OFFICIAL 2nd gen 4x4 front differential bearing vibration thread
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BenWA, Apr 17, 2011.
  1. Jan 31, 2014 at 12:20 AM
    #1561
    eaglesfn5402
    eaglesfn5402 Well-Known Member
    alright thanks, now to find a diy guide. DIY is my only option being over here in Germany so any guidance would be greatly appreciated. I watched the video on how to remove and install the bushing, but I need a DIY guide on the steps before that.
  2. Jan 31, 2014 at 12:41 AM
    #1562
    eaglesfn5402
    http://www.tacomaworld.com/forum/2n...axle-replace-front-wheel-bearing-2nd-gen.html is this the steps taken in order to get to the differential bushing that needs removed/replaced? Did everyone else use the seal and race driver set or can the bushing be tapped in another way? also, if I follow the instructions in the link above (same link as on page one) do i need to get an alignment?
    Edit: DAMNIT! nvm I see it now on the first page. ordering bushing today from ecgs
  3. Jan 31, 2014 at 5:25 AM
    #1563
    wtmorgan1
    wtmorgan1 Well-Known Member
    Thanks for the headsup on the wheel bearings. I'm gonna take a look and check this weekend.
    Also, I'm trying to build my own tool because I have scrap plate and 3/8 threaded rod sitting in the garage. You guys who have a puller or have made one... Why does the tool have a weird oblong shaped plate on the end versus having a full size washer (complete circle) that is a hair less in diameter then the bushing? Is there something that gets in the way inside the front diff. I haven't pulled mine apart yet so I'm not sure what it looks like in there.
  4. Jan 31, 2014 at 5:47 AM
    #1564
    CorrosiveTendency
    CorrosiveTendency When up to your nose in shit, keep your mouth shut
    Nathan S.
    Schuylkill Co, Pa
    05' DblCab SB Speedway Blue
    OME 885's, Locker Mod. Bilstein 5100's on 4 corners
    I'm going to be doing this as soon as temps come up above freezing for a few days. What do you want for the puller? I can't believe they charge $60 for this thing thru ECGS, it is about $3.75 worth of hardware.
  5. Jan 31, 2014 at 6:01 AM
    #1565
    alpinebob
    alpinebob Well-Known Member
    bob
    alpine ca
    2008 Tacoma 4x4
    I have the ECGS bushing and new seal but need the tools and will rent or pay shipping for a loan.
    Thank you all, great info.
    alpinrebob, rlf494@gmail.com
  6. Jan 31, 2014 at 6:01 AM
    #1566
    nj636
    nj636 Hub Master General
    Kev
    Jersey
    OME lift 4x sliders 4x skids
    They make another $10 on the order charging $15 shipping when it cost $5 to ship a small flat rate box :anonymous:
  7. Jan 31, 2014 at 6:53 AM
    #1567
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    If it's slightly smaller to where it fits through the bearing and is still a circle, it would never grab the bearing. Aside from that, you also want it to be as wide as possible where it grabs the needle bearing otherwise you'll just bend the lips on the existing bearing and pop out the plastic cage with all the needles going everywhere. When you see the needle bearing up close, you'll understand how fragile it is.
  8. Jan 31, 2014 at 7:46 AM
    #1568
    Taco'09
    Taco'09 Well-Known Member
    ^^ Nope. Got to take it apart. But I don't think I would advise you to do so because the pass. side does not see side loads like the left. Also its just a stub shaft on the right that only sees work when the ADD is engaged. I suspect mine got beat up during extensive high RPM bench testing of the 4lo Trac mod when shock loading transfer through the diff. occurs as a wheel is braked. But am not entirely sure.
  9. Jan 31, 2014 at 7:56 AM
    #1569
    eaglesfn5402
    got it, all my questions have been answered except for two. 1. Is another alignment needed after doing this? 2. Is the seal and race driver set for $44.95 an absolute purchase to get the new bushing in? Or can it be done with another method?
    I'm about to call them to order as soon as question 2 is answered.
  10. Jan 31, 2014 at 7:57 AM
    #1570
    wtmorgan1
    Great point! Obviously if its larger its not gonna fit through there.
    I'll have to look back through the thread and see if anybody has given the dimensions of the oblong plate that grabs the bearing.
  11. Jan 31, 2014 at 8:55 AM
    #1571
    eaglesfn5402
    alright guys so now I'm on the fence about getting the bushing, I only drive to work literally 2 blocks and that's when the issue occurs. so tonight I went on a longer drive after getting home and the truck still warmed up I left the post and went up to 70mph on certain stretches of the road and I feel nothing now. can cold really effect it that much? maybe I should still get the bushing and install it anyway.
