Official Crawlbox BS thread!
Discussion in 'Technical Chat' started by HomerTaco, Mar 16, 2016.
  1. Apr 18, 2023 at 6:41 AM
    #3141
    Operator8
    Operator8 Well-Known Member
    Woodland Park, CO
    2005 White Tacoma TRD OR
    SAS INW
    So I've been reading through this thread trying to get caught up. But I'm potentially up against a time crunch. Just got an email from Marlin that the tacobox is back in stock. I venture it won't stay that way for long though... I've seen some of the gripes about TG, but also posts like above (positive). For me the Marlin Tacobox is $3300 + shipping. The TG is $2578. NWF's offering is harder to calculate as I need to source more donor parts.
    So in short is the tacobox worth almost $1K more? If not, then I don't have to rush to get the TB. I know everyone has an opinion, and it's not quite a question with a definitive answer. But just looking for advice. Thanks!
    Current Truck specs: 05 Automatic. Locked Frt and Rear. On 37's soon to be 38's. Planning to get an FJ TC to move away from the elec knob.
  2. Apr 18, 2023 at 7:00 AM
    #3142
    ToyRyd04
    ToyRyd04 Taco Transformer
    Greg
    Perryville, MD
    '04 PreRunner
    SAS'd PreRunner Diamond Axles Crawlbox
    Lowest ratio you can go equipped with a NWF case is 6.60:1 (both chain 2.57 tcases combined)
    Lowest ration you can go equipped with a MC or TG Doubler is 12.0:1 (both chain and Gear 4.7 tcases combined)
    Both have pros and cons. Recommend checking out Grimm Jeeper gearing calculator to see what your final crawl ratio is with tires, etc. Will give you a better idea of what you want.
    http://www.grimmjeeper.com/gears.html
    Operator8[QUOTED] likes this.
  3. Apr 18, 2023 at 8:58 AM
    #3143
    Littles
    Littles Stupid is as stupid does.
    Bryan
    Elizabeth, CO
    3 tons of fun
    Between NWF and Marlin/TG, it's really a question of do you want to go slow, or really slow. Between Marlin and TG, I think Marlin has generally been considered the higher quality product. Is it worth $1k more? Meh. NWF is a top notch product, it's just the gearing tradeoff you need to consider. FWIW, I ran the Marlin case for 3 years, and just swapped it out last year for an NWF box. So far I don't miss the lower gearing.
    You're just down in Woodland Park, so I'd offer to let you drive mine so you can check out the dual 2.57s, but I probably wouldn't be able to meet up till the first weekend in May.
  4. Apr 18, 2023 at 9:26 AM
    #3144
    TacoEspecial
    TacoEspecial SSSlow
    Mark
    Sacramento
    13 Sliver TRD AC
    BAMF RCLT Deaver Fox 2.5 StopTech Dana 60 37s 475:1
    I have 2 crawlboxes from TG for 2yrs now and they've been just fine.
    TG was great in answering all my questions and getting me any parts and things I needed.
    Operator8 likes this.
  5. Apr 18, 2023 at 11:53 AM
    #3145
    Operator8
    Woodland Park, CO
    SAS INW
    Hopefully I catch up with you at sometime on the trails this summer! Would love to check it out in person.
  6. Apr 18, 2023 at 12:13 PM
    #3146
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    I will say 12:1 is not needed a ton. However I used it on a few spots on the rubicon and what was originally sketchy was so much smoother with that ratio and I was very happy to have it. That being said 90% of the trail I did in the gear case (4.7:1) as 12:1 is just too slow. So really it depends on how you plan to use your rig. Hard trails? Possible consider marlin/TG. Not so hard NWF should fit your needs. I’m terms of marlin vs TG. Go Marlin, it’s a better design. Almost everyone here with TG went that route because Marlin was unavailable for so long. They seem to be doing better with keeping the taco box on the shelf this past year.
    good luck.
  7. Apr 18, 2023 at 12:25 PM
    #3147
    Operator8
    Woodland Park, CO
    SAS INW
    I do a decent mix of trails out here in Colorado. This year I do plan to tackle some of the harder trails, to get my experience up. Summer 2024 is when I plan to run the Rubicon, and Fordyce, and would like to be running a T-Case by then. I'm kind of looking at the TG and Marlin from a point of diminishing returns with the Tacobox being $1k more. If the tacobox will continue to pop up in availability every 4-5 months though, I feel comfortable waiting (and researching), just hear alot about them being in short supply.
