OEM spare tire kit wrench or torque wrench?
Discussion in 'Recovery' started by justSomeGirl, Jun 21, 2021.
  1. Jul 23, 2021 at 7:44 PM
    cwadej
    cwadej Ballerina Award winner
    Right Here
    2011 Access Cab 4x4
    For jacking, consider that you may not always be on solid ground. I carry a board that's 14" by 9", 3" thick. I made it by glueing and screwing several layers of plywood together. This gives a larger footprint for the jack, which is needed in soft areas, and raises it so you dont have to work as much on the jack.
    Also, a folding 4 way lug wrench. This will clear any wheel width, provide more leverage for loosening and tightening, and more options to help others if need be.
    justSomeGirl[OP] and tacotoe like this.
  2. Jul 23, 2021 at 7:48 PM
    Lezdrivetacos13
    Lezdrivetacos13 Well-Known Member
    Texas
    2021 TRD Off-Road
    1" spacer (front), Helo wheels, 4 dogs.
    The torque spec for Tacomas is only 85 ftlbs. If you put some decent muscle into it, that will be more than enough to keep all the lugs on. As far as the fix a flat, you won't be able to take it anywhere after that to get it fixed properly. You would have to hope you did a good enough job or buy a new tire. I would just use the spare to get you to civilization and get it fixed correctly.
  3. Jul 23, 2021 at 8:03 PM
    tacotoe
    tacotoe Pastry Chef
    Nebraska
    `17 AC Sport MT
    ARE Topper, Icon aal, OEM Audio+
    So much great advice. It was touched on briefly, but learning where that factory jack is and how to remove the spare, just using everything in general is a great idea prior to having to do it because of a flat.
    My brother text me last week after he had gotten a flat and was saying what a puzzle it was for him trying to figure everything out. (He's not very mechanically inclined). And I told him, yes, and then you need a degree in oragami to fit all that stuff back in the bag.
    Yep your on the right track.
  4. Aug 7, 2021 at 7:13 PM
    Desert Dog
    Desert Dog Well-Known Member
    Los Gatos
    2007 DCSB
    Work in progress
    Amen to practice at home. I was on trail with a friend who has a Tundra and he got a flat. We spent 15 minutes trying to lower his tire from under the truck using the same method you would use with the Tacoma. We had the long handle crank thing in the right place but it would not engage the lift mechanism. Finally I got a flashlight out to see why and something look weird because the slot that the crank should go into was not a slot. That’s when my friend said he had this thing in the glove box, he wasn’t sure what it was but remembered the dealer saying something about tire. Turns out he has OEM wheel locks and Toyota not only put wheel locks on each wheel but they also attached the same wheel lock thing on the tire lift mechanism. And what was in the glove box was a matching adapter that snapped on the end of the crank handle for it to work. Fortunately he still had the adapter in the truck but had he practiced beforehand, we could have avoided needless frustration.
