OEM Bulb Replacement Help
Discussion in 'Lighting' started by Jessi, Mar 12, 2011.
  1. Mar 12, 2011 at 1:23 PM
    Jessi
    Jessi [OP] New Member
    Jessi
    2008 TRD Sport
    I tried searching the internet and the forums on TW, but I can't seem to find any help.
    It's a Saturday and my passenger side headlight burned out last night.
    The dealership next to my house is too busy to help me today and most mechanics are charging $50. I just purchased a replacement and am trying to follow the instructions in the manual, but I can't seem to get past step 2 (remove the rubber seal). The problem is that the windshield washer container is behind the headlight thing, which doesn't give me much room to see or pull the seal off.
    If anyone has any advice from personal experience to offer, I would be greatly appreciative.
    I need to replace the bulb today.
    Jess
    P.S. I'm a girl and have very limited experience with cars :p
  2. Mar 12, 2011 at 1:29 PM
    AsianAnts
    AsianAnts just an AnT
    AnT
    Southern California (San Diego County)
    2011 PreRunner TRD Sport L/B Grey Metallic
    -Satoshi Grille Upper/Lower/Triangles -LED Map Lights, LED Dome Light, LED License Plate Lights -No front license -Wet Okole -Weather Techs (digi) -Running Boards -Bed Extender -AFE Cold Air Intake 2SI Dry Filter -Tailgate Hose-Clamp Mod, Tailgate washer Mod -Combi chain lock on bed extender -no chime w/ key in ignition & open door -Fog Light anytime -Slim Cubby's 3kHID fog -bumper plugs -keyhole plug -TRD license plate frame -combi-lock storage -rear TSB -window tint -camera mod -Painted radiator/engine covers -LS460 RetroFit -Bed Tie-Downs -LED Gauge Cluster, radio, clock and AC -Bed Mat -Extra DRings -Painted center console, radio unit, ac panel, overhead console.
    welcome to TW Jessi... check this out:
    http://www.tacomaworld.com/forum/lighting/84308-lighting-faq-please-read-before-posting.html
  3. Mar 12, 2011 at 3:07 PM
    Jessi
    Jessi
    2008 TRD Sport
  4. Mar 12, 2011 at 3:17 PM
    Jessi
    Jessi
    2008 TRD Sport
  5. Mar 12, 2011 at 4:01 PM
    AsianAnts
    AnT
    x2
    QUOTE=wolfpack_5150;2866520]Pull and twist?[/QUOTE]
  6. Mar 12, 2011 at 4:02 PM
    Tacomanator
    Tacomanator Boiling denim and bangin whores
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    the rubber boot just pops right off. remove the 3 bolts holding the wiper fluid reservoir in place and move it aside to give you more room to work with... its so easy, even a girl can do it :p
  7. Mar 13, 2011 at 6:35 AM
    larryde09
    larryde09 Well-Known Member
    Larry
    Rochester, NY
    (Traded-in) 06 2.7L 5-spd SR5 4x4
    K&N Intake, Magnaflow Cat-back Exhaust, Altezza Tail Lights, Pop&Lock Tailgate Lock, Extang Trifecta Tonneau Cover, PIAA foglights with stock switch, DrawTite Hitch, OBX Shift Knob, Hood Protector, Vent Visors, DIY step bars/sliders/running boards, DIY Bed Lights, DIY Running Board/Ground Lights, DIY Tailgate Electrical Box (12V socket, voltage and current gauges), DIY Internal Lighting (coming soon), Aftermarket switches in stock dash blanks, Sony Head Unit, Illuminated 4x4 switch mod
    It can be tough, but just keep working it, it will just pop off. Grab the little tabs and pull/twist each one until it works off.
    You might want to practice on the driver's side headlight just to get a feel for how to take it on and off where there's more room.
  8. Mar 13, 2011 at 6:53 AM
    facemob
    facemob Well-Known Member
    Chase
    1st state
    03 V6 Manual, TRD
    OME 881, Nitrochargers front and rear, diff drop, Wheelers 3 Leaf AAL, Supertop, shitty brush guard and a hole in the muffler
    x2. just pull off the rubber dust gaurd by gripping the tabs and pulling. it may feel as if your going to rip it, but its pretty durable. its easier than you think. remember to not get your greasy fingers all over the glass on the bulb
  9. Mar 13, 2011 at 6:58 AM
    larryde09
    Larry
    Rochester, NY
    x2...I see people touching the bulbs all the time! Even the grease/sweat of a clean finger is enough to burnout a bulb prematurely. Can get expensive if you use bulbs that are better/more expensive than a standard hallogen.
  10. Mar 18, 2011 at 2:20 PM
    Jessi
    Jessi
    2008 TRD Sport
    I had some help. He took out the windshield washer jug to help remove the seal and the bulb. He even filled my washer fluid after he was done! Sweet old man.
    Thanks everyone for your replies to my thread. :)
