OEM Roof Rack Install
Discussion in '2nd Gen. Tacomas (2005-2015)' started by YumaTRD, Dec 4, 2010.
  1. Dec 9, 2011 at 8:28 AM
    #41
    easyeatlanta
    easyeatlanta Artificial Intelligence beats natural stupidity
    Eric
    Memphis
    14 DC Trd Off Road
    some guy did mod one and had a write up for how to make one fit on an access cab
  2. Dec 9, 2011 at 9:10 AM
    #42
    DATZ WEAKSAUCE
    DATZ WEAKSAUCE Well-Known Member
    San Jose, CA
    17 DCLB TRD OFF ROAD LT PROJECT
    im having my co worker ask some guys he knows at toyota about the issue ill let you know. but that yellow clip looks the same as a door panel clip i would try and use that as long as the prong is big enough for the hole to fit snug it will work..
    the fitment issue would never happen with a honda part:p
  3. Dec 9, 2011 at 9:32 AM
    #43
    tarandus
    tarandus Well-Known Member
    Montucky
    '17 TRD DCab OR Supah White
    ProComp/Headstrong leveling kit, AllPro rock sliders.
    I've looked at a bunch of different clips and can't find it. If it is the same as the door clip, let me know!
  4. Jul 9, 2012 at 6:34 PM
    #44
    sonocotaco
    sonocotaco Well-Known Member
    ken
    Rohnert Park
    2016 TRD Sport AC 4x4 Super White
    On the front brackets, do you tighten them until the mastic(rubber) washers are flattened?
  5. Jul 31, 2012 at 7:24 PM
    #45
    Mick71
    Mick71 Member
    Mick
    Slower Delaware
    2011 Pyrite 4x4 SR5 DCSB
    Front Mud Flap delete, Extang Trifecta Tonneau, OEM Bed Divider, OEM Roof Rack
    I just got mine installed yesterday and think I managed to avoid the "gap of woe".
    My passenger side went right on with no problems.
    I could not initially get my driver's side to engage the yellow clip into the bracket.
    The problem appeared to be the ditch molding clip getting in the way.
    The directions clearly state to pop the vertical walls off this sucker, but I did not have to do that on the passenger side.
    Deciding that maybe those directions were there for a reason, I decided to try that. However, mine did not just pop off by whacking them with a trim tool as stated in the instructions. I had to use an X-Acto knife.
    Voilà! The driver's side yellow clip engaged as easily as the passenger side.
    Some additional information that may prove useful....
    1.) My yellow clips were pre-installed in the tracks themselves, not in the bracket as shown in the OP's pics.
    2.) I torqued everything down to the specifications provided in the directions. I used an el-cheapo torque wrench from Harbor Freight.
    The specifications are as follows.
    Bracket screws (2 each, pink thread lock): 117.7 lbf-in (13.3 N-m for our Canadian brethren)
    Also, as stated in the directions I let them sit for 5 minutes and re-torqued.
    The mastic washers clearly "squished" out at this torque.
    Front Rail screws (2 each, blue thread lock): 50 lbf-in (5.6 N-m)
    Long rail screws (3 each, green thread lock):117.7 lbf-in (13.3 N-m)
    Overall, I'm happy with the install. I have more pics if needed, but the OP did a great job in the original write-up. I'm just trying to add some additional detail.
    Good luck!
    neergtaco likes this.
  6. Oct 21, 2012 at 2:46 PM
    #46
    tacomacrazy
    tacomacrazy ExPo Truck
    Bryant
    Coral Gables, FL
    07 DC 4x4 TRD Offroad
    HIDs 10k & 3k, AFE Intake, LEDs Red Map & dome, Pioneer 4300 Walker Evan 2.5 coilover 2.0 rear with all pro expo leaf pack. SnugTop Campershell Famous Fab rear bumper/ tire carrier. Dual Battery System Upgrade 250a Alternator
    SO after you install OEM roof Rack have any of you installed a surco basket?
    and with the OEM crossbars is there a way to install the Surco basket?
  7. Nov 18, 2012 at 8:32 AM
    #47
    Midship909
    Midship909 Well-Known Member
    SocaL
    13 MGM 4x4 OR 6speed
    I was cracking my torx bits to get it to torque at 100lbs.
  8. Nov 18, 2012 at 8:35 AM
    #48
    OH-MAN
    OH-MAN Well-Known Member
    Sunny Az.
    10 4X4 O.R. White
    TRD skid painted black,
    Subbed
    Great write up
  9. Nov 18, 2012 at 8:37 AM
    #49
    nat
    nat Well-Known Member
    South San Francisco Bay Area
    2007 DC SB Tacoma
    Bestop, MP3 Aux Input
    Dude............inch pounds, not foot pounds.
    HUGE difference. Torx bits can handle that easily.
  10. Nov 19, 2012 at 2:25 AM
    #50
    Mendoman
    Mendoman Well-Known Member
    South Lake Tahoe
    2008 SR5 DCSB / 22 TRD OR DCSB
    6112/5100 RXT Option 1
    Hey Nat what kind of camper setup is that?
