Oem led bed lighting kit 2020
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Guccitaco, Dec 29, 2019.
  1. Dec 27, 2020 at 1:49 PM
    #261
    caribe makaira
    Caribbean, Puerto Rico
    Remove a tail light assembly and verify if the connector is there. Then look for the Cargo Bed lamp switch connector in the cab (behind the cubby).
    TRDSport10 likes this.
  2. Dec 27, 2020 at 2:55 PM
    #262
    pismo61
    pismo61 Well-Known Member
    Temecula,Ca.
    SR 4x2 auto.
    Ok.Will the lamps work without a switch and where is the relay located?Some say they come on with the doors opening.This is for a 2021 SR.Sorry but the thread bounces around.
  3. Dec 27, 2020 at 3:05 PM
    #263
    caribe makaira
    Gotta know what your Taco has or doesn't. SR usually do not have the relay installed but the terminals to accept it are there. (cab fuse box) You'd need a switch to have them on when you want, it does not have to be a OEM one. If you tap a purple wire that is part of the switch wires, then they'd be ON only when the door is open and at unlock/lock. Not when you'd need them to be ON.
  4. Dec 27, 2020 at 3:18 PM
    #264
    Mas Olas
    Mas Olas Well-Known Member
    Woody
    10 miles north or 400 miles south of the border.
    2020 Blacked-Out White DCLB TRD OffRoad 4x4
    Can confirm 20 TRD OR is plug/play. For cheeeep!
    ghostleaf likes this.
  5. Dec 27, 2020 at 3:27 PM
    #265
    pismo61
    Temecula,Ca.
    SR 4x2 auto.
    Thanx,have the relay and plug.Just didnt they were right next to each other.I assume a have the plugs at the tail light.Ill look.
  6. Dec 27, 2020 at 3:29 PM
    #266
    caribe makaira
    Do you have a multimeter?
  7. Dec 27, 2020 at 4:55 PM
    #267
    pismo61
    Temecula,Ca.
    SR 4x2 auto.
    Yes
  8. Dec 27, 2020 at 5:07 PM
    #268
    caribe makaira
    Since the vehicle does not have the switch, place a thin wire (jumper) from the wire side of the connector from the blue to the purple.
    With the meter, verify juice on the connectors at the tail light assembly space.
    Some forum members have reported that the wire from those connectors do not have a wire from the engine room fuse/relay/connector box to the cab.
  9. Feb 20, 2021 at 11:25 PM
    #269
    TAC1
    TAC1 Well-Known Member
    Tac1
    Miami, FL
    2015 DCSB O/R 4WD
    Hello,
    I’m thinking of installing these 2020 OEM bed lights on my 2015. I’ll try to make a template out of cardboard or paper once I have the lights.
    Ground them both somewhere in the rear of the truck,
    Mount a waterproof or water resistant on/off button im the bed near the tailgate,
    Run a fused power wire from the lights to the battery.
    I know I will need to buy extra wire but don’t know what gauge. I’ll just match the wire thickness to that of the OE plugs in the light kit.
    Questions,
    What amp fuse do I need to run these lights? 5 amp, 7.5 amp? 10 amp?
    What is the power draw on these lights?
  10. Mar 15, 2021 at 5:31 AM
    #270
    TAC1
    Tac1
    Miami, FL
    2015 DCSB O/R 4WD
  11. Mar 16, 2021 at 5:21 PM
    #271
    Bgrif119
    Bgrif119 Member
    New York
    2021 DCLB MGM SR5
    Anybody know if this kit is plug and play on a 2021 SR5? Does have the switch in the cab but don’t want to take my tail light apart if it doesn’t fit.
  12. Mar 16, 2021 at 5:23 PM
    #272
    caribe makaira
    It's only held in by 2 bolts and 2 plastic fix pins...
    TAC1 likes this.
  13. Mar 16, 2021 at 5:43 PM
    #273
    Rainoffire
    Rainoffire Well-Known Member
    2017 QS DCLB TRD Sport
    It is plug and play for the most part, 2020+ model years. Just pop the cover and plug in. You may need to install a switch or relay, it your truck did not come with it pre-installed.
    I've attached the pdf.
    TAC1 likes this.
  14. Mar 16, 2021 at 5:45 PM
    #274
    Mas Olas
    Woody
    My 20 took longer to unbox than install. I can’t see why a 21 wouldn’t come pre-wired?
    TAC1 likes this.
  15. Mar 16, 2021 at 5:50 PM
    #275
    calebc
    calebc Well-Known Member
    I'd never assume with Toyota, they like to change weird wiring things between years. For example, my 2020 Sport that didn't come with Homelink had the right wires (for the Homelink), but the constant hot wire was just a dead wire. It's easy enough to confirm before buying with the bed lights.
    TAC1 likes this.
  16. Mar 19, 2021 at 4:19 AM
    #276
    Great Dane
    Great Dane Well-Known Member
    Dane
    Georgetown, Ky
    2021 TRD Sport 4x4 Access Cab.
    So is the '21 Access Cab pre-wired for this except for the relay and switch?
  17. Mar 19, 2021 at 9:09 AM
    #277
    Scottyskywalker
    Scottyskywalker Well-Known Member
    Scott
    Kantukee
    2020 Silver Sky SR V6 4X4 SX
    RCI sliders, RCI front skid, RCI trans skid, Bridgestone Revo 3 AT, OTT tune, Fox 2.0 rear, Front Summo springs, Truxport roll up bed cover, Tekonsha P3, Meso total tails, rear diff breather relocate. JCW front bumper, Apex 12k winch, bar light. Alpine ILX 507, Kicker DX speakers, amber grill light bar, yellow LED fogs, LED headlights, bed mat, bed lights, front camera, rock lights, dash cam, seat jackers, recovery gear, Overland Equipment Aux fuse kit, C4 bumber braces.
    Yes, harness is behind the tail lights.
    Great Dane[QUOTED] likes this.
  18. Mar 19, 2021 at 6:22 PM
    #278
    Great Dane
    Dane
    Georgetown, Ky
    Sweet!
  19. Mar 20, 2021 at 6:01 AM
    #279
    NoVa TRD Sport
    NoVa TRD Sport Well-Known Member
    Alexander
    Northern Virginia
    2021 Army Green TRD Sport
    Leer cap
    The wiring is there but the switch is not. The relay may or may not be there, depending on the trim level. Confirm whether you have the relay before ordering it. (Mine had it.)
  20. Mar 20, 2021 at 6:09 AM
    #280
    1984suzukilt185
    1984suzukilt185 Active Member
    2020 ACCESS CAB TRD OFF ROAD MANUAL
    Absolutely love the OEM lights!
