OFFICIAL 2nd gen 4x4 front differential bearing vibration thread
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BenWA, Apr 17, 2011.
  1. Dec 26, 2015 at 5:19 PM
    #3041
    Old School
    Old School You are ignoring covfefe by this member.
    Sounds like your service advisor is an idiot, try talking to the service manager!
    Tell him tsb-0026-15
    scottalot and Kyitty like this.
  2. Dec 26, 2015 at 6:05 PM
    #3042
    Sub_Par
    Sub_Par Well-Known Member
    Buffalo NY
    2011 TRD Off Road
    Went in before I knew about the TSB for needle bearing and they said rears trans mount wAs all they could do under warranty and ordered parts. I came home found this thread and and TSB and called to ask about them about it, the service writer was rude and said he can't just order parts based on something I find on the Internet. So when I went back in to have them put the mount in I brought a printed copy of the TSB and handed it to him, they did the mount and said that the bearing was fine and had nothing to do with the vibrations. So I contacted the service manager and he apologized and told me to come back in and they would work on a fix and even gave me a loaner car. they called a few hours later saying rear driveshaft, ordered, few days comes in so they install. Call me and say ok that didn't fix the issue so it needs a front cv, ordered comes in and repaired and tell me it's driving great. I pick it up and as soon as I hit 40mph it does the same thing. So I call back and the service writer says oh there's no way it's doing it the tech said its fine and they replaced the bad parts, I explain its still doing it and he says well the tech drove another Tacoma and it did it to so its normal. And of course I remind him that the tech originally said its not normal and shouldn't be happening. So if it wasn't for xmas the truck would be back and I would be making sure the manager has them do the TSB. I'll update again once that happens.
  3. Dec 27, 2015 at 3:52 AM
    #3043
    ampmorocco
    ampmorocco Be KungFu!
    warren ohio
    2013 TRD Off Road A/C
    Stock TRD Off Road
    Got ya! Mine is an 08 with no warranty. I told them about the tsb. He kinda laughed n said there is nothing for that part. Just the frame and springs. So instead of dealing with the Stealership . i just orderd the bushing from ECGS seems to have good results so far.
  4. Dec 27, 2015 at 7:34 AM
    #3044
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    That's a different story. The TSB says it is only good while under warranty. :(
  5. Dec 27, 2015 at 10:45 AM
    #3045
    ampmorocco
    warren ohio
    Stock TRD Off Road
    I wish u guys luck! Hope it works out for yall.
  6. Dec 27, 2015 at 4:06 PM
    #3046
    Krackle3149
    Krackle3149 Active Member
    Joe
    2015 trd sport dcsb
    Stock
    Took my 2015 to dealer for the front end noise, first he told me it was the bug deflector making the growling noise and the smog pump as well, had to leave before I choked him out. Truck has 1400 miles, going to another dealer.
  7. Dec 27, 2015 at 5:48 PM
    #3047
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    See Build Page
    Bug deflector?!? WTF? I could see that causing a whistle maybe... But not growling! And if the smog pump is "growling" it needs replaced.
    :facepalm:
    It's not like they have to admit fault or something....
    MTopp likes this.
  8. Dec 28, 2015 at 2:22 PM
    #3048
    TRoss
    TRoss Web Wheeler
    NorJoJah
    '12 Reg Cab MGM 4 banger 5spd
    1.5" 5100 Billie lift, 1.5" AAL w/5125's, 265/75/16 Duratracs on SR8's, ECG diff bushing
    Just got my cat replaced...tried to get the needle bearing SB done...they said it wasn't making any noise...I said otherwise...guess I'll install the ECGS bearing that I've been sitting on. I have a 12 RC 2.7 stick
  9. Dec 31, 2015 at 10:14 AM
    #3049
    MTopp
    MTopp Professional bear handler
    05 SR5 4x4
    trifecta tonneau, pop n' lock, Depo black bezel headlights, mb 352 wheels, 265/75r16 cooper at3s, visors, colormatched 2011 grille with raptor LEDs, much LEDs in and out Future/wanted: black valence, hood scoop, catback, CAI, 285/75r16s, OMD leaf pack mod
    Try another dealer maybe if possible for you
  10. Dec 31, 2015 at 11:53 PM
    #3050
    jimhens714
    jimhens714 Member
    Rocklin, CA
    05 DCSB TRD 4X4
    3" lift, 285/75R16 BFG All Terrains, K&N filter, Snugtop shell
    Wow long thread...didn't read through all of it but I just replaced the needle bearing in my front diff. I did some searching on tools used and apparently the bearing can be pretty stubborn to remove. Worse yet it can break apart and some of the needles drop into the diff. I rented this tool from Autozone which is a slide hammer with expanding collets. The largest one fit perfectly. Unlike normal slide hammers with 2 or 3 fingers this one grabs the bearing full circle. It came out almost perfectly intact and was pretty easy to remove. I attached photos of the slide hammer set as well as the old bearing after removing it. You can see a slight bit of a bend to the edge of the bearing shell.
