OEM Fog light switch
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Unchained 5150, Dec 2, 2014.
  1. Dec 2, 2014 at 3:10 PM
    Unchained 5150
    Unchained 5150 [OP] Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Can any of the Aftermarket Hella, Piaa, KC etc etc etc be wired up to an OEM Fog Light switch?
  2. Dec 2, 2014 at 4:07 PM
    smithr1730
    smithr1730 Well-Known Member
    Rob
    Columbus, Ohio
    '15 TX Pro
    Offroad parts and such
  3. Dec 2, 2014 at 4:08 PM
    Unchained 5150
    Rick
    Auburn Ma
    Thanks googling showed the OEM Fog Light switch is different in 2012 and beyond. Anyone have any thoughts or input on this?
  4. Dec 2, 2014 at 4:14 PM
    Unchained 5150
    Rick
    Auburn Ma
    I am going to be getting a new mesh grill from StealthTaco and a BAMF behind the grill light mount. Want to put either some PIAA, or Hella, or KC lights behind the grill. Also want to hook it up to an OEM switch in another OEM switch position inside the truck
  5. Dec 2, 2014 at 4:57 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
  6. Dec 2, 2014 at 4:58 PM
    Unchained 5150
    Rick
    Auburn Ma
    Hmmmmmmmmmmmmmmmmmmmmmm nice
  7. Dec 2, 2014 at 7:07 PM
    RFT
    RFT Well-Known Member
    BC
    2020 AG Pro 6MT
    F/R Coastal high clearance, F:Elka 2.5 IFP & Rancho UCA, R:Dobinson & Fox 2.0 resi, LT255/85R16 ST Maxx
    It's just the colour of the back-lighting. Pre-2012 is orange, while 2012+ is a whitish-yellow. I used an OEM switch/harness (albeit from a pre-2012 truck) to wire up my PIAA LP530s no problem. Sort of wish I had done a bit more research to have them match the rest of my switches.
  8. Dec 2, 2014 at 7:16 PM
    Unchained 5150
    Rick
    Auburn Ma
    Thanks man
  9. Dec 3, 2014 at 6:01 AM
    MeefZah
    MeefZah -----------
    Mark
    Lexington, Ohio
    2020 GX460
    There is no reason you can't use the OEM switch to trigger the relay to run the driving lights.
    I don't quite understand though - you do, or do not, have an existing OEM switch already in place? If you do not, I think you are better served getting one of the On Board Air switches linked above, or the OEM Toyota / Hella 450 switch for $10. Either is a cheaper route and both will be easier to wire since they are designed for the aftermarket.
    The Toyota / Hella switch drops right in with only a small bit of filing to the hole (removal of two thin plastic ridges):
  10. Dec 3, 2014 at 6:05 AM
    Unchained 5150
    Rick
    Auburn Ma
    I already have the OEM fogs in but when I add the new behind the grill lights they all come with some type of on/off switch. Just wanted to know if I bought another OEM switch if it can be used with aftermarket lights
  11. Dec 3, 2014 at 6:16 AM
    MeefZah
    MeefZah -----------
    Mark
    Lexington, Ohio
    2020 GX460
    Ah, so you want two of the same switches. Gotcha. Yeah, the OEM will absolutely control the after market lights, a switch is a switch.
  12. Dec 3, 2014 at 6:19 AM
    Unchained 5150
    Rick
    Auburn Ma
  13. Dec 4, 2014 at 4:15 AM
    western88
    western88 Chris b.
    ny countryside
    2014 SR5 4x4 taco Barclona Red
    beather mod Bugsheild backup light mod egr vent
    Wondering the switch posted above will replace my oem switch? I am looking a replacement that shows a light initiator that tells me the fog lights are on.
  14. Dec 4, 2014 at 8:27 AM
    MeefZah
    MeefZah -----------
    Mark
    Lexington, Ohio
    2020 GX460
    It won't plug into the harness but with some adjusting it would work, yes.
