Official Crawlbox BS thread!
Discussion in 'Technical Chat' started by HomerTaco, Mar 16, 2016.
  1. Jul 14, 2021 at 10:10 AM
    #2361
    cbechtold
    cbechtold IG: @corybechtold
    Cory
    Pleasanton, CA
    2001 DCSB SR5 TRD 4x4
    My dad's 4 speed Atlas leaks more than my Inchworm setup.
  2. Jul 14, 2021 at 10:31 AM
    #2362
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Interesting, do you know where from? Mine is bone dry outside.
    malburg114 likes this.
  3. Jul 14, 2021 at 10:31 AM
    #2363
    v5ensx
    v5ensx CARB legal is not CALI legal
    Yep. Nothing is leak proof... not even the mighty atlas
    cbechtold[QUOTED] likes this.
  4. Jul 14, 2021 at 11:08 AM
    #2364
    cbechtold
    Cory
    Pleasanton, CA
    The through pin o ring on the backside I believe. I'd have to ask him again.
  5. Jul 14, 2021 at 11:30 AM
    #2365
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    I've come around to largely running lighter oil in most things I own and am not in the "run the heaviest oil you can" camp.
    The biggest reasons are both flow and heat generation. Oil pressure is just a measure of a restriction in the oiling system, more is not always better. If you are running too thick of an oil, you may not be oiling (flowing) enough oil through the galleries to properly lube the rearmost main bearing on cold start or up to lifters...Same thought process about the pinion bearing in a diff or some of the upper bearings in a tcase, the thickness of the oil can actually starve bearings if things are cold. Happened to a handful of guys at KOH a few years ago when they were running super heavy gear oil without preheating and burned up thirds super early in the race.
    Conversely once things are warmed up, thicker oil will actually run hotter than thinner oil because of the increased viscosity is more resistant to flowing and can thermally break down if its too thick for the application.
    In the end it's all about having the right weight lube for the bearing clearances and application. 90w vs 140w probably isn't a huge deal in a tcase...Mine typically gets whatever is on sale or on the shelf at home.
    I'm probably biased because I live in the north and have to deal with below zero temps regularly in a variety of equipment at work and home.
  6. Jul 14, 2021 at 8:57 PM
    #2366
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Or you buy one on craigslist from some guy you never met, ask him if it leaks, trust him, go, and find out he was honest. :)
  7. Jul 22, 2021 at 2:17 PM
    #2367
    TacoEspecial
    TacoEspecial SSSlow
    Mark
    Sacramento
    13 Sliver TRD AC
    BAMF RCLT Deaver Fox 2.5 StopTech Dana 60 37s 475:1
    I finally got started.
    Put my crawlboxes in my truck Monday, no oil. :thumbsup:
    Then drove about 15 miles, 5 on the freeway to CaliFab to have them installed.
    Before pick:
  8. Jul 23, 2021 at 8:06 AM
    #2368
    Littles
    Littles Stupid is as stupid does.
    Bryan
    Elizabeth, CO
    3 tons of fun
    This just popped up if anyone is looking for a used inchworm setup. Likely setup for an auto.
    https://www.tacomaworld.com/threads/fj-case-and-crawl-box.730239/
    Fernando likes this.
  9. Jul 23, 2021 at 9:40 AM
    #2369
    Mothman
    Mothman Well-Known Member
    Advance
    single cab
    Low and slow.. chopped up on 35s
    Fernando and Littles[QUOTED] like this.
  10. Jul 23, 2021 at 9:41 AM
    #2370
    Mothman
    Advance
    single cab
    Also it was setup behind a 2.7 5 speed..
    betterbuckleup likes this.
  11. Aug 3, 2021 at 12:15 PM
    #2371
    TacoEspecial
    TacoEspecial SSSlow
    Mark
    Sacramento
    13 Sliver TRD AC
    My install is moving along.
  12. Aug 3, 2021 at 1:02 PM
    #2372
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    Triples I see?
  13. Aug 3, 2021 at 3:47 PM
    #2373
    TacoEspecial
    TacoEspecial SSSlow
    Mark
    Sacramento
    13 Sliver TRD AC
    Yes :thumbsup:
  14. Aug 3, 2021 at 8:08 PM
    #2374
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Very cool, what is it going in?
    TacoEspecial[QUOTED] likes this.
  15. Aug 3, 2021 at 9:12 PM
    #2375
    k_j_souv
    k_j_souv Well-Known Member
    NorCal
    3G OR DCSB, Dual Case, 42s
    You don't see triplets too often
    TacoEspecial likes this.
  16. Aug 3, 2021 at 9:18 PM
    #2376
    TacoEspecial
    TacoEspecial SSSlow
    Mark
    Sacramento
    13 Sliver TRD AC
    My Tacoma.
  17. Aug 3, 2021 at 10:03 PM
    #2377
    betterbuckleup
    Ian
    Concord, CA
    Rad!
    What made you go that route instead of just a doubler?
    M/T or A/T?
  18. Aug 3, 2021 at 10:33 PM
    #2378
    v5ensx
    You're the third person that have a triple toyota case setup in a tacoma.
    What's your final crawl ratio?
    2.28x4.7 or 2.28x2.28?
  19. Aug 3, 2021 at 10:48 PM
    #2379
    v5ensx
    The slower, the more control.... now that's how you walk your truck uphill.
    TacoEspecial and Fernando like this.
  20. Aug 3, 2021 at 11:00 PM
    #2380
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
