Off-Grid Engineering Dual Battery System Q&A
Discussion in 'Technical Chat' started by HeliMedic, Jan 5, 2017.
  1. Feb 12, 2017 at 7:04 AM
    #81
    TACOVRD
    TACOVRD I Identify As A Prius
    TW Addict
    AZ/WA
    2019 T4R ORP - Formerly 2013 DCSB OR Spruce Mica
    Workin' on it....
    Awesome, subbed.
    HeliMedic[OP] likes this.
  2. Feb 12, 2017 at 9:37 AM
    #82
    seoulja99
    seoulja99 Well-Known Member
    E.J.
    Oahu
    2012 DCSB 4x4 V6 TX Baja (1GR-FE)
    all things mall rated
    Correct. The compressor will be fine to the auxiliary battery. Mahalo, Matt!
    HeliMedic[QUOTED][OP] likes this.
  3. Feb 12, 2017 at 6:31 PM
    #83
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    coming from an electrician view point, when we do battery systems for UPS all cables must be the same length. It's even code for Canada and I'd imagine the US as well.
    Electricity will always take path of least resistance, if you have the battery separate you could end up picking up the negative off your starting battery instead of the Aux battery.
    Matt I agree with you, could be debatable but to me it should have its own cable.
  4. Feb 16, 2017 at 1:51 PM
    #84
    wmg
    wmg Well-Known Member
    bill
    2009 FJ
    BP-51 OEM LIFT..33;s...full skids....dual Batteries
    Just finished installing my split kit...WOW....not often is something once you have it turn out to be what you thought you ordered....Great kit, very hi quality material....easy to install...everything fit as it should, wires were long enough to fit up nice.....really very sweet.
    I installed the monitor control switch in the open pocket on the right side of the steering column in the back ...easy material to cut and work with, switch snapped in perfect, lots of room to run the wire harness inside the dash......its recessed far enough back to dim the LED shine, easy to reach etc......
    Tnx Matt for a great system.......
    16Tacos and HeliMedic[OP] like this.
  5. Feb 16, 2017 at 2:04 PM
    #85
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
    It's tight but all I do is remove the plastic engine cover. I do have to remove a battery to replace headlights, though.
  6. Feb 16, 2017 at 2:51 PM
    #86
    DaveInDenver
    David
    Grand Junction
    Unexceptional
    What's your rational for this?
    My feeling is that using the frame is generally fine, it's a better conductor than any cable so your drop will be lower than a long run of even 1/0. Just take your time, practice good workmanship and make sure you don't have a sneak path.
    Internet opinions might include people who have unibody cars. Finding a good ground outside of the engine bay on those might not be as simple as we have it with body-on-frame trucks.
  7. Feb 17, 2017 at 6:23 PM
    #87
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    I installed my kit today and like everyone else had no problems. It's a well made and thought out product that is pretty much plug and play.
    seoulja99 likes this.
  8. Feb 17, 2017 at 6:49 PM
    #88
    seoulja99
    E.J.
    Oahu
    I'm getting anxious for my kit to arrive! Two batteries already purchased and standing by!
    TURDGEN and HeliMedic[OP] like this.
  9. Feb 18, 2017 at 1:37 PM
    #89
    wmg
    bill
    2009 FJ
  10. Feb 18, 2017 at 3:30 PM
    #90
    DaveInDenver
    David
    Grand Junction
    Unexceptional
  11. Feb 18, 2017 at 4:22 PM
    #91
    HeliMedic
    HeliMedic [OP] Off-Grid Engineering
    Erie, CO
    Constant revolving door of Toyota vehicles
    Thanks! Im so glad you like it. Please let me know if I can do anything else for you
  12. Feb 18, 2017 at 4:35 PM
    #92
    HeliMedic
    Erie, CO
    My rational was absolute equality on resistance.... but what you say makes total sense and I completely agree. If I remember correctly @DaveInDenver you are an electrical engineer, so I suppose we can trust you ;)
  13. Feb 18, 2017 at 4:37 PM
    #93
    HeliMedic
    Erie, CO
    Looking good. The trays have also been narrowed by a half inch since the early rendition. The tie downs have also been made a bit thicker. The narrower base plate will only make oil filter access easier.
  14. Feb 18, 2017 at 4:38 PM
    #94
    HeliMedic
    Erie, CO
    Awesome. Thanks for the support :thumbsup:
  15. Feb 18, 2017 at 4:39 PM
    #95
    HeliMedic
    Erie, CO
    Yours is ALMOST ready. It will probably ship early to mid next week.
    seoulja99[QUOTED] likes this.
  16. Feb 18, 2017 at 4:41 PM
    #96
    HeliMedic
    Erie, CO
    DaveInDenver likes this.
  17. Feb 18, 2017 at 4:59 PM
    #97
    PennSilverTaco
    PennSilverTaco Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    I want to install one of these in my 2010 regular cab 2.7L, for the sole purpose of running two Cobra dashcams without using the key or killing my primary battery. I work at a bar and I want to have video evidence to sue for damages if any drunks damage my truck, intentionally or unintentionally.
  18. Feb 18, 2017 at 5:04 PM
    #98
    HeliMedic
    Erie, CO
    Sounds like a plan. The side-by-side system is what youre looking for. The tray will be new and improved... and on the website later this week. Let me know if you have any questions I can help answer.
  19. Feb 18, 2017 at 5:08 PM
    #99
    PennSilverTaco
    Charlie
    Thanks I'm gonna show your product to my dad and see what he thinks, then I'll be in contact... My dad bought me the truck as a gift and the title is in my name, but he is paranoid about modifications to the electrical system...
  20. Feb 18, 2017 at 5:10 PM
    #100
    HeliMedic
    Erie, CO
    Sounds good. Feel free to email me at matt@************** when youre ready
