Off-Road vs. Sport, and Access vs. DBSB?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Nrbeal12, Aug 20, 2017.
  1. Aug 20, 2017 at 10:09 AM
    #41
    Zanone_taco
    Zanone_taco Tacoma bruhhh
    Blane
    Humboldt county
    2010 white access cab Trd off-road
    Need more...
    I have an access cab and if you don't need the extra people than it's cheaper and the longer bed helps (same length as a DCSB) but I personally think sr5's are better because you can always color match and things like that easy. Instead of paying over a thousand for all that extra easy stuff. But that's just me :D
  2. Aug 20, 2017 at 10:11 AM
    #42
    RETR0spec
    RETR0spec Well-Known Member
    Sacramento, CA
    JDFab +4 LT
    reread it. he asks if you find yourself wanting crawl control, not that he needed it.
  3. Aug 20, 2017 at 10:12 AM
    #43
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    OR access cab with a 6MT is available only in Canada.
    TWTaco[QUOTED] likes this.
  4. Aug 20, 2017 at 10:13 AM
    #44
    specter208
    California
    Agree, but SR5 is not available with 6MT unfortunately.:(
  5. Aug 20, 2017 at 10:15 AM
    #45
    FHC
    FHC Well-Known Member
    Why am it so complicated? :confused:
  6. Aug 20, 2017 at 10:16 AM
    #46
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I did, it is still only available on the Automatic transmission, so I assume if he were buying the Off Road that was his interest.
    RETR0spec[QUOTED] likes this.
  7. Aug 20, 2017 at 10:28 AM
    #47
    Zanone_taco
    Blane
    Humboldt county
    Need more...
    True I go back and forth because some things I really like on the better models but also just think some things are to much to buy when I don't need it:confused:
  8. Aug 20, 2017 at 10:35 AM
    #48
    Spare Parts
    Spare Parts Well-Known Member
    Southern Maine
    2022 Off Road Premium 4Runner Lunar Rock
    From yota dot com
    I think the 16s were the same, but changed on 17s..maybe.
    Thunder Fist[QUOTED] likes this.
  9. Aug 20, 2017 at 10:41 AM
    #49
    Spare Parts
    Southern Maine
    I think access cabs have the 6 foot bed, while the double cab had a 5 footer. And the long bed is the double cab with a 6 ft bed.
    melikeymy beer likes this.
  10. Aug 20, 2017 at 10:42 AM
    #50
    Zanone_taco
    Blane
    Humboldt county
    Need more...
    Yes your correct but an access cab is the same length overall as dCSB I believe and the DCLB is obviously the longest
    Spare Parts[QUOTED] likes this.
  11. Aug 20, 2017 at 10:47 AM
    #51
    Spare Parts
    Southern Maine
    AHHHHH, I didn't read you post as overall length. :smash:
    Zanone_taco[QUOTED] likes this.
  12. Aug 20, 2017 at 10:48 AM
    #52
    Zanone_taco
    Blane
    Humboldt county
    Need more...
    Haha no worries, how's the short bed work for you?
  13. Aug 20, 2017 at 10:50 AM
    #53
    Spare Parts
    Southern Maine
    I miss the extra foot, but needed the double cab, and manual trans.
  14. Aug 20, 2017 at 10:52 AM
    #54
    shakerhood
    Southern Ohio
    What you are probably seeing is a forced option being added to the Off Road like the Towing Package. If you go up into the Sticky Section and look at the Cost and Options Thread you will see that the Sport and Off Road have the exact same price.
    Thunder Fist likes this.
  15. Aug 20, 2017 at 11:00 AM
    #55
    Tacoma1818
    Tacoma1818 Well-Known Member
    Legit question as I'm somewhat in the same boat as the OP:
    Are you saying this because of the terrain select mode or suspension? Or both? Or other?
    Curious as I'm looking at a sport (manual trans)and I'm in Ohio.
  16. Aug 20, 2017 at 11:06 AM
    #56
    Spare Parts
    Southern Maine
    But wouldn't they both have that same forced option?
    I'll go mess around on the site.
  17. Aug 20, 2017 at 11:06 AM
    #57
    Bigfsur
    Bigfsur Well-Known Member
    Don
    2017 White 7559 A/C 4X4 MT
    Clazzio seat covers Oem bed mat $35 china pro grill Snugtop Cab High W/ Yakima racks OME 886 suspension kit 3” Pelfrybilt steel front bumper/1200lb Smittybuilt winch Baja designs lights Switch pros 9100 Method 701 wheels CBI rear steel high clearance bumper
    As I understood the difference between OR/Sport in a manual is softer tuned shocks and locking rear differential. Correct me if I'm wrong, but to lock the rear diff, don't you need to be in 4low ?
  18. Aug 20, 2017 at 11:06 AM
    #58
    shakerhood
    Southern Ohio
    All of the above, the Off Road is just more capable in the extremes, you would still be fine in a Sport.
  19. Aug 20, 2017 at 11:08 AM
    #59
    shakerhood
    Southern Ohio
    I have owned 4 Off Roads and Toyota required the Towing Package when choosing the Off Road, no idea on what they do on the Sport but i would guess not forced.
  20. Aug 20, 2017 at 11:10 AM
    #60
    shakerhood
    Southern Ohio
    Also, Automatic has Crawl Control and Manual has ATRAC. Need to be in 4Low to lock the rear.
    Bigfsur[QUOTED] likes this.
