OEM Cargo Net install (photos)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NMTrailRider, May 9, 2015.
  1. May 9, 2015 at 2:50 PM
    NMTrailRider
    NMTrailRider [OP] Well-Known Member
    New Mexico
    Cargo Net arrived from Amazon.com. Nice quality, as you can see. I mounted it against the back of cab. When I at first mounted it using the side rails, the net rested about 5 inches behind the cab. That's as close to the front as I could get and still lock the bed rail cleats. I didn't like that position (a 5" gap between the net and the back of the cab). It just looked wrong. I like it much better snug against the cab. As others have noted, it will be interesting to see if it flops around on the highway without the bottom being secured to something. I haven't yet installed D-rings on the front floor of the bed to attach it to. It does fit snugly across the top. Overall impression- I like it and it will most definitely come in handy. Until someone steals it.
    taco211 likes this.
  2. May 9, 2015 at 2:51 PM
    NMTrailRider
    New Mexico
  3. May 9, 2015 at 3:02 PM
    taco211
    taco211 Well-Known Member
    socal
    If you decide to install D-Rings on the rear of your bed, you can use a carabiner at each end to hold the lower section of the net to each corner.:bananadance:
    NMTrailRider [OP] likes this.
  4. May 9, 2015 at 3:13 PM
    Jefes Taco
    Jefes Taco Well-Known Member
    Denver, CO
    14' DCLB TRD Sport supercharged
    Try mounting along the drivers side so you can actually retrieve anything you throw in it. Or at the tailgate. :)
    taco211 likes this.
