OEM TRD Seat Covers
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Aggiesdm, May 10, 2012.
  1. May 10, 2012 at 5:28 AM
    Aggiesdm
    Aggiesdm [OP] Well-Known Member
    San Antonio
    10 TRD Double Cab
    ARE CX Shell with roof rack, bed mat, WeatherTech's, some tunes and thats about it.
    Hi, I recently bought a set of TRD seat covers for my 2010 DCSB TRD and I'm having trouble getting the head-rest covers on. I know that technically they aren't made for any year great than 2008 (because of side airbags), so I was wondering...have the headrests changed shape for the newer models? It seems to be the right shape, just a little too small. I can't get the velcro to meet underneath the headrest, and I've been pushing, pulling and tucking as much as possible. Any help or info would be appreciated.
  2. May 10, 2012 at 6:50 AM
    JaimeDawg
    JaimeDawg make me a sammich
    Jaime
    Las Cruces, NM
    2011 trd off-road prerunner custom paint
    black saphire metalic paint with TRD off-road chameleon, 8000k hids on headlights and fogs, led map lights, led corner lights, saftey first baby seat mod in backseat, white/amber drls, devil horn emblems, trd seat covers, trd cai (old version)
    I have the same problem for my 2011...I had a friend squeeze the headrest while I velcroed it...it'll stick if its in place once u adjust the headrest the Velcro wont hold....still trying to figure out a better way...
  3. May 10, 2012 at 7:03 AM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Diamond Bar, CA
    08 TRD Sport
    Estock
    I don't think they will fit...since 05-07 headrests are smaller...I think everyone else just doesn't run them
  4. May 10, 2012 at 7:50 AM
    Aggiesdm
    San Antonio
    10 TRD Double Cab
    I got another reply on another post, and the guy suggested that you just get a wide piece of velcro to bridge the gap that the larger head rest creates. I think I'll try this rather than deforming the headrest by stuffing and cinching. I'll let you all know if it works.
  5. May 10, 2012 at 9:55 AM
    Aggiesdm
    San Antonio
    10 TRD Double Cab
    I've decided to do that same and just take them off. I really only want the covers for the seats anyway. I cycle and run quite a bit and get in the truck sweaty all the time and it was starting to get funky, so hopefully these will help.
  6. May 10, 2012 at 10:36 AM
    ROGU3 PR3DATOR
    ROGU3 PR3DATOR Space Shuttle Door Gunner
    Jake
    Niceville, Florida
    MGM 2011 TRD Off-Road
    Lifted, Supercharged, Armored, and lots more
    That was me... Anyway it is possible to get them to fit and stay closed, it just deformed the head rest and was a PITA to do. I recommended a wide piece of double sided Velcro to fill the gap, but I can't say for sure that it will work as I have since switched to Wet Okoles. The head rests will deform if you force them into the covers with no modification. This was not visible until I removed the covers and I'm not certain that they have gone back to their original shape. But you can't tell with the Wet Okoles on anyway.
    To those that are running these covers on 08 and up trucks... They are not air bag safe. I would suggest that if you want to have these covers on, that you add some kind of provision to allow the seat mounted air bags to deploy properly in an accident. A slit down the side held closed by a strip or a few tabs of Velcro so its not very noticeable might be worth considering. Just my $.02. The safety issue those create and lack of back seat covers is why I switched to the Wet Okoles. Either way, good luck on the head rests if you try to make them fit.
