OEM Heated Mirrors DIY mod
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Benson X, Dec 18, 2011.
  1. Jul 16, 2013 at 5:51 PM
    #261
    Benson X
    Benson X [OP] My build thread sucks...
    Ben
    Olympia, WA
    '11 MGM DC/LB
    If you don't draw blood, you're doing it wrong!
    No worries man, do you know how to use TW Live? Check out the first post on TW Live, and there's instructions. Basically you can send a picture from your cell and it will upload it automatically. Much easier.
  2. Jul 16, 2013 at 7:04 PM
    #262
    Benson X
    Ben
    Olympia, WA
    '11 MGM DC/LB
    Well bud, what you got there is a fog lamp switch. Unfortunately it doesn't have a built-in timer like the heated mirror switch does, so it kind of defeats the purpose.
    I would suggest tracking down a Highlander Heated Mirror switch as referenced above, and use the diagram from CtryBoyInMT to wire it up.
  3. Jul 16, 2013 at 7:24 PM
    #263
    itsakeeper
    itsakeeper Well-Known Member
    nova scotia
    2012 SR5
    DUH !!!lol thanks
  4. Jul 16, 2013 at 7:32 PM
    #264
    Benson X
    Ben
    Olympia, WA
    '11 MGM DC/LB
    Haha, I know it's obvious, but I didn't want to assume you knew that too. I'm sure you could use that, just not 100% sure of the pin out.
    I'm guessing since it doesn't have have the "jewel" indicator light, that's your missing pin (like you previously said). I would wire it up in the same sequence and put your multitester on it to check. Good luck man.
  5. Aug 7, 2013 at 1:29 PM
    #265
    itsakeeper
    nova scotia
    2012 SR5
    Ha, got em workin. Had a problem with the switch not working but would when I put a jumper on it. Traced my wires and what I thought was a factory join on a piece of wire I used was actually a diode; must have been for a set of lights I guess.
    Many thanks for your help and this thread.
  6. Aug 7, 2013 at 2:31 PM
    #266
    Benson X
    Ben
    Olympia, WA
    '11 MGM DC/LB
    :thumbsup:
    Awesome, glad to hear you got it working! Just in time before cold-season comes.
  7. Aug 27, 2013 at 10:14 AM
    #267
    mach1man001
    mach1man001 eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    Happy Birthday Ben.
  8. Aug 27, 2013 at 10:19 AM
    #268
    Benson X
    Ben
    Olympia, WA
    '11 MGM DC/LB
    Thanks Rob! :cheers:
  9. Aug 27, 2013 at 12:19 PM
    #269
    HighTQCummins
    HighTQCummins Instagram: stormtrooptaco
    Hank
    SE PA
    '12 SW DCSB Sport
    5% all around, derp'd wheels, FMS40, 30" E-Series, 55w 6k bi's, 35w 5k fogs
    just installed some pro-efx mirrors w/ a heater circuit in them, some day when I get time i'll certainly be trying to incoporate this write up to get them working, it'd be nice to have heated mirrors finally in this truck, plus I too have 1 empty spot in the dash w/ a blank that a heated mirror switch would fill perfectly
    excellent write up, wish you lived closer by and could do this for me, looks a little bit daunting
  10. Aug 27, 2013 at 12:23 PM
    #270
    Benson X
    Ben
    Olympia, WA
    '11 MGM DC/LB
    Nice man, I've been wondering how the ProEFX mirrors would work with elements of this mod. It is not that difficult, honestly, It is mostly just time-consuming. I helped my dad with his, and we got it done in about 5 hours.
  11. Aug 27, 2013 at 12:26 PM
    #271
    HighTQCummins
    Hank
    SE PA
    '12 SW DCSB Sport
    I mean it's 2 wires for each, if you were diligent enough im sure you could just give it power and remember to turn it off, but thats the important part, remembering to turn it off, I like this timer/switch/relay set up. Toughest part I think for me is getting all the wires run and CLEAN
  12. Aug 27, 2013 at 12:55 PM
    #272
    mach1man001
    Rob
    Bellingham, MA
    2024 Tundra Limited
    The ProEFX mirrors have no problem hooking up this way. I am the person that ran the poll to help finalize the products and ran the GB for the ProEFX mirrors. I constantly send people over to this thread to help them see what's up for the install. Even though I had someone help me install them after seeing it being done I am confident that most anybody can do it if you follow along this write up. GL with wiring them up and hope you like the mirrors!
