Official Crawlbox BS thread!
Discussion in 'Technical Chat' started by HomerTaco, Mar 16, 2016.
  1. Dec 19, 2021 at 8:14 AM
    #2581
    TacoEspecial
    TacoEspecial SSSlow
    Mark
    Sacramento
    13 Sliver TRD AC
    BAMF RCLT Deaver Fox 2.5 StopTech Dana 60 37s 475:1
    Are you shifting your crawlbox into neutral or your trans?
  2. Dec 19, 2021 at 8:26 AM
    #2582
    cnstaco
    cnstaco Well-Known Member
    CO
    17 DCSB OR
    Trans to neutral, box to neutral or high trans to park e brake unless in high. No grinding. TG was stumped wanted me to send the box back but I decided to live with it because there are no other issues. If I break it then it’ll come out for chromoly gears anyway. No metal in gear oil either changed it 3 times so far lol
  3. Dec 19, 2021 at 9:13 AM
    #2583
    TacoEspecial
    TacoEspecial SSSlow
    Mark
    Sacramento
    13 Sliver TRD AC
    I like running in 2.57 then add in the 2.28 cause shifting to 2.28 is so easy and sure.
    I also haven't done the locker anytime mod.
    I'm still fitting mine in and adjusting the shifters.
    cnstaco likes this.
  4. Dec 19, 2021 at 9:49 AM
    #2584
    02hilux
    Planet: EARTH
    I shift my case to whatever when ever... Sometime the truck move so slow, I wonder if I'm even moving at all. :mudding:
    cnstaco and TacoEspecial[QUOTED] like this.
  5. Dec 19, 2021 at 9:56 AM
    #2585
    TacoEspecial
    TacoEspecial SSSlow
    Mark
    Sacramento
    13 Sliver TRD AC
  6. Dec 19, 2021 at 12:40 PM
    #2586
    02hilux
    Planet: EARTH
    How's yours coming along?
  7. Dec 19, 2021 at 7:33 PM
    #2587
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    Normal with the park pawl in the auto not being happy with the extra gearing if there is load on the drivetrain. I was just discussing this with a buddy when I heard his auto ratchet when he went into park too quick
    malburg114 and 6 gearT444E like this.
  8. Dec 19, 2021 at 8:17 PM
    #2588
    malburg114
    malburg114 Well-Known Member
    Las Vegas, NV
    2001 Toyota Tacoma TRD
    Mines the same. Drive to neutral to park. Reverse to neutral to park. Listen to a jeep when they shift straight to park. Same thing.
    TacoEspecial likes this.
  9. Dec 19, 2021 at 9:47 PM
    #2589
    k_j_souv
    k_j_souv Well-Known Member
    NorCal
    3G OR DCSB, Dual Case, 42s
    Yep same here. I don't know what's going on, I just do the neutral trick that everyone is doing. Seems to be fine
  10. Dec 19, 2021 at 10:45 PM
    #2590
    Team_Jake
    Team_Jake Well-Known Member
    '99 4Runner Limited '01 Tacoma Xtracab
    Last I heard was “end of the year”, but that was over a month ago, nothing since then. I’ll post an update in this thread when I have news to share.
    jubei and whatstcp[QUOTED] like this.
  11. Dec 21, 2021 at 12:42 PM
    #2591
    Speedo
    Speedo Well-Known Member
    Sacramento, CA
    2006 dcsb 4x4
    Wrecked!
    Same boat here. I hard end of yr. They were about a month off on the time frame for the crawler so maybe by Feb. :fingerscrossed:
    whatstcp and Bigal90 like this.
  12. Dec 21, 2021 at 10:13 PM
    #2592
    v5ensx
    v5ensx CARB legal is not CALI legal
    Start to sound a lot like marlin.... lol..
  13. Dec 22, 2021 at 5:17 AM
    #2593
    bhigbee
    bhigbee Well-Known Member
    Barney
    Hayden Id
    Wrecked 07 DCSB
    35s, flatbed, rhino liner paint, SOS front bumper, JD Fab lca pivot, JD Fab inner fenders and some other stuff.
    Not even close. They were really great to deal with and very upfront with any delays they had when I got my crawl box.
    whatstcp and BassAckwards like this.
  14. Dec 22, 2021 at 3:52 PM
    #2594
    TacoEspecial
    TacoEspecial SSSlow
    Mark
    Sacramento
    13 Sliver TRD AC
    Pretty good.
    Everything's running fine just using a 3 1/2" long bolt for one of the shifters and I can still see and hear the road through the holes in my center console.
  15. Dec 22, 2021 at 5:10 PM
    #2595
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Did you go with a TG or NWF crawl box?
  16. Dec 22, 2021 at 8:26 PM
    #2596
    bhigbee
    Barney
    Hayden Id
    Wrecked 07 DCSB
    NW Fab. Hopefully after the holidays I can get it put in, along with the transmission that was mated to your fj case and a heavy flywheel.
    BassAckwards[QUOTED] likes this.
  17. Dec 22, 2021 at 10:28 PM
    #2597
    k_j_souv
    NorCal
    For the first several months I was driving with the shifter hole not properly sealed, the cabin was loud and you can hear the gears. After making a plate around the hole, putting a shift boot around the shifter and adding sound deadening foam, my cabin noise reduced drastically
  18. Dec 23, 2021 at 10:55 AM
    #2598
    TacoEspecial
    TacoEspecial SSSlow
    Mark
    Sacramento
    13 Sliver TRD AC
    As I was heading down the hwy listening to all the noise and my wife making a comment somewhere along the lines of how much I just f'd up my truck... I grabbed a towel and stuffed it into the two holes... in the center console and behold.... all was quiet
    Happy wife... :thumbsup:
    Went snowshoeing along ice house res.
    Saw Santa fishing, think I'm getting 37s :thumbsup:
  19. Dec 23, 2021 at 11:23 AM
    #2599
    02hilux
    Planet: EARTH
    Mine's pretty quiet. Can hold a normal conversation without yelling at each and playing deaf.
    TacoEspecial[QUOTED] likes this.
  20. Dec 27, 2021 at 8:36 AM
    #2600
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    Who has an option.
    I built a crawl box, marlin 4.7 chromoly gears, advance adapters case , TG adaptors. Etc haven’t gotten it installed so brand new.
    but I’m think of maybe selling it and going the NWFab eco box route instead.
    torn about what the right path is.
