OEM Radio Malfunction Prevalence
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacomaatw, Sep 15, 2009.
Have you had any malfunction with your OEM radio?
Poll closed Oct 15, 2009.
  1. Yes!
    117 vote(s)
    57.6%
  2. No.
    74 vote(s)
    36.5%
  3. Don't know. Replaced it with aftermarket too quickly to know.
    12 vote(s)
    5.9%
  1. Sep 19, 2009 at 7:35 PM
    #41
    Raven65
    Raven65 Well-Known Member
    Camden, SC
    '09 Magnetic Gray Reg Cab 5-Lug
    Curt hitch, D-rings, bed mat
    I'm on my second defective factory radio in my '09. The first one started acting flakey the day after I bought the truck and the replacement lasted a couple of months before it started behaving the same way - and worse. I'm either going to wait until my warranty is almost gone (to give Toyota time to come up with a better "fix") and then have the dealership replace it again - or I'm just going to punt and buy an aftermarket unit. I prefer the factory look of the stock unit - but it's a POS even when it works properly. I'll probably go aftermarket.
  2. Sep 19, 2009 at 7:58 PM
    #42
    applawman
    applawman Well-Known Member
    OBX
    '12 DC SB Pre-Runner
    Had my 09 since May 31 with no problems so far. Although I have only put about 2800 miles on it since then....and I usually use the steering wheel controls.....
  3. Sep 22, 2009 at 3:00 PM
    #43
    nascrlvr
    nascrlvr Active Member
    Baton Rouge, LA
    Pyrite Mica Tacoma
    cruise, VS wipers, tint
    Bought our '09 in January. The radio turns itself off and on, the volume control won't work. Can't seem to connect it with being in the sun, etc. Took the truck to the dealership. They were very familiar with the problem. Immediately ordered a replacement. It has now been six weeks. Talked to the service manager; he said still about 2-3 weeks away from receiving it. Ridiculous!!!.......
  4. Sep 22, 2009 at 5:29 PM
    #44
    Raven65
    Camden, SC
    My replacement unit is getting worse by the day. Same problems (turns itself on/off, volume knob stops working, display goes blank or displays jibberish, etc.)... just happening more and more often.
    I also HATE the low sound level of the Aux. input jack. It's almost useless. I had my iPod plugged into it on the way home today and was trying to listen to a podcast with the windows down and could NOT make it loud enough to hear. Both the iPod and the radio volumes were maxed out and I had to roll the windows up to be able to hear it - and even then it was barely loud enough to hear over the road/wind noise (and I was only going 55-65 MPH). Ridiculous! Whoever allowed this POS radio to make it to production in this truck should be fired immediately.
  5. Sep 22, 2009 at 5:39 PM
    #45
    Dashe
    Dashe Well-Known Member
    David
    Charleston
    Black Double Cab SR5 4x4
    debadged, Grillcraft grille with FJ emblem, KC SlimLite Driving Lights behind grille, Bilstein 5100's, Eibach 1.6" lift springs, add-a-leaf, Pro Comp 7089 wheels, BFGoodrich A/T 285/75/16, Dynomax Super Turbo muffler, CB with Wilson Flex antenna
    yeah, i have an 09 and i just had a problem the other day. it was about the hottest its been in the cab since i got it, and the buttons stopped responding. i found some inspiration from the fonz and quickly remedied the situation. im just hoping this problem doesnt persist.
  6. Sep 22, 2009 at 5:58 PM
    #46
    03blk27
    03blk27 Active Member
    Manson MA
    18 Sand Storm double cab short bed TRD Off Road
    Stock
    09 single cd, first one acted up one mile after rolling off the lot. The second one is just starting to act up now, i just cant belive there letting this go like they are and just slaping the same shit back in.
  7. Sep 22, 2009 at 5:59 PM
    #47
    devilsalmostfree
    devilsalmostfree Well-Known Member
    Carl
    Loudon, Tn
    99 Tacoma 4X4, 5 spd, 2.7 ltr
    Deck plate mod, intake silencer removed, AFE Pro Dry S Air Filter, debadged, Goodyear Duratracs 265/75R16. Flowmaster knock-off muffler!
    theres a few of out work trucks, 00 tacoma, 1 4X4 & 1 or 2 2wd trucks that have radio mafunctions. they will turn off on thier own, & sometimes the volume button won't work.
  8. Sep 22, 2009 at 6:07 PM
    #48
    nelztaco
    nelztaco Well-Known Member
    Neil
    Levittown, PA
    09 TRD Sport DCLB 4x4 SW
    UNDERCOVER, EIBACH COILS, TSB 4 LEAFS, TRD WHEELS, 255/85R16 KM2
    I've had my 09 for 3 weeks now no problems yet! I did notice that I can turn the radio on by hitting the mode button on the steering wheel. But I can only turn it on not off. Is the problem mostly with the JBL system? I have the 6 disc non-JBL system.
  9. Sep 22, 2009 at 7:20 PM
    #49
    Raven65
    Camden, SC
    I think the problem is mainly with the base single-CD non-JBL model - but the others may be crap too for all I know.
    If you have steering wheel controls, I think you're supposed to be able to turn the unit on AND off with the mode button. That's how it works in my wife's '07 Camry anyway. You just press it and hold it a couple of seconds and the unit will turn on/off.
  10. Sep 22, 2009 at 7:23 PM
    #50
    nelztaco
    Neil
    Levittown, PA
    Interesting I'll have to try that tomorrow. Thanx.
