Official Crawlbox BS thread!
Discussion in 'Technical Chat' started by HomerTaco, Mar 16, 2016.
  1. Aug 25, 2022 at 4:56 PM
    #3041
    tetten
    tetten Cynical Twat Waffle
    Andy
    Socal
    I don't have one but I think those of us cursed with noise sensitivity are screwed as far as crawl boxes go. I think I'm just going to start driving around with ear buds in anyway to drown out the retarded muffler I put in after 4-linking. :frusty:
    Jojee117 and wrmathis[QUOTED] like this.
  2. Aug 25, 2022 at 7:57 PM
    #3042
    mmthaswrong
    mmthaswrong Active Member
    2000 2.7 single cab
    I have probably about 1k miles on my ecocrawler and it's not really any louder than the stock single t-case. There is a slight rattle on decel but is only roughly from 2000-2500 rpm then it goes away.
    wrmathis[QUOTED] likes this.
  3. Aug 26, 2022 at 7:04 AM
    #3043
    Littles
    Littles Stupid is as stupid does.
    Bryan
    Elizabeth, CO
    3 tons of fun
    My throw out bearing is squealing like a stuck pig right now so it hard for to say for certain, but I do think there is a little less gear noise coming out the ecocrawler setup compared to my old 4.7s. I wouldn't call my 4.7s noisy, but there was some noise from them, and as @mmthaswrong said, I don't hear any noticeable gear noise out of the new setup.
    bhigbee, wrmathis[QUOTED] and jubei like this.
  4. Aug 26, 2022 at 7:55 AM
    #3044
    Buttskevin21
    Buttskevin21 Well-Known Member
    Kevin
    Washington
    2019 Brocoma, 37s, Lt, Dual Tcases, blah blah blah https://www.instagram.com/kevinjbutts/
    Stock-ish
    Gotta keep in mind, the 4.7 input is spinning about twice as fast as the stock 2.28/2.57, but yeah they scream for sure. I've had marlin, tg, inchworm, all about the same.
    TacoEspecial likes this.
  5. Aug 26, 2022 at 11:31 AM
    #3045
    6 gearT444E
    Deep South
    Herculiner Hootus
    in low gear yes but at high gear does it not spin the same? Mines noisy all the time lol
    slander and whatstcp like this.
  6. Aug 26, 2022 at 12:32 PM
    #3046
    jubei
    jubei would rather be doing something else
    NoCo
    White 2002 XC TRD and Yellow 1971 JEEP CJ5
    Stuff. Also things.
    I thought the same thing, but
  7. Aug 26, 2022 at 1:15 PM
    #3047
    02hilux
    Planet: EARTH
    Nothing a radio can't fix.... :rofl:
  8. Aug 27, 2022 at 4:07 PM
    #3048
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    It's fucking annoying. Whines like a motherfucker, like I have a SC. Shakes the truck like a hookers bed. But it's a game changer
    TacoEspecial, slander and Dan8906 like this.
  9. Aug 27, 2022 at 4:10 PM
    #3049
    Yota X
    Yota X Some say dresser, I say dryer.
    NW New Jersey
    1st gen
    ls turbo, tons, 40's and a partidge in a pear tree
    That's a classic backyard tailgate build! nice!
  10. Aug 27, 2022 at 5:05 PM
    #3050
    02hilux
    Planet: EARTH
    Whines because you're not using it enough :rofl:
  11. Aug 28, 2022 at 7:25 AM
    #3051
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    :rofl:
    :bananadead:
    You know, you ain't wrong :D
  12. Aug 28, 2022 at 2:26 PM
    #3052
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    I don’t know if I’m the anomaly but my crawlbox is literally invisible in high range. Zero extra noise from stock. TG adapters on a stock top shift case with 4.7’s in front of a stock chain case. My buddy’s 4Runner on dual gear cases is comically loud in high range though.
    BassAckwards and ToyRyd04 like this.
  13. Aug 28, 2022 at 2:32 PM
    #3053
    ToyRyd04
    ToyRyd04 Taco Transformer
    Greg
    Perryville, MD
    '04 PreRunner
    SAS'd PreRunner Diamond Axles Crawlbox
    Was going to mention the same thing, the only noise I did have was where the shifter tip was too long causing it to hit the counter gear. Quick flap disk and its quiet. Also running 85w140 vs 75-90 I'm sure helps a bit.
    Inchworm adapters, MC 4.7 gears, and the upgraded shifter spring. Assembled by myself.
  14. Aug 28, 2022 at 4:13 PM
    #3054
    02hilux
    Planet: EARTH
    Ones definition of quiet will defer to the other. I have other noise to worry about.
    v5ensx likes this.
  15. Aug 28, 2022 at 4:19 PM
    #3055
    HomerTaco
    HomerTaco [OP] also HomerTaco Vendor
    HomerTaco
    HomerTaco
    HomerTaco
    My shit is loud af.
    I just turn up the radio. :oops:
    Speedo and theesotericone like this.
  16. Aug 29, 2022 at 6:22 AM
    #3056
    v5ensx
    v5ensx CARB legal is not CALI legal
    I'm running the clockable inchoworm with mc 4.7 comp and it's not noticeable. I hear my tires more if anything.
  17. Aug 29, 2022 at 3:57 PM
    #3057
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    Same here more or less. Or at least maybe I just can't hear it over the noise of the MT tires. Running 75w90.
    Only time I really hear it is when it's not warmed up and you can kind of hear the gears rack back and forth/chatter on accel and decel.
    I thought about running 84w-140, but some of the shops I talked thought it would be too thick. Maybe I'll give it a go next time I drain it.
    ToyRyd04 likes this.
  18. Aug 29, 2022 at 5:01 PM
    #3058
    ToyRyd04
    Greg
    Perryville, MD
    '04 PreRunner
    I recommend trying the 85w140. I notice the shifter doesn't get nearly as warm as it did when normal driving with 75w90 but conditions change and everyone is a bit different etc. I feel the bearings can handle the flow of even the 140 when it's thicker. Definitely not for the chain case, that screen pickup is too fine for that thicker oil.
    jubei likes this.
  19. Aug 29, 2022 at 8:22 PM
    #3059
    betterbuckleup
    Ian
    Concord, CA
    Yea I'll be curious what kind of differences I notice on both noise and heat. that and if it affects how much metal shavings come out with each oil change.
    The 4.7 case shifter shaft gets god damn hot.
  20. Sep 7, 2022 at 6:15 PM
    #3060
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    I run the thick stuff in my dual lefty combo and it helps keep it cooler. I figured that fluid gets so hot in there anything to help it. Been running it for almost 8yrs now and no real issues. Still comes out clean and with normal amounts of shavings on there. When I lived up north in Illinois I used to warm the truck up in the garage with the rear case in N and the truck in gear to heat the fluid up, that helped when it was in the teens and single digits. If I didn't do that it made some odd noises and kinda dragged a bit.
    My crawl box is also loud as hell and always has been. My chatters real bad as I took off that extra thin gear on the 2.28 gears in my crawl box that was supposed to quiet things down, espcially off throttle going down a hill on the highway, it had done that ever since I installed my spartan rear locker. I am also running one of the ooooold school dual row bearings, I do have one of the upgraded ones on the shelf that I may someday install. Maybe that will quiet it down some.
