OEM Heated Mirrors DIY mod
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Benson X, Dec 18, 2011.
  1. Dec 5, 2012 at 12:15 PM
    #181
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    How are you doing the timing part of it? Will yours just be on whenever the switch is on (meaning you'll have to remember to turn them off)?
  2. Dec 5, 2012 at 12:28 PM
    #182
    b0ules
    b0ules Fresh frame!
    Ottawa, Canada
    Speedway Blue 06 TRD Off-Road
    Leer 100XL Topper OME 885X/Nitrocharger Sport Front Dakar Leafs/Nitrocharger Sport Rear
    No timing yet, but I may go with a 555 circuit if this becomes an issue. Just flip the switch when I want them, and I'll pull switch power from ignition power in the nearby harness (like from the mirror controller?) to power a relay for the heavier work of current supply.
  3. Dec 5, 2012 at 12:37 PM
    #183
    Pugga
    Massachusetts
    I'm going to tap the cigarette lighter for heated mirror power. That way they will only be able to be turned on when the ignition is on and the draw is so low it shouldn't bother that circuit one bit. I normally only have my GPS plugged in there anyways.
  4. Dec 5, 2012 at 1:05 PM
    #184
    b0ules
    b0ules Fresh frame!
    Ottawa, Canada
    Yep, depending on where your switch is going, that could make a lot of sense. I'm staying over on the left side of the steering wheel, and I don't like long runs of wires. Passing a wire for the passenger-side mirror supply is going to piss me off just a wee bit...
  5. Dec 5, 2012 at 1:11 PM
    #185
    Pugga
    Massachusetts
    Switch is on the left side of the steering wheel. I try to avoid long runs but a couple extra feet won't do anything negative.
  6. Dec 5, 2012 at 6:30 PM
    #186
    taczilla
    taczilla I intend to live forever; so far.... so good!
    Marc
    PEC, Ontario, Canada
    2016 RAM Rebel
    2012 TRD Sport - STOLEN! / 2016 RAM Rebel
    subbed
    Thanks!
  7. Dec 10, 2012 at 8:13 AM
    #187
    itsakeeper
    itsakeeper Well-Known Member
    nova scotia
    2012 SR5
    the back of the highlander mirror has two leads; + and - which is which or does it matter ?
    thanks
  8. Dec 10, 2012 at 8:19 AM
    #188
    alegav
    alegav TeamBlue
    Alex
    San Diego, CA
    2012 Tacoma TRD T|X Baja
    Pelfreybilt IFS Skid, Mid Skid and Plate Bumper, Rigid Industries Dually's, ARB CKMA12 On Board Air, Kenwood TM-281A Radio, Rear view mirror relocation bracket, Wheelers SuperBumps, Toytec Baja Spacer
    subd for reference. Amazing mod!!
  9. Dec 10, 2012 at 8:33 AM
    #189
    Pugga
    Massachusetts
    The Sienna mirrors I got have 2 prongs sticking out, unlabeled. I'm inclined to believe it doesn't matter which is which, it's just creating resistance to make heat so it shouldn't matter. You might want to call a dealership to confirm though.
  10. Dec 10, 2012 at 8:59 AM
    #190
    Benson X
    Benson X [OP] My build thread sucks...
    Ben
    Olympia, WA
    '11 MGM DC/LB
    If you don't draw blood, you're doing it wrong!
    What Mike said. If the Highlander mirrors are actually labeled (+/-), I would just wire it according to that to be safe.
  11. Dec 10, 2012 at 9:03 AM
    #191
    Pugga
    Massachusetts
    Oh, if they're actually labeled, keep them straight. Mine weren't labeled at all so I didn't bother keeping track of which prong was which.
  12. Dec 10, 2012 at 9:04 AM
    #192
    Benson X
    Ben
    Olympia, WA
    '11 MGM DC/LB
    ^^^Me too, the Sienna mirrors aren't labeled, and it really doesn't matter which is which. Not sure if the Highlander mirrors are actually labeled though, or if itsakeeper is wondering which is POS/NEG.
  13. Dec 10, 2012 at 9:16 AM
    #193
    b0ules
    b0ules Fresh frame!
    Ottawa, Canada
    Only explanation I could see for polarity would be if there was an indicator led built into the mirror - but these things aren't fancy enough for that I don't think. ;)
  14. Dec 10, 2012 at 11:00 AM
    #194
    Twalt87
    Twalt87 Well-Known Member
    Travis
    Vancouver island Bc
    Got my mirrors in today, never came with a backplate so ill have to swap em out.
    i got the 2012 highlander mirrors
  15. Dec 10, 2012 at 12:11 PM
    #195
    itsakeeper
    nova scotia
    2012 SR5
    yep, just wondering if it made a difference which one was connected to pos/neg - mine are highlander and came with the backing - strange yours didn't
  16. Dec 10, 2012 at 12:23 PM
    #196
    Benson X
    Ben
    Olympia, WA
    '11 MGM DC/LB
    That is strange....where did you order from (if you don't mind me asking)?
    I want to make sure I keep the OP updated with accurate info.
  17. Dec 10, 2012 at 2:28 PM
    #197
    Twalt87
    Travis
    Vancouver island Bc
    ordered from the ebay links i posted. Its just the glass with the heater. Ill post pics later.
    It probably clips into the stock backing plate no problem but if i have to modify it i will post.
    Not 100% sure when ill get to it.
  18. Dec 10, 2012 at 9:24 PM
    #198
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    I'm surprised that you got just the glass only.?.? .You'll most likely have to adhere the glass to the existing backplate, the glass alone simply doesn't just clip into is plastic base.
    Here is a quote I pulled from my post a few pages ago... This link (as well as many others) have the glass and backplate factory applied, it's just a snap and go, It's a genuine Toyota OEM product.
  19. Dec 11, 2012 at 1:59 AM
    #199
    itsakeeper
    nova scotia
    2012 SR5
    mine came from the dealer $106 ea.
  20. Dec 11, 2012 at 5:35 AM
    #200
    Pugga
    Massachusetts
    Whoa... I paid $46/ea for the Sienna mirrors :eek:
