OEM D-Rings No Longer Available???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tjbee2003, Jul 1, 2009.
  1. Jul 1, 2009 at 5:35 AM
    tjbee2003
    tjbee2003 [OP] Member
    09 Off Road
    I've tried to order the dang D-Rings from 4 different companies and each one accepted the order at first, then said they could not fullfill because Toyota pulled them all from stock, but didn't say why. Was there a recall or what???
    Anyone know who actually has the the OEM D-Rings that I could order without getting the circle-jerk-around?
  2. Jul 1, 2009 at 5:50 AM
    Veccster
    Veccster bass turds
    Eric
    Pittsburgh - The City of Champions
    2009 DC V6 TRDsport
    5100's all around - fronts at 1.75", 265/70/17 Bridgestone Revo 2, HID headlights and fog lights, factory skid plate, ss exhaust tip, tube steps, Access roll-up tonneau cover, Redline hood struts, 6 D-rings, seat MagLite, LED dome, fumoto oil drain, DTRL, fog light anytime, Kenwood/Clarion speakers, Pop-N-Lock 5300, LED bed lights and a few other things...
  3. Jul 1, 2009 at 6:00 AM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
  4. Jul 1, 2009 at 6:16 AM
    tjbee2003
    09 Off Road
    Thanks but TRDParts4U.com says "Sorry, the Drings have been discontinued by Toyota. They have not let us know why, they were a great seller."
    And the Army surplus rings are a good idea, but they dont come with mounting hardware, and it's just a pain in the ass to have to drill out the holes for the right mounting hardware and have to go to Home Depot to get the hardware. I'd rather just pay the 28 and be done with it. I only need two anyway.
    Anyone else know where they might have a compatible D-ring with mounting hardware?
    Thanks
  5. Jul 1, 2009 at 6:33 AM
    JeffRock
    JeffRock Well-Known Member
    Capital region, NY
    09 Tacoma accesscab 4x4 SR5 2.7L
    Toyota all weather floor mats. Mag light that clunks around in the jack compartment. Dog hair. Dog drool on the windows.
  6. Jul 1, 2009 at 6:36 AM
    FL4x4Taco
    FL4x4Taco Well-Known Member
    Um, are these D-rings for installing in the bed??? I'd like to have a pair in the FRONT!!!!
  7. Jul 1, 2009 at 6:45 AM
    Veccster
    Veccster bass turds
    Eric
    2009 DC V6 TRDsport
    Again...you don't need the mounting hardware. Hell, send me $2 and I'll send you the mounting hardware that came with my OEM rings. I didn't use it because I installed them using my bed bolts. That is the better way anyway...why drill holes in your bed if they are already there?
  8. Jul 1, 2009 at 6:49 AM
    FL4x4Taco
    I looked them up... they have them separated by reg & access cab and then ones for double cab. how is that possible? Aint they all the same?
  9. Jul 1, 2009 at 7:15 AM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    Picked them up at a hardware store for two bucks and installed 'em under the bed bolts. :thumbsup:
  10. Jul 1, 2009 at 7:20 AM
    hendooman
    hendooman The Stroker Ace
    Jeff
    KC
    2009 Tacoma OR (SOLD); 2015 TRD PRO 4Runner
    I agree with Jeffrock...I installed 4 of these army surplus ones. Allyou have to do is unscrew the bed bolts and drill a larger hole in the mounting plate on the dring. Rattle Can them and they are done.
  11. Jul 1, 2009 at 7:26 AM
    Veccster
    Veccster bass turds
    Eric
    2009 DC V6 TRDsport
    I was unaware that the Arm Surplus rings needed larger holes to accomodate the bed bolts. The OEM ones I used did not...straight plug and play.
    I would still rather enlarge a hole in the d-ring assembly than to drill a hole in my bed.
  12. Jul 1, 2009 at 7:41 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners.
    Those of you installing them using the bed bolts; do they swivle like the factory ones in the rear? If so how are you doing it? Not that I need them to free spin, just curious.
  13. Jul 1, 2009 at 5:47 PM
    fletch aka
    Gary
    Left Coast
    No, they don't.
  14. Jul 1, 2009 at 7:25 PM
    MattN03
    MattN03 Well-Known Member
    Bluegrass State
    SOLD: 07 DC 4x4 TRD Off-Road
    20% window tint, beep mod, hardwired V1, TSB springs, AVS Bugshield-21803, USA Spec PA15, OEM Tacoma scuff plates, Weathertech mats, Truxedo LoPro, TRD skid, GY Duratrac's 265/75/16 C Range, locker mod (switch method)
    I bought mine directly from the local dealer a little over a month ago. Told them what the TRDParts4U cost was and they matched it. Maybe your local dealer has some in stock or can get them somewhere?
  15. Jul 1, 2009 at 7:25 PM
    Veccster
    Veccster bass turds
    Eric
    2009 DC V6 TRDsport
    The OEM ones I installed swivel.
  16. Jul 1, 2009 at 7:43 PM
    hendooman
    Jeff
    KC
    army surplus ones dont. I angled them the way I thought would be most useful 90% of the time. I actually just cut the holes in my bed mat....man it hurt to do that, but I am glad I did. I will get a pic of it this weekend.
    These are the army surplus ones
  17. Jul 1, 2009 at 7:43 PM
    hendooman
    Jeff
    KC
    my truck is only a few months old so getting the bed bolts off was not that big of a deal.
  18. Jul 2, 2009 at 12:29 PM
    Capita
    Capita Well-Known Member
    Corner Brook, Newfoundland, Canada
    09 TRD Sport Double Cab
    Looks great and very functional. Great job. Seems like a very useful mod (something that should be standard on a truck)
  19. Jul 2, 2009 at 1:04 PM
    rmb_crew
    rmb_crew My other ride has 18,400HP!!!!!!
    Jacksonville, FL 30.243103, -81.591007‎
    2010 F150 XLT SuperCrew 4X4
    Access larado tonneau, magnaflow exhaust
    Its the most useful mod. Those bed rails flex when i tie stuff to them. So the D-rings are great!
  20. Jul 2, 2009 at 1:14 PM
    jeremiekc
    jeremiekc Well-Known Member
    Jeremie
    Vilseck, Germany
    07 Regular Cab Base Model
    Secondary Air Filter removed, Painted Brake Calipers, AFN Drop in air cleaner, OEM Chrome Bumper, OEM Chrome grilll, OEM Cruise Control, OEM Interval Wipers, Hard Wired Garmin Nuvi 670, X-Runner Rims, Devil Horns, 6000w HID's, Bling Light Fogs with Blue Halo, OEM Bilstein Rear Shocks, 12V Plug in Truck Bed pocket. Debagged, 13" Antennax, Color Matched Satoshi Grill, URD Short Shifter, WeatherTech Floor Mats, PainLess Wiring Switched Fuse Box, Black Sand Pearl X-Runner Badges
    I guess all of the dealers are different. I went to my dealer this morning and they were going to charge me $55 for a set of two. Boy was I going to get ripped off. I want to do this mod badly but I dont want to spend alot of money on it.
