OEM LED Headlight Conversion Harness
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by daveeasa, Apr 30, 2021.
  1. Oct 17, 2021 at 1:11 PM
    #141
    TRDSport17North
    TRDSport17North 06SR5,17TRDSport,22TRDSport
    Al
    Ontario Canada
    22 TRD Sport D/C L/B Premium
    Oem LEDs Heads and Fogs, Interior and exterior LED's, Tonneau Cover, Tint, Running Boards, decals overlays and inserts, Bed mat and lighting, Mats, Speaker upgrade, amp, powered sub, Dsp. Meso Stage 1 tails. Complete front end Expel paint protection, ceramic coated, rust protection, 265 70 17 Cooper at3 4s on 17" OEM Sema Pro wheels. More to come...
    Dave thank you very much for you giving me the nod that this harness will do the job and leading me to worry free connecting of the heads. As for the fogs I'm guessing it's just plug them into oem existing harness. It seems stage 1 Mesa led taillights are out of stock. Is that the only go to source. Do you make a equivalent set up Dave?
    Question for you t
  2. Oct 17, 2021 at 1:14 PM
    #142
    daveeasa
    daveeasa [OP] FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    I don’t make any taillight switchback harness. You can keep an eye on the BST forum though since many have bought the MESO / Morimoto taillight so some used total tail harnesses should hit the market once those ship. They are preorder right now.
  3. Oct 17, 2021 at 1:16 PM
    #143
    daveeasa
    David
    PNW
    Fog light is a ? But I think direct fit for 2017. At some point Toyota changed to H16 or something? My 2016 was H11. Try and see if it works and if not then we will figure out a plan.
  4. Oct 17, 2021 at 1:42 PM
    #144
    TRDSport17North
    Al
    Ontario Canada
    I sent a pic of the fog. Oem for a 2020 limit, putting them in my 2022 sport when it arrives
  5. Oct 17, 2021 at 1:43 PM
    #145
    TRDSport17North
    Al
    Ontario Canada
    Saw this like for stage 1.
  6. Oct 17, 2021 at 1:43 PM
    #146
    TRDSport17North
    Al
    Ontario Canada
  7. Oct 17, 2021 at 2:02 PM
    #147
    daveeasa
    David
    PNW
    The reason it’s a question is that I know some of these are H16 or something for fog lights. I assume sport and offroad are potentially H11 but I don’t know myself and I know zero people with a 2022
  8. Oct 17, 2021 at 3:12 PM
    #148
    TRDSport17North
    Al
    Ontario Canada
    From what I'm reading and seeing is that all 2022's other than the Pro and Trail, are being trim levels deemed as a carry-over models from 2021. I took some close up of the fogs stampings. Maybe you might be able to decode.
  9. Oct 17, 2021 at 3:27 PM
    #149
    daveeasa
    David
    PNW
  10. Oct 17, 2021 at 5:15 PM
    #150
    TRDSport17North
    Al
    Ontario Canada
    Thanks for the link. Im just happy to know my headlights and harness is all good to go for the swap. I sent the same question about the fogs on that link. Thanks for everything. Cheers Al
  11. Oct 17, 2021 at 11:20 PM
    #151
    Ran-TRD
    Ran-TRD Well-Known Member
    Hi Dave, I’m still learning the ropes around TW. I’m interested in a set of your harness for my OR Tacoma. I’m planing on adding the Raptor grill lights and the Meso turn signal DRL at some point. That being said I’m guessing my option would be the $150 set that says grill lights and V5 harness ?
  12. Oct 18, 2021 at 2:42 AM
    #152
    daveeasa
    David
    PNW
    Based on what you say you want, this sounds like the options you desire.
    Also a quick note to people that I’m away from home base this week but returning Friday. I’ll ship orders on Saturday.
  13. Oct 18, 2021 at 5:47 AM
    #153
    Ran-TRD
    Awesome, thank you for the feedback. Will I have any issues if I go with that harness and don’t use all the connectors? V5 meso turn signals are out of stock right now
  14. Oct 18, 2021 at 7:14 AM
    #154
    daveeasa
    David
    PNW
    If you do grille lights now, you can add the v5 module later. But if you do no grille lights and no v5 then it’s a new conversion harness if you want to add them later.
  15. Oct 18, 2021 at 8:23 AM
    #155
    Ran-TRD
    Gotch! I guess my question really was if I get the harness for grill lights and V5 but install them with out connecting anything to those outlets will I run into headlight issues ? Adding V5 once they are in stock
  16. Oct 18, 2021 at 8:31 AM
    #156
    daveeasa
    David
    PNW
    V5 feed is bare wire so you would either leave it out or run through the firewall.
  17. Oct 18, 2021 at 8:44 AM
    #157
    Ran-TRD
    im talking about the harness it’s self if I get the one for the V5 and grill lights and install it with my new headlights but don’t connect grill lights or V5 will that be an issue for headlight function?
  18. Oct 18, 2021 at 8:54 AM
    #158
    daveeasa
    David
    PNW
    It is modular. I should have photos in the thread. More than one piece.
  19. Oct 18, 2021 at 10:17 AM
    #159
    Ran-TRD
    Gotcha, so no issues if nothing is connected to the grill light port or V5 in the mean time?
    excuse my ignorance I am not great with automotive electrical.
  20. Oct 18, 2021 at 11:31 AM
    #160
    daveeasa
    David
    PNW
    OK, so, previously I was on my phone, sorry, here is a photo which can help you, it's from the LED T tap thread. I do need to put more photos in this thread at some point.
    That's an example of the v5 harness on the right, though for "direct" rather than "T" mode. The T would have male and female connectors and would go in between the headlight conversion harness 3 position AMP connector and the grille light feed. Or if you wanted headlight conversion without grille lights, you'd get that coil on the right as-is.