  8. Apr 18, 2023 at 12:27 PM
    #3148
    Operator8
    Woodland Park, CO
    SAS INW
    What local trails have you done with both? How'd they fare?
  9. Apr 18, 2023 at 12:30 PM
    #3149
    Dan8906
    Daniel
    Concord, California
    Yeah I get what you’re saying. I did the rubicon with out a crawl box then with it and it was so much more enjoyable haha.
    I built my TG with pretty much all marlin stuff. But I think either way they both get the job done
  10. Apr 18, 2023 at 12:33 PM
    #3150
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    Funny enough, NWF figured out that the Marlin/Sumo 23 spline stuff does not match OEM 23 spline like TG’s gears do. @Kerleyfries had to have NWF machine his Sumo 23 spline input to fit the NWF crawlbox output. They told him that Sumo/Marlin don’t fit their adapter that was modeled on OEM 23 spline, but TG gears fit fine.
  11. Apr 18, 2023 at 12:37 PM
    #3151
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    If you're willing to put in the work for a flat belly, being able to clock the rear case is a huge plus to the NWF that you can't do with the others.
    And it doesn't leak a drop. :stirthepot:
  12. Apr 18, 2023 at 1:04 PM
    #3152
    Dan8906
    Daniel
    Concord, California
    Are you done with your flat belly? That is a HUGE benefit
  13. Apr 18, 2023 at 1:26 PM
    #3153
    Squeaky Penguin
    Brett
    Pretty much as flat as you can get.
    I clocked the case the full amount and remade the trans crossmember. Also raised the gas tank. It made a huge improvement in breakover angle.
  14. Apr 18, 2023 at 1:27 PM
    #3154
    Dan8906
    Daniel
    Concord, California
    Ah that’s sweet
  15. Apr 18, 2023 at 1:45 PM
    #3155
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    FYP :D
  16. Apr 18, 2023 at 2:39 PM
    #3156
    Kerleyfries
    Kerleyfries Idk what the hell I'm doing
    Zack
    Lebanon
    ‘17 F150 and SAS ‘98 4runner
    If you go swap to an FJ t-case then you just use the internals from your factory for the NWF box and you’re done. An FJ t-case can be had for like $400, so just figure you’re buying that at the same time as NWF box.
    I just got a box from them for my runner build and it showed up in 7 weeks I think? Vs. the 8-10 week lead time they quoted. And they’ve been fucking awesome to deal with and even helped me out by sending me some free oil seal rings that I broke.
    jubei and Operator8[QUOTED] like this.
  17. Apr 18, 2023 at 2:41 PM
    #3157
    Kerleyfries
    Zack
    Lebanon
    Which is fucking insane to me that Marlin just decided to build their gears larger, but whatever. NWF is top notch for doing that for free and covering the shipping. I offered to pay but they wouldn’t let me.
    FWIW, stock 23 spline and TG are identical and will work with NWF stuff. Marlin, sumo, and one other company are confirmed to not work with NWF’s shafts without machining.
  18. Apr 18, 2023 at 2:43 PM
    #3158
    Ricardo13x
    Ricardo13x YT: @UrbanOpsOffRoad IG: @urban.ops.offroad
    Upland, CA.
    05 OR DCSB ProRunner(4x4 conv.), Chevy 63”s, NWF EcoCrawler, 35”s
    Random stuff. Oh! and converted to non ADD 4x4.
    Man I want one of those so bad, at the moment sourcing a cracked t case to retrieve the donor parts :curls:
  19. Apr 18, 2023 at 3:53 PM
    #3159
    Squeaky Penguin
    Brett
    Maybe they're getting a little harder to find, but I bought a good condition 3rd gen 4R case for $150 to gut. :notsure:
    Ricardo13x[QUOTED] likes this.
  20. Apr 18, 2023 at 5:16 PM
    #3160
    Tacofire98
    Tacofire98 Well-Known Member
    Jake
    Castle Rock
    01 TRD
    I have a few trucks with 4.7 duals. I'm in littleton if you ever want to try.
    I will say, if I did have an automatic I would lean to the NWF, that would be a nice final ratio. @Squeaky Penguin did impress me in Moab with his NWF box on some nice climbs. Flat belly is nice for a long wheelbase.
    jubei and Squeaky Penguin like this.
