Official Crawlbox BS thread!
Discussion in 'Technical Chat' started by HomerTaco, Mar 16, 2016.
  1. Nov 7, 2021 at 1:57 PM
    #2501
    JordanTaco6
    JordanTaco6 Well-Known Member
    Jordan
    Any tips on a reasonable price to expect?
  2. Nov 7, 2021 at 2:50 PM
    #2502
    theesotericone
    theesotericone Well-Known Member
    Bishop CA
    $150 or less.
    Squeaky Penguin and Bigal90 like this.
  3. Nov 7, 2021 at 2:54 PM
    #2503
    Chucky_P_671
    Chucky_P_671 Member
    Charles
    Pittsburg, CA
    2005 Toyota Tacoma SR5 TRD 4x4 6 speed manual
    All pro long travel KING 2.5 remote reservoir long travel coil overs with adjusters Arb front locker with Nitro Gear 5.29 gears Cab mount relocation BAMF sliders Coastal Offroad front bumper Warn VR Evo 8s winch BAMF rear shock relocation KING 2.0 12 INCH remote reservoir with adjusters NITRO gears 5.29 gears with factory rear e locker Old man EMU drakkar heavy duty leaf springs Coastal Offroad rear bumper with dual swing out spare tire carrier and dual gas can holder Prinsu roof rack with light bar and storage cases Midland gmrs radio PRP seat covers Dirty life 17 x9 dt-2 beadlocks with 37 x 12.5 milestar patagonia mt Front and rear extended steel braided brake lines BAMF low profile bed rack Pro eagle 2 ton beast jack and mount Hilift jack and mount BAMF rear HD hangers not yet installed Trailgear crawlbox with FJ twinstick transfer case not yet installed Build continues.......
    Anywhere between 400 to 650 shipped.
    I was able to buy my fj tcase from ebay for 279 plus tax and shipping, total came out to $405.
    With the NWFab case, you can use your stock tcase as a donor and use any VF chain driven case after it. So you are not stuck to a 1st gen transfer case for options.
    This set up cost less than a trailgear or Marlin dual case.
  4. Nov 7, 2021 at 5:23 PM
    #2504
    v5ensx
    v5ensx CARB legal is not CALI legal
    So what's the total cost for a nwf setup? I helped a buddy built his dual case using tg adapter and a turbo 2.28 case for his 1st gen tacoma and it cost shy of $1k after tax.
  5. Nov 8, 2021 at 7:47 AM
    #2505
    Chucky_P_671
    Chucky_P_671 Member
    Charles
    Pittsburg, CA
    Was this a few years ago?
    Just shy of 1k is a great deal.
    From what i have seen for a 1st gen Tacoma the trail gear adapter is around 900 or so, before gears and bearings.
    With todays pricing a crawlbox is 2598 or around those pricing complete.
    With NWfab pricing for their kit i saw at 1400. Then you need a donor case to harvest the components. As VF tcases go, with NWfab any VFcase can be used after its case so the choices are not limited to 1st gen tacoma cases, and the stock may be used as a donor should the original tcase for a 1st gen is not available. A donor VF case can range from 200 to 600 depending on where its purchased.
    Even on the higher end for a donor tcase, it looks to be around 2k to complete before driveshafts, which is still 500 to 600 less than trailgear or Marlins options.
    If i am wrong, then i apologize. As anyone who could do dual cases less than what is available right now, big props to them. If so, i am looking for a 3rd case.
  6. Nov 8, 2021 at 8:07 AM
    #2506
    Maxx
    Maxx Well-Known Member
    It would be nice if someone made a 4.7 gear for the 2nd/3rd gen Tacoma T-Case. If I could re-gear the case then I wouldn’t bother with all the work required to run a second case.
    I haven’t really researched it but my guess is it hasn’t been done yet because it’s too hard, too expensive or both.
    TimberTiger and Jojee117 like this.
  7. Nov 8, 2021 at 8:16 AM
    #2507
    02hilux
    Planet: EARTH
    Dual case can still be assembled anywhere between 1 to 2k, depending on what you want. Wait for a 15-20% sale and you can get the adapter for roughly 7ish. If you're lucky and is able to find a turbo 23 spline case, that's where you'll save money. If not, you'll have to fork 300ish for the input plus some more for 21s rf1a. That's if you don't mind a 2.28/2.57 setup.
    It gets expensive when you add 4.7 gears. Overall, if you're able to built and assemble the unit yourself, it will be cheaper than buying a fully assembled unit. But if you're not capable of or don't know how to piece it together, then just smile and fork the 2500ish.
    slander likes this.
  8. Nov 8, 2021 at 8:34 AM
    #2508
    v5ensx
    Nope. Buddy bought the adapter spring of 2021 this year during their sale. Paid shy of 800 after tax. Did some local searching and found a 2.28 23 spline case for 200. Didn't have to buy mc/tg 23 spline input. Litterily put the adapter on the case and installed. Even if you add 4.7, the entire build will cost shy of 1900.
