***Official 1st gen scangauge/ultra-gauge/torque readings***
Discussion in '1st Gen. Tacomas (1995-2004)' started by Justus, Jul 17, 2014.
  1. Jul 17, 2014 at 5:31 PM
    Justus
    Justus [OP] fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Just for the 1st gen guys/gals
    Post your method....... scangauge, ultra-gauge, torque app, or other (specify).
    Let us know what u watch and what numbers u usually see. Average temps, highest temps, worst temps while towing, etc.
    let us know your mods (if they may change things up) like a trans cooler, tow package, non tow package, supercharger, aftermarket exhaust, no cats, aftermarket cats, valve body upgrades, toolboxes, trailers, campers.
    If this trip was up a lot of grades, a hot day, a cold day, hauling a load (of), a long trip, etc.
    outdoor temps
    this way we can compare and get an average reading for those of us who use OBD2 and or other gauges.
    Ths way we have numbers to compare to instead of just running blind.
    I want to thank Ricks2013 for this idea!
  2. Jul 17, 2014 at 5:33 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    hopefully this becomes stick worthy............ may help MANY future questions, especially when someone gets a new OBD2 gauge and wants to know if his/her readings are acceptable
  3. Jul 17, 2014 at 5:40 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    lets get values on whatever u usually watch.
    trans temps, watertemps, voltage, fuel trims, cat temps, just your usual.
    No telling what a FUTURE user may be looking for.......... Lets not go nuts here, but just use the general numbers you look at personally, unless someone asks specifically for another parameter you dont usually look at, but wouldnt mind sharing?
  4. Jul 17, 2014 at 10:19 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 v6 Auto Trans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000K Driving Lights on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Doug Thorley Headers Magnaflow 18" Muffler w/upstream CAT delete 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    An interesting idea.
    Scangauge II. On the Gauge panel I have voltage, auto trans fuild temp, water temp and mpgs since last start. And I toggle to mpgs and miles traveled since last fillup on the trip panel.
  5. Jul 17, 2014 at 10:30 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    OK... As example on my second gen.
    Typical trans temp via Scangauge is around 160 on a 90 degree day...
    Tow package, v6 supercharged, toolbox with tools 150lbs, mesh grille.
    Volts around 13.7
    Intake around ambient at speed
    Water temp typically 185..... Never seen above 200 even up a large grade at 75 mph.
  6. Jul 18, 2014 at 9:02 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Bumpski
  7. Jul 18, 2014 at 9:33 PM
    Digiratus
    Roaming the PNW
    The RedHead
    There really isn't a typical trans temp. That temp is all over the place. The only time it is constant is on cruise control,on the highway, total flat-no inclines.
    What is more interesting in that regard is when offroad, on dirt, on a road smooth enough and not steep enough road to not require 4lo.
    What do to trans fluid temps do in that situation?
    Do you have the x-gauge code for HP?
    Water temp is dependant a lot on which thromostat is installed. Mine always run between 198* and 202*.
  8. Aug 24, 2014 at 8:03 AM
    MedicMutt
    MedicMutt Purveyor of Useless Information
    Josh
    Baton Rouge, LA
    '03 DC PreRunner TRD OR
    OME suspension, Whiteline bushings, Line-X'd Jason topper, GoRhino "Grille Guard", many more...
    Here's what I watch on my Ultra Gauge:
    System Voltage, normally around 13.5 - 14.2
    Engine Temp, 186 - 194 depending on driving conditions
    Intake Temp, around ambient while driving, varies in traffic
    Avg MPG, 18-19
    % Engine load, just there to help me with driving efficiently.
  9. Sep 28, 2014 at 6:24 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    bumpski
  10. Oct 1, 2014 at 5:49 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    bumpers
  11. Jan 6, 2021 at 12:08 PM
    Poncate
    Poncate Well-Known Member
    PNW
    04 DCSB 4x4
    Resurrecting an old thread
    just ordered an ultra gage and interested in mpg temp voltage etc
    for those that have them any issues or anything with it? I’ve read there may be limited support as they age out. Thanks
  12. Jan 6, 2021 at 12:12 PM
    Kwikvette
    Kwikvette Woke up and chose violence
    Salinas, CA
    1998 4Runner Limited 4x4
    King 2.5 Front/Rear, OME 890, 33s, Locked +
    There's a thread dedicated to Ultragauge I'm sure.
    Another for Scangauge.
    I have a flickering issue on my Ultragauge since day 1; it flickers maybe once every 20 or 30 minutes...almost like it "blinks".
    Been too busy to even mention it anywhere.
  13. Jan 6, 2021 at 5:47 PM
    MedicMutt
    Josh
    Baton Rouge, LA
    I don't think mine has done that, but it does appear to cycle through the gauges from time to time. Basically, the gauges disappear for a moment while the backlight remains on, and then reappear almost immediately.
    The only reason I swapped from my original Ultragauge to a new MX version is because I wanted to program it to read transmission temp. From what I'm reading here and seeing with my gauge, the transmission temp it displays may not be accurate. I need to find a way to get an actual temperature reading...
