Official Crawlbox BS thread!
Discussion in 'Technical Chat' started by HomerTaco, Mar 16, 2016.
  1. Mar 30, 2021 at 11:02 AM
    #2221
    4Running Daily
    4Running Daily Long Live ZS
    Connor
    Tempe/San Diego
    1996 Toyota 4Runner
    I threw a tac weld on the end of the ball and ground it down until the fit was more snug. Worked well
  2. Mar 30, 2021 at 12:01 PM
    #2222
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    That's a good idea. I might have to copy you on that one.
    there's a lot of slop in that slot with the shifter.
    TacomaDad18 likes this.
  3. Mar 30, 2021 at 6:31 PM
    #2223
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Good lord. Removed my drop in bedliner since it was causing some nasty noise from the vibration. I think its worse now. The whole truck shakes so bad in rev or drive. Do i need to replace the bushings from the cross member? No way my motor mounts are causing this. About to retire this bitch and keep as my offroad vehicle and keep the runner for me. Wife can buy whatever she wants. Getting irritated with this damn truck
  4. Mar 30, 2021 at 6:34 PM
    #2224
    malburg114
    malburg114 Well-Known Member
    Las Vegas, NV
    2001 Toyota Tacoma TRD
    Mine vibrates from the thick mounts in drive or reverse but that’s from the poly motor mounts and tcase mounts. Been that way from day one of the crawl box
    Fernando[QUOTED] likes this.
  5. Mar 30, 2021 at 6:53 PM
    #2225
    02hilux
    Planet: EARTH
    Time for wonton :anonymous: and trailer queen
  6. Mar 30, 2021 at 7:26 PM
    #2226
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    So normal huh. Damn. Not fun putting around town
    Lol. You are such a bad influence.
  7. Mar 30, 2021 at 7:29 PM
    #2227
    02hilux
    Planet: EARTH
    Just encouraging you to chase your dream, lol. Isn't that why you bought the 4r? To tow your built taco
  8. Mar 30, 2021 at 7:49 PM
    #2228
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Noooooo. Lol. Although, that bitch dose have power. If it became a trailer queen, i would get a diesel
    waldeeeeen likes this.
  9. Mar 30, 2021 at 8:07 PM
    #2229
    betterbuckleup
    Ian
    Concord, CA
    Don't know how HMF built your crossmember for the crawlbox mount, but you could just try and take out the poly crawlbox mount and see if it's better.
    Did they use one of the premade ones that TG or marlin sells, or did they make one custom like what @cbechtold did?
  10. Mar 30, 2021 at 9:08 PM
    #2230
    malburg114
    Las Vegas, NV
    Put it in neutral at the stop lights or while sitting. Vibration goes away
    Fernando[QUOTED] and 6 gearT444E like this.
  11. Mar 31, 2021 at 5:34 AM
    #2231
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    I think they used the TG ones. I'll have to ask him
    Thats what i been doing. Goes back to normal
    malburg114[QUOTED] likes this.
  12. Mar 31, 2021 at 7:24 AM
    #2232
    cbechtold
    cbechtold IG: @corybechtold
    Cory
    Pleasanton, CA
    2001 DCSB SR5 TRD 4x4
    Yeah, that ain't TG or Marlin.
    malburg114 and Fernando like this.
  13. Mar 31, 2021 at 7:44 AM
    #2233
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    So its custom built. Pretty sure the bushings are poly tho
  14. Mar 31, 2021 at 10:40 AM
    #2234
    betterbuckleup
    Ian
    Concord, CA
    Oooh. Yea uhhh I'd take it back to them in that case.
  15. Mar 31, 2021 at 11:09 AM
    #2235
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Lol. You being sarcastic? I dont want to go back to there. So i need rubber bushings?
    malburg114 likes this.
  16. Mar 31, 2021 at 11:12 AM
    #2236
    02hilux
    Planet: EARTH
    Why not extend a 3/8" base plate to the crawlbox and buy a factory rf1a mount. That will solve your vib issue.
  17. Mar 31, 2021 at 11:12 AM
    #2237
    betterbuckleup
    Ian
    Concord, CA
    I mean kinda not really. Don't blame ya.
    I don't know what the front-side of that whole crossmember looks like and how it actually mounts to the crawlbox. As far as I can tell the only bushings I see are the outboard ones that mount the member to the frame.
    You could probably get some rubber sleeve bushings to replace those ones with, but not sure much that would make a difference with how those bushings & mount are designed.
  18. Mar 31, 2021 at 1:12 PM
    #2238
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    How would that solve the issue? You know my noobness lol . is that dropping some pretty coin? :spending:
    That would probably be my easiest route. I need to call HMF and find out for sure what they used
  19. Mar 31, 2021 at 2:07 PM
    #2239
    02hilux
    Planet: EARTH
    Your vibration is caused by the poly designed mount use between the tcase and frames on your truck. If you eliminate the HMF designed tcase mount and run a factory rf1a mount (not MC or TG), you'll eliminate the vibration. You'll have to extend a 3/8" flat plate from the factory crossmember to the crawl box tho.
    I'm running a modified piece from FROR with the factory mount at the front and have no vibration. But eventually I will eliminate the front crossmember and built a skid with the rf1a mount to support the weight. Hopefully there will be no vibration when that's done.
    cbechtold and Fernando[QUOTED] like this.
  20. Mar 31, 2021 at 2:19 PM
    #2240
    02hilux
    Planet: EARTH
    Extend like this piece. Stole the picture from MC
    Fernando likes this.
