OEM Heated Mirrors DIY mod
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Benson X, Dec 18, 2011.
  1. Feb 25, 2021 at 6:29 PM
    #561
    JAGCanada
    JAGCanada Well-Known Member
    Canada
    2010 TRD Sport V6 Auto Double Cab MGM
    Just gathering the parts to do this mod. I have a timer from timers.shop that I plan on using. Looks a bit smaller than the Wolsten and cheaper too. You need to pick up their external programer to program the timer. Haven't used it yet but when I do I'll post an update.
  2. Feb 25, 2021 at 6:30 PM
    #562
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Is it cheaper with the programmer?
  3. Feb 25, 2021 at 6:34 PM
    #563
    JAGCanada
    Canada
    $17 for the timer and $5 for the programer on their website. I purchased a timer and programer a few years ago and never used it. Looks like it should work, but haven't tried it yet.
  4. Feb 25, 2021 at 6:57 PM
    #564
    bagleboy
    Scott
    Norcal, Santa Rosa
    Definitely cheaper, might be faster too as I got my shipping notice on the 11th and it’s not here yet.
  5. Mar 5, 2021 at 7:52 PM
    #565
    bagleboy
    Scott
    Norcal, Santa Rosa
    Be nice if the relay had enough output terminals but I made up a chair terminal with 1-female and two male spade connectors for the mirrors and will add another terminal to the relay for the return wire to the switch.
  6. Mar 5, 2021 at 8:44 PM
    #566
    bagleboy
    Scott
    Norcal, Santa Rosa
    The black stuff potting the inside and terminals of the wolsten tech timer relay is just abs cement. A minute or so with some acetone cleans it off enough to solder a lead wire to the Load terminal inside the relay enclosure. Putting the extra terminal next to trigger1 seems good. It’s just a male spade terminal on the lead wire and repotted after soldering to Load.
  7. Mar 8, 2021 at 9:59 AM
    #567
    bagleboy
    Scott
    Norcal, Santa Rosa
    Since I have an aux fuse panel and ground buss under the center console I’ll be installing the relay there and running the wires to the mirrors/switch under the carpet along the front seat mounting rails and over to the door grommets. I could go up through the dash but it’s more trouble and more wire for no real benefit.
  8. May 1, 2021 at 5:26 PM
    #568
    bagleboy
    Scott
    Norcal, Santa Rosa
    Woot! All hooked up and working. The extra spade terminal I slipped through the relay housing(next to trigger1)worked just fine to activate the secondary switch led. The terminal has a jumper soldered inside the housing to “load” and is glued in with abs cement.
    road2cycle and FastEddy59 like this.
  9. Oct 30, 2021 at 6:03 AM
    #569
    dontnonottin
    dontnonottin Well-Known Member
    Larry
    Weigelstown PA
    2004 Toyota Sequoia Limited
    Just ordered the parts to do the wife's.
    super_white likes this.
  10. Nov 12, 2021 at 12:40 AM
    #570
    bagleboy
    Scott
    Norcal, Santa Rosa
    Spottermirror has the 2nd gen 2-axis heated mirrors back in stock finally.
  11. Nov 13, 2021 at 2:00 PM
    #571
    dontnonottin
    Larry
    Weigelstown PA
    Just burned up the switch. Anyone have a drawing to wire the Highlander switch without using a relay?
  12. Nov 16, 2021 at 12:31 PM
    #572
    elricfate
    elricfate Well-Known Member
    2009 Tacoma AC Silver Mica
    Okay, spotter mirrors acquired. As noted in the general 2nd gen thread, I'm foregoing a relay since there are 10a micro timers out there. I'm also not bothering with getting an OEM mirror switch that has the heat/fold button in it. I'm just getting a micro momentary on: https://www.amazon.com/gp/product/B07KX24WWS/ and a 10a rated mini-timer: https://www.amazon.com/gp/product/B01HNDOCKK/
    That makes this dead simple. I'm also going to use my aux fuse box to actually supply power to the entire setup, so technically always hot, but it will be fused and grounded appropriately. Now I just need to decide where I am in terms of having time to do it, especially with winter setting in hard here and me having to work outside.
  13. Dec 27, 2021 at 3:51 PM
    #573
    dontnonottin
    Larry
    Weigelstown PA
    Got the replacement high lander switch. Wired relay in per first page of this thread. Orange (top) light on the switch light when running lights are turned on. This doesn't seem correct to me. Anyone have thoughts?
  14. Nov 1, 2022 at 3:35 AM
    #574
    dontnonottin
    Larry
    Weigelstown PA
    Finally took time & got this working. I must have had the switch upside down when I originally wired it up. I changed the wiring & all works as it should. To anyone else doing this, make sure the switch is upside right before connecting the wires to it.
  15. Dec 23, 2022 at 1:33 PM
    #575
    mdywv
    mdywv Member
    2011 Silver Tacoma SR5 DCSB
    OEM heated mirrors, Anytime Rearview Camera, Aftermarket stereo with rearview camera connection, lighted 4x4 switch, always-on USB chargers
    Thanks to all who worked to put this thread together. I got the mirrors and Highlander switch put in back in November; the trim just got put back last night because of some other projects. I was able to fit the relay just in front of the driver door behind the door sill plate/kick panel; in the first picture below the wiring harness that lives just in front of the door is pulled loose for access. I haven't needed this very often yet, as I'm usually able to park under a carport, but as winter kicks in I'm looking forward to being able to see behind me. Thanks again!
    [​IMG] [​IMG] [​IMG]
    Norton likes this.
  16. Jan 26, 2023 at 12:29 PM
    #576
    Madd Matt
    Madd Matt Well-Known Member
    Between the Brandywines S.E. Penna.
    2015 Blue Tacoma TRD Sport 4.0 6 speed manual
    I just finished up this install this afternoon. I sourced a used Highlander dash switch with the pigtail and about 3” of wire for $25.
    on eBay, TRQ heated mirror glass for $35 also for Highlander on eBay. Got a relay with pigtail and a fuse tap for another $12. on eBay.
    I built the wire harness at work to the given dimensions and paid $25. For wire and miscellaneous connectors. I probably spent an hour
    and a half building the harness all solder and heat shrink connections, and bench testing. Spent about 4 hours on final install, Total time
    spent 5 1/2 hours, about $100. spent. Now just waiting for some real winter weather to test it all out.
    mdywv likes this.
  17. Jan 26, 2023 at 3:48 PM
    #577
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    What ray did you get? The one posted originally is never in stock. I have mirrors ready and just need to wire them up.
  18. Jan 26, 2023 at 4:01 PM
    #578
    Madd Matt
    PM me I have a spare one.
  19. Jan 26, 2023 at 4:59 PM
    #579
    mdywv
    mdywv Member
  20. Feb 14, 2023 at 5:19 PM
    #580
    slicksam
    slicksam Member
    sam
    2012 Tacoma 4x4
    I completed this project.......and all I can say is thanks for the write up! Everything went perfect!!!
    Norton and mdywv like this.