    02hilux likes this.
  9. Nov 9, 2021 at 4:30 PM
    #2509
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Just saw this update.
    https://www.instagram.com/p/CWEmMTBvwSS/
    I'm hoping to see their triple stick setup soon. Sourced my donor case today and will be ready to order a NWF box in a month or two.
  10. Nov 9, 2021 at 5:24 PM
    #2510
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Which truck are we taking about here :popcorn:
    Littles and jubei like this.
  11. Nov 9, 2021 at 6:38 PM
    #2511
    Squeaky Penguin
    Brett
    1st gen best gen! I'll post an update on that shitbox here at some point.
    We'll need to test out the NWF box on Blanca next year. And Holy cross, wheeler, etc. etc. :D
  12. Nov 10, 2021 at 6:48 AM
    #2512
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
  13. Nov 10, 2021 at 6:55 AM
    #2513
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    I use double low all the time here in the south east. 2.28 and 4.7. I mostly use 4.7:1 just trail cruising, I would hate life without all the different gearing options especially with a 5spd.
    theesotericone likes this.
  14. Nov 10, 2021 at 7:00 AM
    #2514
    6 gearT444E
    Deep South
    Herculiner Hootus
    maybe it’s the extra 0.29, what diff gearing for you have and what’s the first gear of the trans? I’d be at 229:1 in double low, almost going backward at that point. Obviously it’s nice to have when you need it but I can say if I was to do it all over again I’d have just got the 2.28 in the crawler box.
  15. Nov 10, 2021 at 7:03 AM
    #2515
    slander
    Hickory, NC
    5.29 and whatever the 1st gear of the r151 is. It's a V6 first gen.
    6 gearT444E[QUOTED] likes this.
  16. Nov 10, 2021 at 7:21 AM
    #2516
    cynicalrider
    cynicalrider #NFG
    Jersey
    :popcorn: I am keeping an eye out for a donor case too to potentially run this setup. Extremely interested to see how clocking it can go. Down to rebuild some floor panels, ain't much different than tubbing.
  17. Nov 10, 2021 at 7:43 AM
    #2517
    v5ensx
    You can always do it over again. I'm sure someone will be more than happy to buy your used 4.7 :D
  18. Nov 10, 2021 at 8:01 AM
    #2518
    02hilux
    Planet: EARTH
    2.28/2.57 should be good for automatic but not for a 5speed imo. But why not ran a 4.7 in the front case and run L4.7 H2.57 vs LL2.28/2.57. You get more flexibility with the 4.7 imo. 2.28x2.57=5.86 4.7=4.7 (you still have the option of L2.57) 4.7x2.57=12.08
    I use the LL2.28/2.57 H4.7 for majority of the time but every now and than, I find myself engaging the LL4.7/2.28 and H2.57. When there's guys who show off their LL2.28/4.7 or 10.34:1 atlas, I play along and do the "you're not that slow" and engaged the LLL 2.28/4.7/2.57 :rofl:only a handful of times when I find myself engaging all 3 is down a steep steep slope where applying the brake is still sketchy. But in those scenarios, I think my butt cheek gets the most out of it vs me enjoying it and pushing off the steering wheel.
  19. Nov 10, 2021 at 8:40 AM
    #2519
    Squeaky Penguin
    Brett
    I like the idea of more options, but I like the idea of not dealing with TG/MC more.
    I think dual 2.57 lows will be sufficient. And when I feel I need an upgrade in the future, I can put a different tcase behind it.
    Yeah, we really need an update here @NorthwestFabworks :D
    I also see their mentioned crossmembers and skids will be coming. Curious to see what they work up as I was planning on cutting off my stock transmission crossmember anyways.
  20. Nov 10, 2021 at 9:08 AM
    #2520
    02hilux
    Planet: EARTH
    I will never deal with failedgear. Guys I know who bought their parts also bought into their BS and horror experience. Recently, a fella I know installed their ram. Leak like crazy the second the install was completed and upon starting the vehicle after plumbing and got them on the phone and was told it's normal. After topping off for a week, he drove the vehicle to their HQ to prove a point. They initially refused to warranty the ram, saying oil drips from the ram is normal when you can tell the seal is blown internally to start with. Long story short, after some fuss, they "repaired" the issue.
    Same go for marlin. It's nonstop BS about this or that over xx months. Just glad I bought what I need when everything is somewhat in stock. They wouldn't be that bad of a company if they would focus some energy to other products they sell vs their RCLT. Not everyone is into RCLT or differential.
    A lot of these smaller company starts off good than struggle with supply and demand overtime. Hate to say it, but that's the truth. And for company who is actually growing and buying out other company, all they're doing is tainting the new business with bad service and bad reputation.
    For me, a future built will not be with a NWF setup but an Atlas.