  11. Nov 19, 2012 at 7:40 AM
    #51
    nat
    2007 DC SB Tacoma
    Bestop soft top plus a rack I fabbed up.
    The Mendocino area is one of my favorite places to visit, I love it there.
  12. Dec 21, 2012 at 5:11 PM
    #52
    WarDamn
    WarDamn Well-Known Member
    Davenport, IA
    07 Tacoma
    I stayed out in the freezing cold to install this tonight and well.. drivers side went on fine. the passengers side did not come with the rail attached. The long bolt they provided has nothing to screw into. Someone mentioned a tab of some sort that can fall out. is this tab on the bracket? Does anyone have a picture of this? I have looked everywhere and cant find any extra parts...
    Thanks.
  13. Dec 21, 2012 at 5:15 PM
    #53
    aphex
    aphex Well-Known Member
    Pittsburgh, PA
    11 DC TRD OR
    Undercover Classic Tonneau, EGR Aerowrap Bug Deflector, Consolevault Custom Safe, Britax Boulevard 70 Baby Seat!, Retro TRD Shift Knob, Factory Bed Mat, Rear Leaf TSB, 265/75-16 BFG All-Terrain KO's, KMC Enduro Wheels, Front Bilstein 5100's set @ 0" w/ Toytec/Eibach Springs, Rear 5100's, TRD Grille Emblem, OEM Roof Rack, AntennaX 14" Billet Antenna
    If it is what I am thinking of, it's a square metal plate (maybe 1/2" by 1/2") with a hole in it. The plate should be inserted into a square hole underneath where the long screw goes in. The plate can fall out when you start to mount the rail (this happened to me) but it sounds like you didn't even get that far. Not sure if I can find a picture.
  14. Dec 21, 2012 at 5:22 PM
    #54
    aphex
    Pittsburgh, PA
    11 DC TRD OR
    Couple more things. The small plate is part of the rack. You would see it by flipping over the rack. Also, FYI, per the instructions the passenger side is supposed to come with the rail unattached. This is all by memory, so hopefully it's accurate.
  15. Dec 21, 2012 at 5:27 PM
    #55
    WarDamn
    Davenport, IA
    07 Tacoma
    Yes the rail was unattached. I can see in the screw hole and there is a clip shape that could hold some sort of a plate.. maybe it fell out in the bed of the truck. I am not sure.. will have to look in the morning.
    Thanks!
  16. Jan 1, 2013 at 12:41 PM
    #56
    TacoFMS
    TacoFMS Bubble bubble bubble pop
    Justin
    Louisa County, VA
    Just a vehicle to take trash to the dump
    One or two things modded... Check out the build thread
    picked up a used rack and am wndering what to do about the mastic washers as i have none and cant seem to find any place that knows what they are let alone sells them. any ideas? i was considering maybe plumbers putty??
  17. Jan 1, 2013 at 1:58 PM
    #57
    IluvTEA
    IluvTEA Well-Known Member
    South Dakota
    '10 DC LB 4x4 SR5 Super White
    Cooper ST 265/75/16 on Flat Black TRD OR wheels, window tint, blacked-out badges, front mudflap trim, BHLM, Base Black Rear Bumper Swap, Color-matched grille, Custom Relentless Fab plate bumper powdercoated flat wrinkle black and "TACOMA" backlit with Drunknsloth LEDs, Camburg 2.5" coilovers, LR UCAs, Power sliding rear window, Back-up camera anytime, FX-R projectors/Morimoto 3Five Ballasts/D2S bulbs 5000K, Black WeatherTechs, heated TRD seats with Roadwire Graphite Leather, OEM Roof Rack, front mud flap delete, Black Level 8 Guardians, TreadWright 285/75/16 with KG ...
    I just installed a used roof rack last week. I used clear, all weather silicone. It's worked good so far. Roofer's tape would work good too, I've never used plumber's putty, but it sounds like it would do the trick.
  18. Jan 1, 2013 at 2:04 PM
    #58
    robm7
    robm7 Well-Known Member
    2012 TRD OR
    Installed mine last night. More tougher and complicated than installing the OEM Honda element roof rack.
  19. Jan 1, 2013 at 2:18 PM
    #59
    TacoFMS
    Justin
    Louisa County, VA
    clear silicone huh? im sure ive got some clear silicone for windows and doors around. prob gonna have to try that... is that the all weather stuff like you are talking about? thanks for the info too!
  20. Jan 1, 2013 at 2:25 PM
    #60
    IluvTEA
    South Dakota
    Yeah that should work. Check the packaging, it should have a temp range and make sure it matches the climate you live in.
    I'd suggest silicone-ing around the front holes and install the front metal bracket. Then test fit the rack on your roof, take it off, make any adjustments, add the silicone around the remaining bolt holes and then install the rack. If you squirt the silicone before you test fit, you can get silicone everywhere. I had to take the rack off and bend the metal brackets a little bit (they must've got bent up a little while they were off the truck).
    Good luck and let us know how it goes!
