Off Road Lights as high beams?
Discussion in 'Lighting' started by Dimestore55, Mar 6, 2017.
  1. Mar 6, 2017 at 11:00 AM
    Dimestore55
    Dimestore55 [OP] Well-Known Member
    William
    Richmond, VA
    2007 TRD OR Prerunner DCSB
    I ordered a set of 6.5" off road lights and I would like to wire them with a dash switch but I would also like them to come on automatically with the high beams. I drew up this quick diagram, could someone please check my work to see if this is possible. Are the diodes necessary and if so what size would you recommend?
    I also plan to use fuses on all + connections I just didn't add them to the image.
    ChadsPride, DustStorm4x4 and Chepo like this.
  2. Mar 6, 2017 at 3:50 PM
    Dimestore55
    William
    Richmond, VA
    Evening bump. Someone's got to know something about this.
    ChadsPride and DustStorm4x4 like this.
  3. Mar 6, 2017 at 3:51 PM
    bawoodfin
    bawoodfin @lifein4lo
    Blane
    Bozeman, MT
    2013 DCSB TRD Sport
    Icon Stage 3, 285 BFG AT, Leer 100XQ, Tepui Autana RTT.
    I'd be interested in a solution here too!
  4. Mar 6, 2017 at 4:11 PM
    Chepo
    Chepo Tankoma!
    Mexico City
    '11 TRD Sport
    Lots...
    Instead of using Diodes, I would only use both Relays and one fuse...
    how?
    87A from the first relay feeds 30 of the second... The fuse goes between battery and 30 of the first relay...
  5. Mar 6, 2017 at 4:34 PM
    RacecarGuy
    RacecarGuy Well-Known Member
    Houston, Texas
    '12 DCSB OR
    Pelfreybilt front and rear HC bumper w/swingout, BAMF LCA Skids, BAMF Diff skid, Pelfreybilt IFS and Trans skid, RCI gas tank skid, Bronze SCS F-5's, Icon RR's ext travel, Dakar leafs, Archive Garage shackle flip
    The diodes are so one relay won't back feed into the other. What I would do, is use a single relay and a single pole double throw switch.
    Pardon my crude paint skills :)
    This way, when the switch is in the up position, they'll come on with the high beams, but if the switch is in the down position, they come on manually. I have a similar setup with some LEDs on my rear bumper. They auto come on with reverse lights, or I flip the switch and they manually come on.
    VE7OSR and IronPeak like this.
  6. Mar 6, 2017 at 4:41 PM
    Dimestore55
    William
    Richmond, VA
    Genius!!!
    I'm not gonna lie, I had to think about that for a while but it makes total sense now.
    Thanks a bunch.
    Chepo[QUOTED] likes this.
  7. Mar 6, 2017 at 4:49 PM
    Dimestore55
    William
    Richmond, VA
    So in this scenario I would use a SPDT switch to toggle between each mode (high beam/dash switch) and then an actual dash switch + high beam feed in addition?
    Chepo likes this.
  8. Mar 6, 2017 at 5:01 PM
    RacecarGuy
    Houston, Texas
    '12 DCSB OR
    The switch takes either source and activates the relay. A simple SPDT switch will have three terminals on it, the middle terminal would go to the relay, the top one would go to the high beam signal, the bottom one would be any +12v source for manual activation. (You can use an add-a-fuse to get power from an existing circuit. I used a switched +, so when you turn the truck off, it will not be powered. If you use a constant+, you'll be able to manually activate them with the truck off too.)
    If you get a lighted switch, it'll have more terminals for powering the led backlight of the switch.
    Chepo likes this.
  9. Mar 6, 2017 at 5:02 PM
    Chepo
    Chepo Tankoma!
    Mexico City
    '11 TRD Sport
    Lots...
    THIS!
  10. Mar 6, 2017 at 5:37 PM
    Dimestore55
    William
    Richmond, VA
    Sorry guys, I'm really slow tonight. I understand now that I won't need an additional switch if I run a constant 12v to the bottom of the spdt. So when the switch is up it will be ready for a high beam feed and when it's down the lights will come right on, no diodes or additional relays necessary.
