OEM Heated Mirrors DIY mod
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Benson X, Dec 18, 2011.
  1. Feb 24, 2015 at 4:49 PM
    #401
    Tbryson2
    Tbryson2 Well-Known Member
    Terry
    Central Florida
    05 PreRunner SR5
    Using the Highlander timer switch, (84871-48030), what is the delay time & is it adjustable?
    TB
  2. Feb 24, 2015 at 5:39 PM
    #402
    Benson X
    Benson X [OP] My build thread sucks...
    Ben
    Olympia, WA
    '11 MGM DC/LB
    If you don't draw blood, you're doing it wrong!
    The timer stays on for roughly 15 minutes at a time. I'm not sure if it's adjustable - I didn't want to tear apart a $50 switch :eek:
  3. Feb 24, 2015 at 5:53 PM
    #403
    onedivinetaco
    onedivinetaco Well-Known Member
    botolphston
    '05 dcsb 4x4
    How about some new pics of the Highlander mirrors on the Tacoma? Do they come with the blinkers or spotlights too?
  4. Feb 24, 2015 at 5:59 PM
    #404
    Benson X
    Ben
    Olympia, WA
    '11 MGM DC/LB
    It's just the mirror glass that is used...not the whole housing, so it will not give you any feature other than heated mirrors.
  5. Feb 24, 2015 at 7:03 PM
    #405
    shawnd2
    shawnd2 Well-Known Member
    Shawn
    Toronto, Ontario, Canada
    08 Tacoma Access Cab 4x4 TRD Offroad
    I still have the old Highlander switch that I burnt out by not using a relay. I pulled it apart when it happened and don't remember finding anything that would allow timer adjustment.
    After roughly 7 years and -40 Wheather my mirrors still worked great.
    Shawn
  6. Feb 25, 2015 at 7:23 PM
    #406
    Jeremy M.
    Jeremy M. Well-Known Member
    Fort Drum, NY
    13 DCSB TRD Off Road
  7. Feb 25, 2015 at 9:54 PM
    #407
    Up2NoGood
    Up2NoGood Well-Known Member
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
  8. Feb 26, 2015 at 1:47 PM
    #408
    Jeremy M.
    Fort Drum, NY
    It's an on off switch you will still need the timer relay.
  9. Feb 26, 2015 at 2:52 PM
    #409
    Benson X
    Ben
    Olympia, WA
    '11 MGM DC/LB
    WolstenTech Timer Relay (from bgreenley's add-on to the OP):
    "Lastly, the magic timer-relay: http://www.wolstentech.com/products/timedelayrelay/tdr-mc.php
    You can read about the timer relay above by following this link:
    http://www.wolstentech.com/products/timedelayrelay/timedelayrelay.php
    The timer relay is offered in many flavors. The correct flavor to order for this application is the TDR-MLC. This circuit, wired as shown below, will allow you to turn on the mirrors with a single press of the button. If you press the button again before the timer expires, it will cancel your request for the mirrors to be heated. This is really cool, and exactly the way most OEM installations are done. You don’t need another relay in addition to the TDR-MLC. It will drive the mirrors directly. The TDR-MLC can drive 10A continuous current, and each of the mirrors only consumes about 2A each (I bench tested them).
  10. Feb 26, 2015 at 7:40 PM
    #410
    Tbryson2
    Terry
    Central Florida
    05 PreRunner SR5
  11. Feb 27, 2015 at 9:15 AM
    #411
    Up2NoGood
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
    Interesting, aren't the switches and switch blanks the same size for 05-15?
  12. Feb 27, 2015 at 10:25 AM
    #412
    Tbryson2
    Terry
    Central Florida
    05 PreRunner SR5
    The one in post 406 looks wider than the one for the 05
  13. Feb 27, 2015 at 10:35 AM
    #413
    Up2NoGood
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
    Actually at a second glance it does, although to me that looks like it is sized to fit in the area under the AC controls etc rather than the area to the left of the steering wheel.
  14. Feb 27, 2015 at 10:47 AM
    #414
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
  15. Feb 27, 2015 at 11:25 AM
    #415
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Yeah , I think the difference in size is between the ones on the dash and under the AC controls , that always confused me why they had the 05-11 and 12+ dash ones in different categories on the Aironboard site
  16. Mar 4, 2015 at 2:12 PM
    #416
    Tbryson2
    Terry
    Central Florida
    05 PreRunner SR5
    Just a thought about fuse rating size. I'll probably be guilty of starting a debate here, hope not. It is in my educated opinion that using a 10amp fuse described in the schematic on page 1 of this post may be pushing the envelope a bit too much. A over rated fuse can be dangerous.
    If the relay can handle (max) 10amps, and the wire used (20 ga) is Rated for (roughly) 10 amps, then the fuse should be somewhat less.
    I will be doing the ">>>*UPDATE* FOR THE THOSE WITH TRD-OR TACOS (with no switch blanks) <<<" In that instruction the author stated that each mirror pulls 2amps. This would be 4amps total (roughly) so the fuse could safely be a 7.5 amp fuse. This would not compromise the integrity of any components or wiring used. I want my fuse to pop before that expensive timer/relay!
    Just a thought
    TB
  17. Mar 4, 2015 at 4:36 PM
    #417
    Up2NoGood
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
    I'm in 100% agreement with you on that one. I was considering a 5 amp... although that may be close so may have to go with the 7.5 amp fuse. Also regarding the wire, the instructions list using 16 gauge but i will be going with 18 gauge. I'm all for overbuilding on certain things, but in reality even the 18 gauge is what is called for and is WELL within it's safety margin for this project.
    Also hope that this post doesn't get misinterpreted, I think this is an awesome write up and huge respect to Benson for putting it all together.
  18. Mar 4, 2015 at 4:51 PM
    #418
    Mako99
    Mako99 Well-Known Member
    Virginia
    2012 Taco Sport
    Didn't see a tdr-mlc, just the tdr-mc. I'm assuming that is the same thing? And the relay we want is the negative (as opposed to positive).
    Thanks
    Corey
  19. Mar 4, 2015 at 5:50 PM
    #419
    Tbryson2
    Terry
    Central Florida
    05 PreRunner SR5
    From what my research tells me, the TDR-MC (negative) is what to use as shown in the schematic. I suppose you could use positive (reference the relays website for instructions) but since it was already so nicely worked out, that is the route I'll take.
    I did inquire about the relay timing diagram & what was the meaning behind the small positive trigger where the relay did nothing. They said that is to represent that the trigger must be longer than the turn on delay for it to actually trigger on. If your delay is 0 (or practically 0) then it will trigger on instantly. If you want a 2 second turn on delay, the trigger has to be longer than 2 seconds...
    TB
  20. Mar 6, 2015 at 4:57 PM
    #420
    Tbryson2
    Terry
    Central Florida
    05 PreRunner SR5
    Received my switch from AirOnBoard.com. (http://www.aironboard.com/online/pu...replacement-heated-mirrors-led-green-red.html) and physically it is exactly what I want. However, the switch is NOT schematically the same as the switch (84871-35010) shown on the schematic and will have to be modified to make it the same. It can be done, but will take some work. I may take pictures & post them as I will be modifying mine.
    If you order one, (to complement the digrams on the first post) you really need a momentary switch. AirOnBoard will ship a momentary if you request it when you order it. I was told to request it on the PayPal page, but I didn't have that option & simply contacted them via email. They had no issue meeting my needs.
