OEM Pocket Box Power Outlet
Discussion in '2nd Gen. Tacomas (2005-2015)' started by baldridge, May 30, 2017.
  1. May 30, 2017 at 7:03 PM
    baldridge
    baldridge [OP] War Eagle!!!!! KN4OYZ
    Bart
    Auburn, AL
    2015 MGM TRD Offroad and 2015 Black Prerunner SR5
    OME Lift with HD Dakar’s C4 Slim Line Bumper 4.88 ECGS Gears ARB Single Air Compressor ARB Rear Air Locker JBA UCA’s 285 BFG KO2’s Weather Tech Floor Mats Martin OffRoad Rack Console Vault KB Voodoo Cab Height Rack 23Zero RTT 23Zero Awning 23Zero Shower Tent Maxtrax Black MaxTrax amounting Pins Krazy Beaver Shovel Fiskers Axe Smittybilt ace and Shovel Mount Quickfists Rotopax 4 Gallon Rotopax Mounting Plate Rotopax Mounting Brackets Decked Storage System Alu Cab XL Tilt Fridge Slide ARB Elements Fridge OEM Skid Plate Local Sliders Uniden 510XL Cali Raised Tailgate Antenna Mount Fire Stick 3 foot Antenna PowerTray Fuse Panel Blue Seas Fuse Box Blue Seas Breaker Cali Raised Ditch Light Mounts Rigid Ditch Lights Alpha Rex Head Lights with LED bulbs Blue Ridge Overland Tacoma Attic Blue Ridge Overland Seat storage bags
    Where can I find a 2015 OEM pocket box power outlet other than the dealership? I've looked on eBay and there is one listed but it is for 2013 and below. Thanks for the help!!!!!
  2. May 31, 2017 at 3:58 PM
    the dashing ham
    the dashing ham Taco n00b
    Scotty
    Los Angeles
    '12 DCLB rattle can
    yes, I have done the mods
    baldridge[OP] likes this.
  3. May 31, 2017 at 6:45 PM
    baldridge
    Bart
    Auburn, AL
    How much should I be looking to spend on something like that? Also, where can I get a inverter? Did you find it worth doing once you got yours installed?
  4. Jun 1, 2017 at 1:30 PM
    the dashing ham
    Scotty
    Los Angeles
    '12 DCLB rattle can
    There's no real reason to try and get the factory 400W Toyota inverter; there are plenty of aftermarket inverters available. I got a 600W samlex from Amazon for about $200 and put it under the driver's seat.
    Try and consider what it is you need to do with the A/C outlet in the bed to help inform what inverter you get. For me, I just needed to charge batteries and laptops that didn't have 12v chargers available. So getting a pure sine-wave inverter was important to me, as some electronics don't like the modified sine-wave inverters available much more cheaply. But I also didn't need anything more powerful than 600W.
    There are a number of inverter install threads on here, check them out.
    GREENBIRD56 and baldridge[OP] like this.
  5. Jun 1, 2017 at 2:39 PM
    baldridge
    Bart
    Auburn, AL
    Thanks!
    the dashing ham likes this.
  6. Jun 1, 2017 at 6:52 PM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    Anyone know of something closer to the 1200 watt mark that is still reasonably sized? I'd like to run a small electric skillet off the plug in the bed for camping purposes.
  7. Jun 2, 2017 at 8:24 AM
    cliffyk
    cliffyk Well-Known Member
    Cliff
    Saint Augustine, FL
    2009 DCSB SR5 TRD Sport 145k miles
    Just my $0.02 worth, however I recommend reading up on what's involved in wiring up a 1200 W inverter before commiting to buying one to run an electric skillet. To mount it in the cab you'll need 12 ft or more of at least #2 AWG wire; a 150 or 200 A fuse and holder, or circuit breaker; a capable switch or relay to shut off the inverter; and wire to run from the inverter to the bed outlet (12 or 14 AWG marine duplex cable).
    All this will of course have to be fished/run from the battery to the converter, and converter to bed outlet--and perhaps a second battery and isolation switch.
    This could start to make a small generator or propane stove and skillet look like viable alternatives. Our A-Liner camper has its own battery and a 1250 W inverter--we quickly found out there were alternatives to electric skillets...
  8. Jun 2, 2017 at 8:30 AM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    alt wont put out 130 amps at idle
  9. Jun 2, 2017 at 8:45 AM
    cliffyk
    Cliff
    Saint Augustine, FL
    This is quite true, and even though the battery will be carrying most of the load the generator will try its best to do something, which stresses it more than is normal--however for occasional/intermittent use this is not a huge concern...
  10. Jun 2, 2017 at 5:45 PM
    ItalynStylion
    Steven
    DFW, Tx.
    All good points. The running of the cable is a piece of cake as I've done similar stuff for stereo amplifiers. Additionally, most inverters of that size have their own integrated hardline switch on the inverter itself. And I'm aware the alt won't make 130 at idle. I've been searching and I can't seem to find what it makes at idle since I know that's a concern. I suppose I could measure it but that would be tricky to get a solid read.
    All of that being said, if Honda or Yamaha didn't fucking gouge so hard for those little generators I'd own one already lol! Those seem to be the ONLY two kinds worth getting. Anything else is just a loud piece of shit for the most part.
  11. Aug 22, 2017 at 11:00 PM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Bought my truck used but think it might have a factory tow package. Is there an easy way to tell which alternator is installed?
