Off-Grid Engineering Dual Battery System Q&A
Discussion in 'Technical Chat' started by HeliMedic, Jan 5, 2017.
  1. May 4, 2018 at 4:11 AM
    #421
    tacoma16
    tacoma16 Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    The whole thing is so you can the proper voltage to charge the battery properly. So the booster pumps it to 14.6-14.8 volts so each cell of the battery gets charged (from what I have read). Your alternator should be able to pump out 13.8-13.5 volts under normal load if it’s similar to mine (without the diode).
    Here is another link for a booster. It’s states that your alternator plug should have some lettering that allow you to alter the stock alternator testing voltage if you will.
    https://www.tacomaworld.com/threads/mike-singer-voltage-booster-groupbuy-feeler-thread.541223/
    Joe23[QUOTED] likes this.
  2. May 4, 2018 at 9:49 AM
    #422
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    I'm thinking I might just install and see what happens.
    tacoma16[QUOTED] and ponts like this.
  3. May 4, 2018 at 9:10 PM
    #423
    ponts
    ponts Well-Known Member
    Make sure you confirm the connection type with Mike. Mine was a “LIN” (2016 Tacoma) style connector and he doesn’t make that connection type.
  4. May 5, 2018 at 11:59 AM
    #424
    Joe23
    Ya I was reading through there doesn't sound like it will work.
    Have you found any other solution or do you just plug in to charge
  5. May 5, 2018 at 12:03 PM
    #425
    ponts
    It won’t work as my is a LIN and he doesn’t make it for that type connection. I had to get a refund :(. I just plug in overnight every day or two. Soon I will have a renogy solar panel on the roof to do the top up.
    Joe23 likes this.
  6. May 5, 2018 at 12:36 PM
    #426
    Joe23
    I might need to look into doing solar then
  7. May 15, 2018 at 8:45 AM
    #427
    Tacomavkk
    Tacomavkk Well-Known Member
    Woodinville, WA
    2018 TRD Off-road DCSB Quicksand
  8. May 15, 2018 at 10:20 AM
    #428
    ponts
    Tacomavkk[QUOTED] likes this.
  9. May 15, 2018 at 10:23 AM
    #429
    Tacomavkk
    Woodinville, WA
    Glad it helped, please post pics and details of your install after since I’m interested in doing this as well. It looks like I should skip the off grid kit and buy parts separately to save money.
    ponts[QUOTED] likes this.
  10. May 15, 2018 at 10:25 AM
    #430
    ponts
    I agree! Had I known the issues of charging dual batteries with his kit I would of not gone that route. However I do love the battery tray!! Oh well live and learn! It may take a few months but hoping this new setup is in before the end of summer.
  11. May 15, 2018 at 10:30 AM
    #431
    tacofort
    tacofort Well-Known Member
    Joe
    Cincinnati, OH
    2017 Toyota Tacoma TRD PRO, Automatic, Cement
    Adventure Trailers Tacoma Habitat Pelfreybilt Rock Sliders Line-X Pelfreybilt Pro mid, Gas, Exhaust Reroute Skids Hondo Unholey Dash mount Total Chaos Bed Stiffeners Redline Tuning Hood Lift Struts Weathertech Floor Liners
    What issues do you mean?
  12. May 15, 2018 at 10:30 AM
    #432
    Tacomavkk
    Woodinville, WA
    Basically I should probably get his kit without the MLACR Im thinking. I like the trays as well.
  13. May 15, 2018 at 11:45 AM
    #433
    ponts
    My truck alternator will not properly charge 2 AGM batteries.
  14. May 15, 2018 at 11:50 AM
    #434
    tacofort
    Joe
    Cincinnati, OH
    Gotcha. Yeah, I know what you mean. I keep leaning towards replacing the alternator altogether with one that will output the correct voltage.
  15. May 15, 2018 at 12:02 PM
    #435
    tacofort
    Joe
    Cincinnati, OH
    The MLACR really is over-designed for what is needed for Tacomas and is an excellent piece of equipment, but fundamentally, it doesn't solve the fact that our vehicles standard alternator output a lower voltage. The redarc dc to dc charger is great for some of that, but it doesn't change that the primary battery will still likely not charge fully. And the MLACR doesn't like mixing and matching different battery types. Solar with a MPPT or redarc using a similar process for battery charging definitely changes the equation.
  16. May 15, 2018 at 12:10 PM
    #436
    ponts
    I’m new to this so thanks for the input. Why would the primary battery not charge fully?
  17. May 15, 2018 at 12:18 PM
    #437
    tacofort
    Joe
    Cincinnati, OH
    Correct me if I'm wrong, but my understanding of the way the 40 Amp Redarc DC to DC chargers work, they take the inputs (solar or alternator power) and push that to the aux battery to attemp to top it off similar to a MPPT controller. It's basically designed to correctly charge your auxillary system at 40A max and modulate voltage to optimize the battery's charge. The redarc does nothing for the primary battery to my knowledge. It still will be charged with the factory alternator. The factory alternator is designed to maintain correctly a starter battery, but not an AGM deep cycle. This is why a replacement alternator or a voltage booster are attractive options if you've matched batteries or replaced primary with AGM.
    Joe23 and Tacomavkk like this.
  18. May 15, 2018 at 3:41 PM
    #438
    Joe23
    mudyetti likes this.
  19. May 15, 2018 at 3:42 PM
    #439
    Joe23
    Ya issue is no one is making anything yet that works for the 3rd Gen
  20. May 15, 2018 at 3:43 PM
    #440
    bajatacoguy
    bajatacoguy Well-Known Member
    Johnny
    RI to NH
    Blk Taco
    OEM: Bed Mat Roof Rack Tri-Fold Tonneau Cover Door Sill Protectors KO2's Dobinson GTS Suspension TRD Beadlocks Timbren Bump Stops SPC UCA Rear SuperSpring SSO Slimline Winch Bumper SmittyBilt x20 Mobtown Sliders Mobtown Front Skid Avid Basket Bed Rack DECKED Draw Organizer Total Chaos Bed Stiffners Relentless Fab Bed Corner Tie Downs CBI Ditch Light Brackets ARB Dual Compressor Instant Air Tank Smittybilt RTT Road Shower II Indel-B Fridge/Freezer w/ Slide Ironman 4x4 Insulated Fridge Case Redline Tuning Hood QuickLIFT Yo_Hec - Center Console Molle Little Johnny III CB Radio KB Voodoo Flashlight Kit Switch Pro 8100 BlueSea Fuse Pelfreybilt Fuse Panel Mount Gecko - LED Bed Lights Gecko - LED Hood Lights Raptor Grill Lights Cali Raised - Bed Flag Pole Holder Center Console Tray & Organizer Weather Tech Floor Mats Weather Tech Hood Deflector TRAILER BUILD HAPPENING! Plate: Negan
