably about due by now. I have 1st hand experience with a friend who’s passenger side BJ let go at about 5mph and caused a decent bit of damage, so I’m always on the conservative side.
    For about $300 and an alignment, it’s cheap insurance in my books.
    Truckstop13 likes this.
  15. Jul 2, 2024 at 12:54 PM
    #35
    CenCalWheeler
    None yet
    Sounds like I should go for it then. Honestly, not worth living in fear that I am going to loose one going 75 miles an hour down the freeway...
  16. Jul 2, 2024 at 1:50 PM
    #36
    eon_blue
    Azusa, CA
    if it makes you feel a bit better, most LBJ failures happen at low speeds during tight turns. Which is why you see so many of them happening in parking lots or turning into driveways.
    or maybe all the freeway failures just never lived to tell the tale :eek:
    Its worth the peace of mind though indeed
    ciaman96, Truckstop13 and Pbfender15 like this.
  17. Jul 2, 2024 at 2:51 PM
    #37
    Truckstop13
    Truckstop13 Well-Known Member
    Los Angeles
    1999 Red TRD Off Road SR5 Extra Cab 4X4
    TRD Supercharger, headers, Cold air intake, MagnaFlow exhaust, ARB front bumper, Kennesaw Mtn rear w/ tire mnt, OME suspension with beefed up rear springs with 2 1/2” lift, 285/75/16 tires, Shell, Contractors rack, Road shower and 120v inverter in cab.
    It’s too easy and affordable not too, in my opinion. $400 with alignment is a no brainer to me, considering the cost both financially and even worse if there’s a failure. I don’t know how handy you are with mechanical work, but It’s pretty quick work. You’ll spend more time waiting for your alignment than the actual work needed to complete the repair/replacement. The only advice is too be sure to torque the bolts to spec… Confirm the bolt you’re using and torque to that bolts specific requirements. There’s a sticky in the first gen forum with a detailed breakdown of the various bolts.
  18. Jul 2, 2024 at 3:18 PM
    #38
    Black97v6MT
    Black97v6MT 366k on the 0D0 ... 5VZFE R150F 4WD
    iMA0
    tacoLand USA
    28 years of livin' Gen1 TacoLife...
    If it is so way quick to do then Why is the shop book time for LBJ replacement about 2 hours per each side?
    That confuses me is all and am curious why so long! I have not attempted to do one yet so IDK!
  19. Jul 2, 2024 at 3:58 PM
    #39
    smyles1632
    smyles1632 Well-Known Member
    2003 Tacoma
    I just replaced LBJs on both sides, took less than an hour and I didn't even need to use a separator as both joints just popped out. Not sure why folks insist on alignment, it's not affected by LBJ replacement.
    Best price for 04005-03235 I could find was ~$200 shipped from Midlands Toyota.
  20. Jul 2, 2024 at 4:21 PM
    #40
    Truckstop13
    Los Angeles
    They have bills to pay and customers to screw over to afford the brick and mortar. It’s 2 hours all in for a clumsy guy like me, taking my sweet time. Unfortunately, you got hosed. I don’t know what a certified mechanic should charge for this job, but if you’re not handy, or don’t have the time(which is often the case) and or not willing to learn, it’s what it is.
    Black97v6MT[QUOTED] likes this.
