Off-road capabilities of stock 4x4 TRD Off-Road?
Discussion in 'Off-Roading & Trails' started by solidcopy, Jun 18, 2010.
  1. Jun 18, 2010 at 7:02 PM
    solidcopy
    solidcopy [OP] High Speed, Low Drag
    WV
    2010 DC 4x4 TRD Off-Road
    I just picked up a 2010 Tacoma Double Cab 4x4 TRD Off-Road and am wondering what the off-road capabilities of the truck are in box-stock form. I plan to add a set of sliders to protect the truck before I take it on any trails.
    When evaluating a trail (prior to installing a winch) what should I look for danger-wise? What kind of inclines and obstacles will be to much for the truck to handle. I don't want to head out on the trails and get my new truck stuck the first time out.
  2. Jun 18, 2010 at 7:04 PM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    use your head.......that's all i can contribute
  3. Jun 18, 2010 at 7:08 PM
    BEEFY_CHEESY_TACO
    BEEFY_CHEESY_TACO DUDE MAN BRO
    Hot Carl!!!
    Roy UT
    2010 TRD-Off Road TACO Extra value package
    Icon Ext Travel w/ Resi Front and rear, Dakar leaf springs, total chaos UCA's, color matched rear bumper, color matched satoshi grille with black chrome TRD emblem, konig countersteer offroads (black) w/ 285/75 Duratracs, sockmonkey Trailiens 3rd tail light cover, Tacomaworld.com sticker (made by me), debadged all around, Relentless Front Bumper, Sliders, Rear bumper, and bed bars with Yakima rack w/ full size spare, shovel, hi-lift
    mine is still stock except wheels, main thing is just watch your ground clearance, ive been close a couple times. other than that its pretty much a beast and will climb anything.
  4. Jun 18, 2010 at 7:16 PM
    BirdTRD
    BirdTRD Unsuspectingly striking from above
    Greg
    New Mexico
    TRD Off Road 4x4
    Front (2.75" total): 1.6" Eibach coils, Toytec 0.5" (L) & 0.25" (R) top plate spacers, 5100's @ 0.85", Built Right uniball UCA's, Differential drop, Removed sway bar Rear: TSB springs, Wheeler's 1.5" AAL, 5100's, 2* shims, Carrier bearing drop, F and R Spidertrax, 285/75-16 Goodyear Duratracs, Self-fabbed sliders, rear bumper, and skid plates, Cobra 75 CB, Bed lined slim lo-pro tool box, Bed Extender, Diff breather mod, Two tail gate security mods, Exhaust dumped behind axle, Can't leave shit alone so plenty more coming...
    Ground clearance is by far the biggest limiting factor of a stock Off Road. Turn on the ATRAC and the locker and enjoy the crazy shit you can climb.
  5. Jun 18, 2010 at 7:16 PM
    StandingCow
    StandingCow Well-Known Member
    NJ
    09 SR5 4x4 V6 access cab
    Without any recovery gear, at least bring someone with you, have good strong D shackles and a recovery strap to pull one another out. I wouldn't go anywhere unfamiliar without someone else that has been in that area before.
    Without installing the rear diff breather mod, don't go into any water that would go over your axles, along those same lines, don't go into any water before you check how deep it is with a stick, because there could be deep ruts.
    You don't have a lift yet, so watch your clearance, and the factory skid plate isn't very strong, so just watch what is in front of you.
    Just use common sense and you will be fine.
  6. Jun 18, 2010 at 7:34 PM
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    X2 on bring a friend. The trucks limits may be one thing but your limits are another. Start small and work you way up. At least that how I did/doing it.
  7. Jun 18, 2010 at 8:10 PM
    solidcopy
    WV
    I am planning on getting a hi-lift jack and accessories (including shackles, chain, base and lift-mate) as well as a recovery strap and some chain before I head out. I am not going to be going out without at least a minimum of recovery gear.
  8. Jun 18, 2010 at 8:10 PM
    solidcopy
    WV
    Thanks for all the replies. I think I am going to wait at least until my hi-lift and rock sliders are on the truck before I head out anywhere.
  9. Jun 18, 2010 at 8:16 PM
    Andrew H
    Andrew H What is this "search" you speak of?
    Dirty Tucson
    2017SSMDCSBTRDS
    the truck is only as good as the person driving it.
    pow!
  10. Jun 18, 2010 at 8:17 PM
    broker
    broker Well-Known Member
    Broker
    Camarillo, CA
    2002 T4R
    Mostly Stock with a Roll Cage
    randy was with me when i did my body damage
    but stock form ive pushed mine to the max basicly and ive only gotten stuck once where the lifted trucks went where i couldnt because of ground clearance
  11. Jun 18, 2010 at 8:23 PM
    solidcopy
    WV
    The truck has P265/70R16 BFGs stock. Does the 75 aspect ratio make *that* big of a difference? I mean, I can understand going from the rugged trails to Mud Terrains but I really don't want to yank off tires that currently have only 100 miles or so on them.
  12. Jun 18, 2010 at 8:24 PM
    solidcopy
    WV
    That picture is why I am going to wait until I have sliders before I tackle anything serious! Damn, is your truck OK?
  13. Jun 18, 2010 at 8:29 PM
    solidcopy
    WV
    I didn't know about a trade-in deal of any kind. That totally changes things. In that case, yes, I think I will trade up to some decent tires. Assuming I am not going for a lift or anything crazy right away should I stick with All-Terrains or go for Mud-Terrains with the more aggressive tread?
  14. Jun 18, 2010 at 8:30 PM
    broker
    Broker
    Camarillo, CA
    2002 T4R
    yea nothing a 2x4 and a hammer couldnt fix. just a little paint transfer
  15. Jun 18, 2010 at 8:30 PM
    ProRacerNorm
    ProRacerNorm Member
    Norm
    Salem County NJ
    07 TRD Off-Road Lifted
    URD MKII Stage 3, Borla Cat-back, Doug Thorley Headers, ICPW Tail and Third Brake Lights, ToyTec Ultimate Lift Kit 3", GrillCraft MX Series Upper and Lower, Kenwood Double-Din, 18" RBP 94R with 285/65/18 tires.
    It is surprisingly not that bad i did more off roading before i lifted and modded my truck then after, I just haven't had any time or any good place to go in south jersey legally.
  16. Jun 18, 2010 at 8:36 PM
    solidcopy
    WV
    :bananadance:
  17. Jun 18, 2010 at 8:45 PM
    solidcopy
    WV
    I ran BFG ATs on an old truck and loved them, so that would be my first choice. The only thing I noticed is that the 75 aspect ratio tires are "not rated for severe snow" and the 70 aspect tires are. I can only presume this is due to the narrower footprint of the 75 series tire.
    $173+ BFGoodrich All-Terrain T/A KO Tiresource
  18. Jun 18, 2010 at 8:48 PM
    Jason'sLawnCare
    70 and 75 isn't the width. That's the sidewall height in percent of the width. Maybe the specific 75's you're looking at aren't siped?
  19. Jun 18, 2010 at 8:51 PM
    broker
    Broker
    Camarillo, CA
    2002 T4R
    i ran the bfgs ats 70 on my ranger when i lived in morgantown, they did awesome in the snow
  20. Jun 18, 2010 at 8:53 PM
    solidcopy
    WV
    You are probably right. After checking BFG's site, I couldn't find any difference. I will note that on the BFG site I noticed that the black sidewall in 265/75-16 revolves only 654 revolutions per mile vs 657 for the raised white letter version, making the all-black tire slightly larger, which is totally bizarre. I must be the only one that pores over specifications tables and sees the anomalies.
