OEM struts and shocks question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BONTONWHO, Sep 28, 2008.
  1. Sep 28, 2008 at 1:46 PM
    BONTONWHO
    BONTONWHO [OP] Active Member
    Caliwaii
    05 PreRunner 4.0
    My rear end seems to bottom out driving out of a drive way- i do have a shell on my truck but i think it could be the shocks. Have any of you had to remove and replace front struts / shocks? Im going on 85000 miles and just purchased some BFG A/Ts. WOW- what a difference!! Thanks
  2. Sep 28, 2008 at 2:00 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    you are way outta warranty now, but there is a tsb that replaces the rear 3 leaf spring pack with a heavier duty 4 leaf pack. new shocks will help a bit....go with billy 5100's front and rear, but you really should look into getting an aal(add a leaf) for the rear springs. with that, you shouldnt have any more bottoming out problems, plus aal's arent too expensive either.
  3. Sep 28, 2008 at 2:06 PM
    BONTONWHO
    Caliwaii
    05 PreRunner 4.0
    thanks again for being on it AGAIN! i'll look into both suggestions. i think the TSB was taken care of but i'll confirm. I was planning on installing the B5100s but also came across brand new front struts and rear shocks off of a 09 tacoma with 30 miles on them for free. Thanks again brah
  4. Sep 28, 2008 at 2:13 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    no problem man......new stuff for free is always a good deal. hope you get it all worked out man!!
  5. Sep 28, 2008 at 3:21 PM
    linkfeeney
    linkfeeney Well-Known Member
    link the stink!
    Sewell, NJ Eh!
    09 Doublecab TRD Off-Road! Magnetic Grey!
    what's tsb??
  6. Sep 28, 2008 at 4:13 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
  7. Sep 28, 2008 at 4:13 PM
    BONTONWHO
    Caliwaii
    05 PreRunner 4.0
    TSB = Technical Service Bulletin
    A TSB is not a recall.
    AU001-05 FEB 06 Audio System - Amplifier Won't Turn OFF/Battery Drain
    AU001-06 FEB 07 Audio System - Quick Reference Diagnostic Guide
    BO001-06 JAN 06 Body - Front/Rear Window Runs Deformed
    BO003-05 MAR 05 Body - Overfender Refinishing Process
    BO004-05 APR 05 Body - Water Leaks Onto Front Floor
    BO018-07 NOV 07 Body - Bent Rear Tailgate
    BO022-06 NOV 06 Interior - Driver's Side Lower Dash Panel Poor Fit
    EG011-07 JUL 07 Engine Controls - Intermittent No Start Condition
    EG021-06 APR 06 Exhaust System - Ticking Noise Between 2,000-2,500 RPM
    EG043-05 MAY 06 Fuel System - MIL ON/DTC's/No Start in Extreme Cold
    EG046-06 AUG 06 Intake System - Air Intake Hose Rattle
    NV003-06 MAR 06 Body - Front End Rattle/Squeak on Bumps
    NV004-06 MAY 06 Interior - Front Seat Squeak Noise
    NV006-07 AUG 07 Body - Windshield Wind Noise at Highway Speeds
    NV007-05 JUN 05 Body - Front/Rear Popping/Knocking Noise on Rough Roads
    NV007-07 JUL 07 Body - Dech Side Panel Rattle
    PD039-04 SEP 04 Pre Delivery - Initial Calibration Of Compass
    PD075-06 AUG 06 Pre Delivery - TPS Initialization Procedure
    PG004-06 NOV 06 General - TPS Diagnostic Tips
    SS002-07 APR 07 Engine Controls - ECU Flash Reprogramming Procedure
    SU002-05 NOV 05 Suspension - Rear Suspension Noise
    SU006-07 SEP 07 Suspension - Harsh Rear Spring Ride With Heavy Loads
    TC004-06 JUN 06 M/T - Clutch Pedal Squeaking Noise
    Each TSB can be read and / or downloaded here.
    In cases where a TSB has more than one revision I have uploaded the latest revision only.
    There are a few other TSBs that I do not have PDF files for.