  13. Aug 27, 2013 at 12:58 PM
    #273
    HighTQCummins
    Hank
    SE PA
    '12 SW DCSB Sport
    i've had them on for less than 24 hours, and already am in love w/ them, just wish I had the time to wire it up for heat, i'll have to see what kind of time I can come up w/ before winter to do this, although if I don't get it done, not a big loss, hell the stockers didn't have it either :D
  14. Oct 7, 2013 at 9:47 PM
    #274
    smgcon
    smgcon Well-Known Member
    Geoff
    Vernon, BC
    2013 DBC
    After watching this thread for a while and seeing the thermometer drop, I decided it was time to do this mod. The parts are fairly similarly priced in Canada with exception of the switch. It is double that shown in the US.
    So I ordered all of the parts from the USA out of a Toyota dealer in Yuma AZ. Shipping was $15 but that was more than made up for by the lower switch price.
    Should get this started in a couple of weeks once all of the bits arrive.
  15. Oct 19, 2013 at 5:27 PM
    #275
    floodedkiwi
    floodedkiwi Well-Known Member
    Ken
    Naw'lins, Louisiana
    2019 GMC AT4
    Dog.
    I just installed the Muth mirrors with heat and indicators and used BJGreenly's write up for the heated mirror piece ( http://www.tacomaworld.com/forum/2n...em-heated-mirror-option-off-road-package.html), which worked fantastically and was super simple to install. The hardest part was pulling all the dash apart to install the OEM switch next to the Atrac switch.
    The biggest issue I had was following the Muth instructions and contacted customer service and they sent me more info for my 2013, however still struggled trying to sort out where the actual wires were. Anyway, following the instructions as I read them did not give me indicators, so after getting a 2013 wiring diagram I found the tail light indicators and used them. Once found and traced, super easy. I have put two pics in so you can see where I ended up doing my hook ups. (yellow is left and Blue/ white is the right).
    Only the close up pic will upload , so will add the other one on the next post.
    Thanks to everyone who has added to this thread
    :cheers: :D
  16. Oct 19, 2013 at 5:28 PM
    #276
    floodedkiwi
    Ken
    Naw'lins, Louisiana
    2019 GMC AT4
    Dog.
    Here is the overview pic so you can see the location of my tie ins
  17. Oct 19, 2013 at 5:58 PM
    #277
    gold68ht
    gold68ht Active Member
    '07 PreRunner SR5
    Subscribed
  18. Oct 19, 2013 at 7:40 PM
    #278
    Tacomaruss
    Tacomaruss Active Member
    Russ
    Leduc
    Alpine White 2013 TRD Trail Teams
  19. Oct 28, 2013 at 5:09 PM
    #279
    smgcon
    Geoff
    Vernon, BC
    2013 DBC
    Ben and those following this thread:
    The instructions were perfect, so the install went off without a hitch. I would say it took 4 hours for everything including clean up. That is mostly because the write up was so well documented, the Muth door panel removal instructions were easy to follow, and I had read this thread 10 times at least over the last week or so :D
    Best mod I have done so far as out temperature is falling and I don't have a garage. Should be able to try them out tomorrow morning when I go to work at 0630 hrs...
  20. Oct 29, 2013 at 3:20 PM
    #280
    Benson X
    Ben
    Olympia, WA
    '11 MGM DC/LB
    Thanks Geoff! I'm glad you found the write-up helpful. It is definitely that time of year again...the temp was 30° when I got in my truck this morning - windshield and mirrors were frozen over, but with some defrost and the Heated Mirrors, it was gone in a couple minutes. :thumbsup:
