OFFICIAL 2nd gen 4x4 front differential bearing vibration thread
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BenWA, Apr 17, 2011.
  1. May 9, 2012 at 4:19 AM
    #521
    ECGS
    ECGS Well-Known Member
    Chase
    RALEIGH
    Labor Charge for this should be 1.5 hours, 2 hours at the most with the tool. It is basically whatever the charge for replacing a CV axle plus 30 minutes. Now if the diff is dropped your looking at 3-3.5 hours. Our labor rate is $80 an hour so that should give you a range.
  2. May 9, 2012 at 9:35 AM
    #522
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    I tough on 2gen front diff if you split case you need to make sure R&P has correct backlash because case acts as giant bearing holder. :confused:
  3. May 9, 2012 at 11:47 AM
    #523
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    No, I thought he split the case because the needles were lost inside. Someone else removed the bearing from the outside when this happened before so why split the case?
  4. May 9, 2012 at 12:18 PM
    #524
    GP3
    GP3 Well-Known Member
    California
    4X4 TRD Off Road
    Front: stock suspension, 12" wide fiberglass fenders Rear: stock suspension, 10" wide fiberglass fenders
    Below is the post where he explains what happened.
    As for the 'someone else' you were referring to, he hammered the crap out of the bearing race to get it to finally break into pieces, and by doing so, he damaged the carrier. Not everyone is willing to take a BFH to their differential.
  5. May 10, 2012 at 7:52 AM
    #525
    HB Taco
    HB Taco Well-Known Member
    Curt
    Huntington Beach, CA
    2019 F150 FX4 S Crew 3.5 TT
    Anyone in OC Ca. done this? I'd like to do it but being my daily driver I'd feel more comfortable with an experienced hand helping. beer and cash provided. BTW Toyota denied my claim after taking it in for this because of lift - its ok because we all know the problem would return anyway.
  6. May 10, 2012 at 1:46 PM
    #526
    BassMaster06
    BassMaster06 Well-Known Member
    Dan
    South Carolina
    2006 Double Cab V6 4x4
    Mods: sand, dog hair, roof rust
    After reading through the majority of this thread, I'm certain I have this issue. I can feel a shudder/undulating vibration coming from the front of the truck from take off up til about 35-40 mph, as we well as coming to a stop, and it goes away when I engage the 4 wheel drive. I just lifted my truck w/ OME 885's and Dakars, and I felt the vibes as soon as I drove it. I plan on ordering the new bushing and tool. Forgive me for my lack of knowledge when it comes to this stuff, but how would I know if I need to replace anything else? Such as a new CV axle, bearing, etc.? I can't stand the vibration and I want to get this fixed ASAP, and do it right the first time.
  7. May 10, 2012 at 2:11 PM
    #527
    Koby
    Koby Well-Known Member
    Vancouver
    06 access trd
    2in OME suspension lift ARB bull bar 8000lb WARN 32`duratracs on 17 procomp 7033`s
    I'd replace the CV axle just to be safe since you have an older truck. I had the vibe the second I lifted my truck as well. One more thing to consider for you is 'takeoff shudder'. If your truck hesitates and shudders slightly when accelerating form a full stop, then this is another issue you may want to address as well. Check to see if you have the CB drop...if not get one...and if that still doesn't work, like mine, then going to a one piece DS will fix this problem. I had one fab'd up using part of my existing DS for less than 250 bucks. You'll be riding smooth in no time.:D
  8. May 10, 2012 at 2:40 PM
    #528
    BassMaster06
    Dan
    South Carolina
    Thanks for the reply. I installed the CB drop, as well as the diff. drop when I installed the lift. Some members on here have recommended that I remove the diff. drop and see what happens. Haven't had the chance to do that yet, but from all the research I've done, it doesn't really make a difference on the 2nd gens. As far as replacing the CV axle, I think I'll contact CVJ axles, as others have done in this thread. Thanks
  9. May 10, 2012 at 5:21 PM
    #529
    kieth
    kieth Well-Known Member
    British Columbia, Canada
    06 trd
    Full OME lift with Dakars, 886s and LR UCA's, Firestone air bags w\ onboard compressor, 2 kicker CVT 10" subs , MB Quart 1000w amp ,Alpine media player
    do you guys just engage your 4 wheel drive on the pavement going straight to see if the vibe goes away. Cause I dont know if i could notice it on the dirt or a gravel road?
  10. May 10, 2012 at 7:42 PM
    #530
    05Moose
    Jim
    Yes, that's the best place to test it for this. Find a smooth, straight section of road and engage. Give it a moment to observe the change, then disengage to confirm it returns. It'll be like night and day.
