Official Crawlbox BS thread!
Discussion in 'Technical Chat' started by HomerTaco, Mar 16, 2016.
  1. Mar 16, 2016 at 6:28 AM
    HomerTaco
    HomerTaco [OP] also HomerTaco Vendor
    HomerTaco
    HomerTaco
    HomerTaco
    There has been much discussion in multiple threads on this topic so why not make a reference thread?
    Crawlbox: aka "dual cases". An additional gear reduction case that installs between the transmission and transfer case to allow for a lower gear ratio than the stock transfer case low.
    Hints, tricks, and generally just some good info for those interested.
    I'll post up some pics,links, and additional descriptions soon.
    :turtleride:
    Links to vendor sources:
    1.Marlin https://www.marlincrawler.com/transfer-case/line-ups/tacobox
    2.RST http://rststore.rocksolidtoys.com/shopping/pgm-more_information.php?id=2&=SID
    3. Inchworm http://www.lowrangeoffroad.com/toyo...sfer-case/built-tacoma-double-case-setup.html
    glam shot just because:
  2. Mar 16, 2016 at 6:28 AM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Reserved.
    hoverlover and mcharfauros like this.
  3. Mar 16, 2016 at 6:32 AM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    Sub'd for the info. I might learn a thing or two.
  4. Mar 16, 2016 at 6:44 AM
    SMKYTXN
    SMKYTXN If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
  5. Mar 16, 2016 at 6:45 AM
    G.T.
    G.T.
    CONUS
  6. Mar 16, 2016 at 6:48 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Good idea
    I have something there is a clunk when shifting gears or a hard start with mine at least it sounds like the crawl box I'm thinking it might be the collar to the trans output it's almost like there is slop from forward to reverse. Other then that my T case itself could have a stretched chain. I've been trying to pinpoint it for a wile now I just haven't pulled the cases because i don't have the time.
    mcharfauros likes this.
  7. Mar 16, 2016 at 6:48 AM
    Haws
    Haws Well-Known Member
    Shawn
    Washington
    TRD Off Road
    Lot's of stuff (-;
    Ok you've got my attention...
    Cocolocobean likes this.
  8. Mar 16, 2016 at 6:59 AM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Haven't had mine long enough to know what is "normal" and what isn't. :oops:
  9. Mar 16, 2016 at 7:30 AM
    sander1036
    sander1036 Well-Known Member
    Snack Food Capital of the World
    02 SR5 TRD Double Cab 4x4
    THULE Roof Rack, Color matched grille w/ GrilleCraft, Toytec Ultimate, 33 x 12.5 Duratracs, Bushwacker Cut Out Flares, Cvt Mt Shasta, Cvt Awning, LEER Cap
    Subbed because :turtleride:
  10. Mar 16, 2016 at 7:33 AM
    SGTCap
    SGTCap Well-Known Member
    Cap
    Summerville, SC
    4x4 6-spd,
    37s, 4x4 6-spd, OME 886s, Allpro Expos, SOS sliders and front/rear bumpers,Rack,Skids, 4.56s, Lockers,Recon Winch, TJM RTT, Lots of tools, boxes and gear. Shaggy mutt behind the seat
    I've got the Inchworm crawlbox on order, hope to see it in the next month or so. I just got an FJ TCase minus the shifter
    I Have a 6-speed truck
    So here are my questions:
    If I can't find a factory FJ shifter cheaply and easily what are my options for twin sticks?
    What other parts should I be accumulating while waiting for the box?
    How does "Clocking" the tranfer case work?
    Does anyone have the drivesaft measurements so I can have my spare front (and rear if I can find one) modded before the install?
    hoverlover and Bfox like this.
  11. Mar 16, 2016 at 7:37 AM
    SMKYTXN
    Nathan
    Houston
    DCFB
    I should have a shifter for you, but I opted for the Front Range Offroad twin stick.
    I did not receive a crawl box shifter from lowrange when I ordered my inchworm box, but I'm hoping that was an oversight.
    Craig will have to explain the clocking as I haven't done mine yet.
    You'll need the mount for the transfer case, a DPDT momentary switch for the front ADD, and I'm sure there's something else that I'll figure out we need in the next couple weeks.
    hoverlover likes this.
  12. Mar 16, 2016 at 7:42 AM
    NwiTACO
    NwiTACO Big tars, little/no bed.
    Mark
    Indiana
    05 TRD Sport
    Custom Everything, 1 Ton Axles F & R
    balls, another thread to sub
    Chipskip, SMKYTXN and HomerTaco[OP] like this.
  13. Mar 16, 2016 at 7:42 AM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Here's a link to one source for a twin stick:
    http://www.davezoffroadperformance.com/store/twin-stick-shifter.html
    You'll need to fabricate a new crossmember to support the crawlbox so you need the mount:
    https://www.marlincrawler.com/armor/crossmember/crossmember-mount-hd
    Switch for the front actuator & prerunner blank to replace the 4x4 dash dial.
    Clocking raises the t-case up higher & allows for additional clearance.
    Ant's got the measurements for the driveshafts but I'd honestly wait until you get the cases in to do the shafts if possible. Every truck's got it's own variables...
    Glueman and Ugly Betty like this.
  14. Mar 16, 2016 at 9:26 AM
    PSU Taco85
    PSU Taco85 Señor Member
    optional
    '10 TRD OR mostly stock
    Plasti dipped hootus
    Shubbed
    SMKYTXN likes this.
  15. Mar 16, 2016 at 9:56 AM
    NwiTACO
    Mark
    Indiana
    05 TRD Sport
    More stick pron:
    Crawlbox and single stick FJ case
    Crawlbox and twin stick FJ case
    Oh and there's this too...my slight OCD had to have both H-L shifters in line so I made the twin sticks crossover-twins :D
  16. Mar 16, 2016 at 9:57 AM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Skillz... :cool:
    Manfred likes this.
  17. Mar 16, 2016 at 10:08 AM
    NwiTACO
    Mark
    Indiana
    05 TRD Sport
    Alot of it is still scraps from the shifter's on the twin stick I got from you
    Reminds me I need to take a pic of my "boot" for the twin stick to seal the tunnel up a touch
    HomerTaco[OP] likes this.
  18. Mar 16, 2016 at 10:19 AM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
  19. Mar 16, 2016 at 11:59 AM
    SMKYTXN
    Nathan
    Houston
    DCFB
    Everyone feel free to post up your skid plates and support mounts for the crawl box. I need some ideas!
  20. Mar 16, 2016 at 1:41 PM
    SGTCap
    Cap
    Summerville, SC
    4x4 6-spd,
    I have a spare transmission and mount so I'm hoping to find a spare crossmember I can modify and have prefabbed for my install. I readlly want the install to go quickly and easily by doing as much beforehand as possible.
    Is there a wiring kit or any advice/instructions availible for the front diff wiring?