    Thanks a lot, end thread.
  11. Mar 6, 2017 at 5:42 PM
    Chepo
    Chepo Tankoma!
    Mexico City
    '11 TRD Sport
    Lots...
    Exactly, just make sure you fuse also the constant 12v...
  12. Mar 7, 2017 at 7:07 AM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    Of course you could simplify the whole thing even further if you simply use one relay to trigger your aux lights off of your high beams. Yes, this will mean that your aux lights will only come on with your high beams and / or every time you trigger your high beams you will get your aux lights. I wired my 30" LED bar (hidden in the lower grill) to come on this way, but have also used it on past trucks to trigger a set of 100 watt Hella 550 driving lights. Simple, yet effective.
  13. Mar 7, 2017 at 4:03 PM
    Chepo
    Chepo Tankoma!
    Mexico City
    '11 TRD Sport
    Lots...
    Yup, I have mine that way, but noticed that it would be useful as well to have them as OP says...
    Why? Because my 72w (in total) leds throw more light than my ~200w high beams... when the truck is off, and you need light, led is the way to go (without stock lights)
  14. Mar 8, 2017 at 9:34 AM
    HawkShot99
    HawkShot99 Well-Known Member
    Kingston, NY
    13' Silver DCLB TRD Sport - Sold
    What is the need for being able to turn on the Aux lights without the High beams? I feel you are making this far more complicated than you need to. When I wired up my Aux lights, I realized anytime I wanted them on, I would also be running my high beams.
    I bought a wiring kit on Amazon.
    https://www.amazon.com/gp/product/B01B0OAFE0/ref=oh_aui_detailpage_o07_s00?ie=UTF8&psc=1
    I have the trigger wire for the relay hooked up to my high beam fuse in the engine bay with a add-a-fuse. Ran wires into the cab for a override switch for inspections. Install took less than a hour and works super easy. Just turn on my highs and blind the world.
  15. Mar 8, 2017 at 8:37 PM
    RacecarGuy
    Houston, Texas
    '12 DCSB OR
    Not sure about the Op, but for me, I can use my rear floods, or front led pods with the engine off, as work lights. Mine are wired off of a aux fuse panel from a second battery, so even if I leave them on for days, I can still start my truck.
    Chepo likes this.
  16. Mar 9, 2017 at 8:22 AM
    HawkShot99
    Kingston, NY
    I totally understand having separate "work" lights off a separate battery. But are those work lights hooked up to be triggered by your high beams as well driving down the rd?
  17. Mar 9, 2017 at 3:21 PM
    RacecarGuy
    Houston, Texas
    '12 DCSB OR
    They're 4 D2 driving lights and a 20" Led bar as my forward facing "work" lights. Some are connected to high beams, some to foglight with foglight anytime mod. Ive used them on public road maybe once or twice in the middle of nowhere, but its mostly off-road usage. My rear lights are bumper mounted floods that come on when Im in reverse or when activated by pressing the button.
  18. May 25, 2017 at 6:41 AM
    cuda2k
    cuda2k Well-Known Member
    Jon
    Allen, TX
    BRM 15 TRD Off Road 4wd
    LVL8 MK6 wheels,SOS Sliders,Smked 3rd Brake,Gibson Exhaust
    This is how I'm wiring my aux reverse lights (of course I'm using a reverse 12v lead vs headlight source) and it works great.
  19. May 25, 2017 at 11:04 AM
    RacecarGuy
    Houston, Texas
    '12 DCSB OR
    Yeah, thats how I did my rear aux lights.
  20. May 27, 2017 at 2:07 AM
    Muddinfun
    Muddinfun Well-Known Member
    Key power-SPST dash switch-diode->terminal 85
    High beam wire-diode->terminal 85
    This way, you're using a simple switch, it always works, and the relay coil power is the only thing going through the diodes.
