OFFICIAL - 3rd GEN 275/70r17 Tire Thread
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Haikin, Oct 6, 2015.
  1. Oct 19, 2015 at 12:40 PM
    #41
    99TacoDriver
    99TacoDriver Well-Known Member
    South Louisiana
    OME 885x/5100s/LR UCA/3 leaf AAL/275/70/17 Terra Trac X-Venture
    your link didnt work
    and yes there are KO2's in 265/70/17 load range C
    am i missing something?
    http://www.4wheelparts.com/Tires/LT...aspx?t_c=13&t_s=536&t_pt=101509&t_pn=BFG66255
    edit: uhhh total mind f'd atm... OZ-T posted a link and now it aint there
    anyway it may be because i have the stock shocks with a little revteck lift that fits over the coil...once i update my suspension that little block is being removed and a good set of billies is going in
  2. Oct 19, 2015 at 1:11 PM
    #42
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    I misread your post so I edited my post
  3. Nov 11, 2015 at 9:13 PM
    #43
    NV_Tacoma
    NV_Tacoma Well-Known Member
    Paul
    Northern Nevada
    2013 MGM ACLB TX Off Road
    2016 White DCSB TRD Off Road (Sold)
    OP were you able to figure you if they would rub on our stock trucks or would they work? It seems no one else has the answer yet.
  4. Nov 11, 2015 at 10:52 PM
    #44
    Haikin
    Haikin [OP] Well-Known Member
    No I decided to stay at stock size for warranty purposes.
    smitty99 likes this.
  5. Nov 11, 2015 at 11:05 PM
    #45
    twalchlii1
    twalchlii1 Tacotraitor
    Tom
    Wa
    2018 GC Trailhawk
    Are floor mats a mod?
    OP, I can tell you that you will need at least a small lift for the 275s. At full flex they will rub the lower control arms a bit. I have 3" lift, and my 265/70s run a tiny bit but only when at full flex. No big deal, just takes the paint off. As for mud flap rub, TAKE EM OFF! They will get torn off the 1st time you do any serious off roading anyway!
  6. Nov 12, 2015 at 5:07 AM
    #46
    gsxxr
    gsxxr Well-Known Member
    2016 tacoma trd sport
    3" lift, goodyear wrangler duratracs 285/70r17, k&n filter, bakflip vp tonneau and tint.
    Did you look I to the goodyear wrangler duratracs?
  7. Nov 12, 2015 at 5:30 AM
    #47
    BlkTaco47
    BlkTaco47 Unhinged
    2018 TRD PRO Midnight Black Metallic
    What warranty would bigger tires void?
    Heepspo and border411 like this.
  8. Nov 12, 2015 at 6:14 AM
    #48
    Haikin
    Powetrain issues are possible from the added stress on the tranny/motor trying to push a taller/wider/heavier than OEM tire size. I am just going off what a buddy of mine told me who worked for Toyota as a service writer for several years. I'm sure it's fine since a lot of guys run larger than stock tires on here without issue, I'm just being cautious for now as I don't want any possible warranty situations to come up. My 16 already had the steering rack replaced since the one from the factory was leaking from the damn boot. Maybe you can see my concern.
  9. Nov 12, 2015 at 6:17 AM
    #49
    BlkTaco47
    BlkTaco47 Unhinged
    If that's true, even going with A/T's of the same size would void it as they are heavier.
  10. Nov 12, 2015 at 6:21 AM
    #50
    Haikin
    I'm purely going off what a Toyota employee aka my friend told me. I or he may be wrong but since I have already had one fairly serious warranty issue with the truck from the get go I am gonna play it safe at least until the factory warranty is up.
  11. Nov 12, 2015 at 6:48 AM
    #51
    BlkTaco47
    BlkTaco47 Unhinged
    Good plan. Right or Wrong, I'd do what made me feel comfortable about the new truck I just paid 40k for. :)
    SCas and Haikin[QUOTED][OP] like this.
  12. Nov 12, 2015 at 10:14 AM
    #52
    NV_Tacoma
    Paul
    Northern Nevada
    Has anyone else ran this size without any issues?
    619HiluxLover likes this.
  13. Nov 12, 2015 at 10:34 AM
    #53
    Bumrush
    Bumrush Well-Known Member
    Brian
    Middle TN
    16 TRD OR SB quicksand
    Hmm I was looking at installing this size with just 5100s up front to level. I was under the impression they would work with no rubbing?
  14. Nov 12, 2015 at 9:06 PM
    #54
    Green panther
    Green panther Active Member
    Billings, Mt
    2017 DCSB OFF-ROAD W JBL
    Kingcoils and rear w Toytec AAL TRD PRO 4 Runner Wheels 275/70 R17 Dynapro Atf10 Morimoto 5500k 35w HID Morioto LED fogs SSO Slimline Bumper
    I'm running 275/70 r17 Dynapro ATM RF10. They came highly recommended and I really didn't like the ride of duratracs although they looked a lot better. No rubbing on full lock but when I turn into ramped entrances I get a scrape of some type, very minor. I have DCSB SPORT and I removed the air damn.. Getting 5100's installed tomorrow to "level" the front which I imagine will alleviate the tiny rare rub
    619HiluxLover and NV_Tacoma like this.
  15. Nov 12, 2015 at 9:07 PM
    #55
    Green panther
    Billings, Mt
    I do also have the TRD PRO 4Runner wheels if that makes any difference
  16. Nov 12, 2015 at 9:32 PM
    #56
    NV_Tacoma
    Paul
    Northern Nevada
    Thanks for the help! Let me know if the 5100's fix it. I've been looking at a similar set up with the TRD PRO wheels as well. Have you noticed how much it rubs if you stuff the wheel? I don't want them to rub when I'm off road.
  17. Nov 12, 2015 at 10:13 PM
    #57
    Tacoma2GR
    Tacoma2GR Well-Known Member
    Hesperia, CA
    2020 TRD Sport 4x4
    I saw a 16' SR5 at the dealer running 280/70/17's but it had a level kit, nothing done in the rear though.
  18. Nov 25, 2015 at 5:19 PM
    #58
    Sir Taco
    Sir Taco Well-Known Member
    2016 TRD sport 4x2
    265 70 17 shouldn't have any problems...correct?
  19. Nov 25, 2015 at 6:34 PM
    #59
    Haikin
  20. Nov 25, 2015 at 6:38 PM
    #60
    Haikin