  11. Sep 22, 2009 at 8:11 PM
    #51
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Some customers may experience a distortion noise from the JBL sub-woofer. This condition can occur when listening to the CD, Satellite, or Auxiliary audio modes. An updated JBL amplifier is available to address this situation.
    See this T-SB-0164-09 file for applicability. NOT all 2009's are affected.
    I have had my 2009 since June 1st and I have had no known problems with my stereo and I have used it every day that I have driven it. I have used radio/satellite/CD/Aux with no problems.
    Good luck with those that are having difficulties, I feel for you.
  12. Sep 23, 2009 at 4:34 AM
    #52
    noocs
    noocs Member
    Boston
    09 Tacoma 2x cab short bed
    I have 09 and had the sames issues as everyone else here. I had the unit replaced a month ago and yesterday started having the same problems again. You think they would be able to figure this out.
  13. Sep 23, 2009 at 5:32 AM
    #53
    sammy
    sammy Well-Known Member
    Maryland
    '09 4X4 Reg. Cab, Debadged Barcelona Red
    seat belt chime inter. wipers debadged canvas top (Bestop)
    The maker of the radio knows there is a problem and they are re-designing the unit. That's why it's taking 6-8 weeks for them to come in. I'm waiting for my 3rd radio. I wouldn't be surprised if a TSB is issued sometime in the near future. Or they might send out little yellow stickers to place on the radio that states...
    "This unit may change stations and turn itself off and on without operator influence. Volume control should not be adjusted while driving"
  14. Sep 23, 2009 at 6:03 AM
    #54
    nascrlvr
    Baton Rouge, LA
    Pyrite Mica Tacoma
    The above-mentioned radio is the "plain vanilla" single CD, non JBL standard radio. I forgot to mention that in my description. Maybe this will help clarify who exactly is having problems with which specific radio!!! Thanks for all the posts!!
  15. Sep 24, 2009 at 6:48 AM
    #55
    rutherk1
    rutherk1 ElPhantasmo&TheChickenRunBlastarama
    09 Silver TRD 4door
    I got mine to work. Right when it turns off, punch the front of it as hard as you can. It will come back on but then the display will have cracks.
    I went through 2 before I threw it in the garbage and put in aftermarket.
    Too bad about the quality of these things.
  16. Sep 24, 2009 at 7:02 AM
    #56
    fishshooter
    fishshooter Well-Known Member
    Northwest Florida
    09 Super White TRD Off Road 4X4
    Stock
    The "mode" button below the tuning button. Press it once to turn the radio on, hold it down for a few seconds to turn it off.
    No problems with my 09, yet.
  17. Sep 24, 2009 at 7:48 AM
    #57
    SManZ
    SManZ Sold the Taco in June 2020
    Fauquier County, VA
    Current, 2020 Ford Super Duty Tremor, Previously 2010 Supercharged 4x4 Tacoma Sport 6-spd
    TRD Supercharger, King 2.5" extended travel remote-resi coilovers, OME Dakar leaf packs, King 2.5" extended travel rear shocks, Total Chaos UCAs, MBRP turndown exhaust, TRD intake, TRD Quickshifter, Goodridge SS brake lines, EBC Sport Rotors, Hawk HPS pads, TRD FJ Cruiser Special Edition 16" Anthracite Rims, Spidertrax wheel spacers, 265/75R16 A/T, Autometer oil pressure, oil temp gauges, TRD boost gauge, PLX DM-100 OBD II scanner, flexpod mounts, A-pillar gauge pods
    I've had my '09 about 2 weeks and have had problems with the radio. I'm going to mention it to the service staff when I take it in to have a scratched when I bought it subwoofer and loose overhead console fixed. It seems to crap out when its hot. Today's a warmer day so we'll see if the radio craps out.
  18. Sep 24, 2009 at 8:57 AM
    #58
    SubZombie
    SubZombie Well-Known Member
    South East
    2019 Voodoo TRD Pro
    I haven't had any problem of any kind with the radio in my '09 (built the end of July '09).
    It is a 6-disc changer though and I think the problems were in the single disc players.
  19. Sep 24, 2009 at 9:06 AM
    #59
    09REG.cabTaco
    09REG.cabTaco Well-Known Member
    Patrick
    San Antonio, Texas
    09 reg cab 4x4SOLD..08 AC trd sport 4x4
    5100s front and back set at 1.75, BHLM, upper grillcraft
    better just to replace it i went through 3 the first 3 months of having my 09 i finally bought an aftermarket. makes it louder and doest mess up everyday
  20. Sep 25, 2009 at 10:41 AM
    #60
    onevoodooz
    onevoodooz New Member
    At first it would just switch off on it's own and I wasn't sure if it had something to do with the way I was using the aux input for my Ipod. Then I realized it was the radio, switching itself off and also on, or conversely, not being able to switch it off, control the volume or switch between FM and Ipod inputs. Not as loud as I think it should be, the fader and balance controls also reset themselves.
    Dealer told me 3-4 weeks, which is now going on 6-8 weeks. I always intended to install a an aftermarket radio, but would like to be sure that the problem is only with the radio and not something that includes the rest of the electrical system. To upgrade before I know for sure would give the Dealer and excuse to void the warrantee. so I am waiting to be sure that everything is sound before I upgrade.
    I may try to convince the dealer that the radio comes on automatically that startles me, and causing an unsafe driving experience. That might get their attention and motivate them to replace the radio a little faster. Just a thought anyway.