  11. May 11, 2012 at 12:54 PM
    #531
    BassMaster06
    Dan
    South Carolina
    Just ordered a bushing, tool, and seal. Pretty excited to see if this is gonna work for me. It was recommended that I replace the CV axle while I'm at it to be on the safe side. The truck has close to 80k miles on it. Should I just go ahead and get two new axles? Or should the passenger side be okay? Thoughts?
  12. May 11, 2012 at 12:59 PM
    #532
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    take a look at your cv axle before before spending money on gettin a new one
  13. May 11, 2012 at 9:00 PM
    #533
    Koby
    Vancouver
    06 access trd
    Just leave the passenger side one alone. That one is definitely not required.
  14. May 12, 2012 at 3:16 AM
    #534
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    Ugh, this stupid issue haunts me. I got mine fixed over 5k ago and even now, i still swear I feel it, but I'm pretty sure its just my tires, doesn't go away in 4WD lol. Waiting for it to return :( Could be wheel bearings for all I know.
  15. May 12, 2012 at 9:38 AM
    #535
    MikeluvstheTaco
    MikeluvstheTaco Well-Known Member
    Michael
    Saskatchatoon
    TRD Sport
    What was your fix? New diff? Or needle bearing? Or ecgs bushing? Im very interested to see how the ecgs bushing holds up.
    Thanks in advance
    Btw your sig pic is awesome!
  16. May 12, 2012 at 6:05 PM
    #536
    Skadumz
    Skadumz Well-Known Member
    Lehigh Valley, PA
    2008 tacoma dual cab, long bed, 4x4, TRD Spor
    3" lift 265/70/17 nitto, Grille Craft Grille, Tinted windows, 17x9 Moto Metals Matte Black, Carrier barring drop
    I purchased a new cv axel from advanced auto just incase and when I did the bushing I notices scoring marks on it so I replaces it. This will stop from tearing the bushing up. If you don't need it just return it.
  17. May 12, 2012 at 6:23 PM
    #537
    brian
    Elizabeth City, NC
    Thanks!.. with some serious help, I got the dealership to replace the diff at 92k
  18. May 13, 2012 at 7:17 PM
    #538
    kiteman78
    kiteman78 Member
    Hey, Just wanted to add my results. My 2005 had 65000 miles on it when I lifted it 1.75 in the front with billes, and 1.5" in the back with an add a leaf.
    Got the vibe right away. Drove the truck for 16000 miles with the vibe until putting the bushing in this weekend, and there was no wear on the CV shaft. Put in a bushing and new seal, took about two hours total and it's as smooth as can be.
    Couldn't be happier. The puller works great. I just unbolted the lower ball joint, pulled the caliper and tied it all out of the way.
    To get the shaft out past the clip in the dif, I drove two pry bars in between the CV joint and the case to put some tension on things, and took a punch and gave the joint a hit.
    Popped right out. The rest was totally straight forward.
    Been a while since my truck has ran this good.
    Thanks Chase for a great product.
  19. May 13, 2012 at 7:22 PM
    #539
    TOYOTA 09
    TOYOTA 09 Kicking Ass Since 1981
    Maine
    2009 SR5 MT 4x4 Access Cab
    Preview 2009 SR5 4x4 MT Black Sand Pearl (Access Cab) SUSPENSION ToyTec 5100 Billstein Coil Overs (3" Lift) Fox 2.0 Remote Res Rear Shocks Total Chaos UCAs Full Dakar Leaf Pack w/Extra AAL TIRES & WHEELS BFG AT KOs 265/75/16 load range E American Rancing AR-23 Wheels Borla CAT back exhaust AFE cold air intake w/custom TRD clear cover Satoshi grill w/Grill Craft insert Hella 500 behind grill lights Rigid Industries Backup lights Interior Custom LEDs and Bed Lights Backup Cam Anytime MOD Leather armrest and rear seat MOD Weathertech floor liners Custom rear gear/dog platform Cobra CB and Garmin GPS Bed Mat UWS low pro tool box with Custom LED lights Diff breather MOD Custom painted engine cover Wet Okole seat covers
    Anyone interested in doing a write up with pics? This may be above my skill level.
  20. May 14, 2012 at 10:50 AM
    #540
    BassMaster06
    Dan
    South Carolina
    Which write up are you looking for? There are videos and written instructions with pictures in this thread for the needle bearing removal/bushing install, as well as on the ECGS website, and their facebook page. I've also seen write-ups with pictures on how to remove the cv axle. I just did a quick search and this is the first thing that came up:
    http://www.tacomaworld.com/forum/2n...axle-replace-front-wheel-bearing-2nd-gen.html
    there are others floatin around out there too. good luck