  11. Jan 1, 2016 at 11:00 PM
    #3051
    DefyInertia
    DefyInertia Saratogian
    Nate
    NorCal
    '05 DCLB 4x4 SR5#8 (white)
    Toytec Ultimate: ~3" up front via coil overs, LR UCAs, and SB delete; 2+ out back with AAL and new shocks. Leer cap, padded sleeping platform in bed
    Selling the bearing removal tool. $45 shipped to lower 48. Will ship elsewhere as well.
    Best to send me a PM as I no longer check this thread often.
  12. Jan 2, 2016 at 5:49 AM
    #3052
    TRoss
    TRoss Web Wheeler
    NorJoJah
    Eph the dealer... I'll fix it myself
    MTopp[QUOTED] likes this.
  13. Jan 3, 2016 at 9:00 PM
    #3053
    Cog
    Cog Well-Known Member
    Reno, NV
    This is awesome! I just watched a youtube video on how this works and it seems like it'll do the trick really well. Did you have enough room for the slide hammer to get it out? What all did you remove?
    What did you use to drive the new bushing in??
  14. Jan 4, 2016 at 11:59 AM
    #3054
    Cog
    Reno, NV
    Anyone have the install tool and driver I can use?
  15. Jan 5, 2016 at 3:54 PM
    #3055
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
  16. Jan 5, 2016 at 8:38 PM
    #3056
    MTopp
    05 SR5 4x4
    Anyone else gonna be needing the tools anytime soon? I'm sending them to @Cog this week, he could pass them on to the next member. Send me a message
    Matt T.
  17. Jan 5, 2016 at 8:39 PM
    #3057
    MTopp
    05 SR5 4x4
    75w-90 is oem oil, there's a diy on draining and filling the differential on tacomaworld. I think it's 1.6 quarts but check the diy first
    Link:https://www.tacomaworld.com/threads/front-diff-and-transfer-case-oil-change-howto.147631/
    PVT Pablo[QUOTED] likes this.
  18. Jan 6, 2016 at 1:14 AM
    #3058
    Hartford
    Hartford Well-Known Member
    Maine
    2011 Acc Cab 5spd
    75-85 is oem, but it can be hard to find so most everyone just uses 75-90. It's generally not a problem to go lower on the first number and higher on the second. Your going to need 1.6 or so quarts, one quart equals about .95 liters, so it might be cheaper for PVT Pablo to get two quarts lucas or mobile1 or some other quality 75-90 synthectic.
  19. Jan 6, 2016 at 1:02 PM
    #3059
    08TRDOFFROAD
    08TRDOFFROAD Well-Known Member
    Dan
    21' Tundra Platinum & 08' TRD Offroad DCSB 4x4
    Bilstein 5100's w/front's set at 1.75", TRD exhaust, Colormatched grill, Illuminated 4wd selector switch, BAMF Bolt on Sliders w/kickout.
    Here is the link to both the removal tool you used as well as the bearing race set.
    http://www.autozone.com/loan-a-tool...ind-hole-puller-set/391362_0_0/?checkfit=true
    http://www.autozone.com/loan-a-tool...and-seal-driver-set/391360_0_0/?checkfit=true
    Both of which, like you already mentioned, are available through Autozone's Loan-a-tool program, which I have used numerous times. This is the route I will go when I replace my bearing.
    I'm posting mainly to keep track so I have an easier time finding the information when I need it...lol.
  20. Jan 8, 2016 at 7:15 AM
    #3060
    scottclarkinco
    scottclarkinco Well-Known Member
    Scott
    Denver, Colorado
    2014 MGM TRD Off Road
    A lot. Check out my build page.
    Took mine in for the needle bearing TSB a few weeks ago. The tech claimed he couldn't hear or feel any vibration (which as with everyone else started once I lifted the truck). I told them I was shocked they couldn't feel it as it is definitely pronounced and can be felt. They called me back a few hours later and said they ordered the parts for the TSB. Took my truck back yesterday to have to work done. Dealer called later in the day.....they don't have the tool to pull the existing bearing. HAHAHAHAHAHAHAHAHA!!!! They put me in a luxurious 2016 Corolla for now. Hope they get it done today.
    As a lot of others have said....if you have this issue and you are still within the power train warranty period.....HAVE THE DEALER DO THE WORK! It's free, it's a NEW bearing (they aren't simply swapping with the same part) and if it comes back....then maybe look at the ECGS fix. But if it works and it's free, why wouldn't you? Also, be certain to take the TSB with you and insist on the repair. My service advisor obviously wasn't familiar with the TSB or the issue and was hesitant at first but when I insisted the problem is there and this is the fix I want, they did it.
    MTopp and Kyitty like this.