  12. Jan 31, 2014 at 9:01 AM
    #1572
    YOTA LOVER
    YOTA LOVER Stay Calm, and Fire For Effect
    NH
    2011 MGM Tacoma DCLB SR5
    A slew of pricey stuff my wife hates me for.
    Mine got worse in the cold, and was noticeable over a longer stretch of the speedometer. I'm less than pleased.
  13. Jan 31, 2014 at 9:30 AM
    #1573
    tacoma4
    tacoma4 Well-Known Member
    I knocked mine in with a 32mm socket turned around backwards and an extension. Got it in but it was a bitch. I rented the bushing press from auto zone but they were all to small so I had to get creative as I had no car to go anywhere lol.
  14. Jan 31, 2014 at 9:45 AM
    #1574
    eaglesfn5402
    good point, back to ordering it.
  15. Jan 31, 2014 at 10:30 AM
    #1575
    Taco'09
    ^^ 1. I think about everyone here would say an alignment is not needed. However, look at the the two bolt holes in the bottom of the knuckle. They are a bit oversize relative to the diameter of the bolts. So some movement can occur out of plane when it is bolted back together. Enough to substantially affect alignment?
    2. Lots of people have done this using sockets to drive the bushing in and PVC pipe fittings to set seal. BTW, the race driver set is a Harbor Freight tool. Look for one of their 20% off coupons.
  16. Jan 31, 2014 at 10:56 AM
    #1576
    eaglesfn5402
    thanks, I'm gonna look now.
  17. Jan 31, 2014 at 11:50 AM
    #1577
    uncleART
    uncleART Well-Known Member
    Arty
    Bothell, WA
    13 MGM DCLB Sport
    3" Toytec ULK 285/75-16 BFG KO2 Verge FN Wheels DeBadged, Toyota Bedmat, Window tint 30%, DeFlapped the front, Bilstein 5100s, Toytec coil overs, Dakar leafs, LR UCAs, SwayBar relocate, TRD Offroad tow hook, RotoPax, DeFlapped the rear, Tailgate mod, CBI receiver shackle w/ Bolt Hitch Pin, BFG KO2 285/75-16, FNWheels Verge, Weathertech Floor Liners, Spare tire mod, UWS toolbox with Bolt Latch Retrofit, Rear Diff vent relocated, Blacked-out grill emblem, Toolbox Bedrail mod, Trailer Plug relocated, ECGS bushing, Redline Hood Struts, Leer 100XR, C4 Fabrication Lo-Pro Bumper, Relentless Fab Frame Reinforcements, Warn 9.5XP-S Winch, Baja Designs S8 20" Lighbar, Off-Grid Engineering Dual Battery Tray, Odessey 35-PC1400 Batteries, BlueSea ML-ACR
    Dude! - just buy the tool already!
  18. Jan 31, 2014 at 1:01 PM
    #1578
    YOTA LOVER
    NH
    Use it to get the job done and sell it for $5 less than you paid. It's not like there is a lack of customers here on tw.
  19. Jan 31, 2014 at 1:16 PM
    #1579
    wtmorgan1
    I can make this tool in about 20 mins once I have the dimensions of the small plate that contacts the bearing. I can't see how anybody would pay more then $10 for something like this.
    Were talking about a metal plate, 3/8 threaded rod and washer cut to size bolted in place.
    I went ahead and ordered the ECGS bushing and seal. I will make the tool once I get the bushing. I'm gonna pick up a race driver from HF.
  20. Jan 31, 2014 at 6:26 PM
    #1580
    lilgerber
    lilgerber Well-Known Member
    Aaron
    Fresno, CA
    06 4x4 off road Speedway blue
    Front: Total Chaos 3.5 4x4 LT kit, Engage off-road one piece hood, Caged front end, TC gussets. Rear: Fiberworks fenders, King 14" 3.0 triple bypasses, boxed/braced frame, extended brake lines, 63" chevy leaf springs, U bolt flip kit, TC lower shock mounts. Preformance: URD intake, Doug Thorley headers, Flowmaster 40, 2.5 tubing. Interior: Weather techs, LED's, Double DIn, kicker 10" subs, Kicker componet speakers, Exterior: Method wheels with OMF beadlocks, Custom made bumpers, Retro headlights.
    I used a 5/8 x 6 bolt and the washer idea was to weak. So I made a plate beveled the back and threaded it.
