OEM battery went to 5 years 8 months
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Gutt Pile, Jul 21, 2021.
  1. Jul 31, 2021 at 5:21 PM
    #81
    suaveflooder
    suaveflooder Well-Known Member
    2021 4Runner Venture
    I bought my replacement at Walmart. So far it’s lasted longer than than my OEM one. Got about a year out of that one
    Cuffs[QUOTED] likes this.
  2. Jul 31, 2021 at 5:22 PM
    #82
    snickers
    snickers My new, overpriced heaping pile of shit
    2024 Tacoma Tailhunter 5ft bed Bronze Oxide
    Get yourself one of these or an equivalent: https://www.amazon.com/gp/product/B086L29DL9?ie=UTF8
    Saved my behind out camping in the boonies. Gifted a similar thing to a relative and saved his behind several times too.
    usmc2msu likes this.
  3. Jul 31, 2021 at 6:07 PM
    #83
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    I’ve done a fair amount of studying batteries and what makes them last and die. With pure lead acid batteries 2 things reduce its life. Heat and sulfation. You can’t do much about the heat. An engine bay is a horrible place to have a battery. Sulfation starts the minute the battery has less than 100% state of charge. Batteries with thicker plates like marine and deep cycle resist sulfation. If you run a starting battery dead you just killed a major percentage of life. Starting batteries should not be used to run accessories by themselves. Marine batteries can some what and deep cycle a lot more. Marine batteries are a compromise between starting and deep cycle. Even deep cycle batteries should never go less than 60% discharge without damage. Starting batteries with their thin plates can dump a lot of amperage fast for starting an engine but are typically full charged by the alternator about 10 min later. A deep cycle will last much longer in your car but may not dump enough amperage to start in cooler weather. All lead acid batteries do better with less discharge and constant trickle charging. Modern cars discharge batteries all the time. My deep cycle Trojan battery for my trolling motor is 15 years old and still runs like a champ. I charge it as soon as I get home and keep it on a battery tender in my cool basement.
    My point is that the OEM battery is just about as good as you can get. Take a volt meter with you to get the freshest one and piss off the auto part store. The one that’s been sitting on the shelf discharging on its own ( they all do) has a lot less life.
    If you want some heavy reading on batteries check out http://www.batteryfaq.org/
    VaToy and DanoTay like this.
  4. Aug 8, 2021 at 9:47 PM
    #84
    SmokeyTacoAZ
    SmokeyTacoAZ Well-Known Member
    2018 DCSB TRD 4x4 OR
    Ha! I bought one a few months ago bc I can't leave noco in the hot truck down here in the summer. But I wasn't sure if they would work. I'm about to buy a new battery anyway bc I'm taking the family to see remote spots in UT and CO and don't need to bother with a dead battery. My bros OEM Tacoma battery died about this time so I figure better safe in this case. Good to know the autowits worked for you though.
  5. Aug 13, 2021 at 9:35 AM
    #85
    Age315
    Age315 Well-Known Member
    AJ
    Castle Rock, CO
    2016 BBP Yeti Mobile
    TRD Baja Kit with JBA UCA's 1/2 inch spacer on top, Medium Dakars with BAMF hangars and super bumps all around. 285/75/16 Cooper Discoverer AT3 XLT's on graphite TRD faux beadlock wheels. Pro skid powder coated black with Pelfreybilt aluminum mid skid and aluminum gas tank skid.
    Today it finally happened. 5 years 5 months and 9 days from the time I took ownership of my 16. She just gave up this morning and said she was done. I used my jump box to get her started then headed to wally world. All they had in stock was the agm so now I have to get mine tuned again to include the agm so it charges correctly. It lasted longer than I expected but I knew the day was near.
  6. Aug 13, 2021 at 2:17 PM
    #86
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    I’m confused here. If the OEM lasted 5 years why replace it with something more expensive and may not last that long. It just doesn’t add up. :der:
  7. Aug 13, 2021 at 2:32 PM
    #87
    snickers
    Because here at TW we like pissing contests with our insanity. Mo' money, mo' time. We are legion. Or maybe, our shit doesn't break enough and we get bored.
    bulalo[QUOTED] likes this.
  8. Aug 13, 2021 at 2:46 PM
    #88
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Your confusion likely comes for your ignorance in battery prices..no offense. How much do you think a Deka battery costs or how much a Trustart costs?
  9. Aug 13, 2021 at 2:51 PM
    #89
    bulalo
    SoCAL Inland Empire
    KDMax pro 9.0
    I know it costs more than the OEM you will replace
  10. Aug 13, 2021 at 2:52 PM
    #90
    JoeCOVA
    Joe
    Colorado Springs
    It's actually less. It's also less than every other run of the mill Johnson Controls battery at Advanced, Autozone, Napa etc
    EDIT: Funny enough my battery finally died and I just replaced in a week or so ago. Could have been age or lack of use.
    For your edification:
    East Penn Deka Intimidator Lead Acid, 34R - $120
    East Penn Deka Intimidator AGM, 34R - $175
    OEM Toyota Trustart, 24F, $140
    DieHard Gold, Lead Acid, 24F - $180
